Question about Toshiba PDR-3320 Digital Camera
Camera won't focus
Toshiba PDR-3320 has blury picture LCD monitor. I have reset all the settings and replaced the batterys. The viewfinder lamp flashes when I turn the camera on. The owners manual says if the viewfinder light flashes the lens cannot work because of obstacle. I cannot see any obstacle.
    Guru:
  • 1,705 Answers
I think you're camera has had it. You could try the Toshiba web site follow links for support and downloads to see if there's a firmware upgrade which may solve the issue.
I've checked the specifications and I wouldn't spend anything on repairing it. I'm afraid its just not worth the outlay. You could probably get a good camera with a higher specification second hand for less than an hours repair bill.
Posted on Jul 19, 2010
My LCD monitor won't light up to take a picture but it does when I review those I have taken thru the viewfinder
Most screens can be turned off for low battery usage. Check battery with tester or have it tested or replace battery and check menu and see if review screen is turned off. Rich
Apr 02, 2013 | Canon EOS Digital Rebel XS / 1000D IS...
Hi,lost my CD for my Toshiba PDR-3320 any where I can download it for free? Old laptop died and I need to re-install the software so I can post photos.Thank you!Kev
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Oct 09, 2010 | Toshiba PDR-3320 Digital Camera
First thing do you charge for this if so i can not do it When looking through the camera lens to take a shot it is bluery and you can not tell what it is. toshiba PDR 3320 digital still camera
No charge.... FREE!
The eyepiece has no diopter setting.
However, if you press the shutter button "halfway" down (don't press it all the way). the picture will come into focus.
After you focus, then press the shutter button all the way down.
This will work...
Sep 08, 2009 | Toshiba PDR-3320 Digital Camera
I press the shutter button a red light flashes in the viewfinder
Your focus or lighting is too low for the picture. Add more light, and hold the button down half way to self adjust to see if it goes away. Change the battery to a lithium battery, which helps the digital cameras work their best.
Let me know if this helps.
Jan 24, 2009 | Toshiba PDR-M700 Digital Camera
Locked lens
your camera needs a new lens assembly.These lenses are not repairable .They can only be replaced.
Jun 23, 2008 | Toshiba PDR-3320 Digital Camera
Lens not moving
The lens mechanism is shot. Depending on the age and possible cause of the condition- has it been dropped? I would think replacing the camera is a better option than trying to get it repaired -which I think is not a likely option
Jul 25, 2007 | Toshiba PDR-3320 Digital Camera
Better Focus
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Only us the MACRO MODE for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Be sure not to use Macro Mode for Normal Photography. Using MACRO MODE improperly will result in poor focus (also known as 'fuzzy pictures'). 4. Rely on the LCD Monitor, especially for Telephoto and Macro photography. Due to differences in depth perception, the Viewfinder is not as accurate at the LCD Monitor. When in doubt, trust the LCD. The LCD will display the subject more accurately than the viewfinder. This will help with "framing" the subject, or determining if you have enough light for proper exposure. 5. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Better Focus
Sep 11, 2005 | Toshiba PDR-3310 Digital Camera
Blurry Pictures
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. If the camera can automatically set the focus and exposure, the LED by the viewfinder will turn GREEN. If the camera can not adjust the settings automatically, the LED will turn RED. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Only us the MACRO MODE (Flower Icon) for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Using MACRO MODE improperly will result in poor focus. 4. Rely on the Rear LCD Display. When in doubt, trust the LCD. The LCD will display the subject more accurately than the viewfinder. This will help with "framing" the subject, or determining if you have enough light for proper exposure. 5. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Toshiba PDR-3320 Digital Camera Logo
Top Toshiba Cameras Experts
john milligan
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
