E3 paper jam
My copier keeps jamming (the code is E3) ,it looks like the paper is crooked when jamming . There are fine bristles it appears to catching on ,not sure though , and it appears that there is less clearance on the side that the paper is jamming on (only one sides seems to be jamming) . Is there an adjustment or any fix that you may know of ? It was moved recently , not sure how carefully ,though.It did work for about 3 months after moved.It is a xerox 5021 copier.
Thanks in advance
radar0404@sbcglobal.net
  • radar0404 Apr 24, 2008
    thanks for all your help, it is greatly appreciated
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
If the paper is crooked it will come out wrinkled. If not the print is crooked indicating a different problem.
You wil have to look at the paper as it is printing, to see where it is catching, paper ramp maybe ( before the fuser entrance), exit rollers? ( only place I know there are bristles)
E3 is : paper jam in fuser
also check fingers or claws on fuser they catch the paper if worn.
Posted on Apr 23, 2008
Error 3 indicated - what is it and how do I fix it
E3 means that there is a paper jam. If you are getting the E3 error and there is not an actual paper jam you may need to do is simulate a paper jam. Try inserting paper crooked to cause a jam so that when it starts trying to feed the paper through it gets jammed. Then lift the cover up and take the paper out. You'll then get a bunch of the lights flashing. Turn the printer off and then back on and you should be good to go.
Mar 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam
look for debris in the feeder very common to see staples, and paper clips in the paper path
Mar 29, 2010 | Canon Office Equipment & Supplies
Paper jam (e3) BUT no paper jam
make sure you open all check points, if yours has a rear feed through, look in there also. it only takes a tiny piece of paper to cause it to say that. use a flash light, have had to use one to find several that way.
Feb 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My canon pixma mp150 have an E3. How can I fix
The E3 error indicates paper jam. If there is no paper jammed then look that if something is stuck inside the rollers. This may solve your problem.
Aug 31, 2009 | Office Equipment & Supplies
Printer all in one
E3 is a paper jam error, but I would use a flashlight and small mirror to check for any paper scraps or paper clips and remove them carefully. If you can't find anything then it's possible that the paper path sensor is broken and would require a shop repair.
Jun 22, 2009 | Office Equipment & Supplies
Flashing E3 error code for a paper jam
I had the same problem with my mp 160, Error message was blinking. I tried to print but the printer would take 1/10 of the whole page and stop, even though rollers were moving. My solution for this was to take a piece of thin cardbord(I used a magazine cover), cut it in a size of A4, put it in printer, printed it and when the rollers start moving I forcebly pushed the cardboard through. Now it seems to work fine. Hope it does for you.
Mar 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer Error E3
E3 error -
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press [Black] or [Color].
The above is direct from the user manual.
If there is no paper jam - look for any small pieces of paper that could be located near the roller sensor.
Oct 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
189 people viewed this question
jasbo
jasbo
