I plugged my brand new Philips usb 2.0 Portable Disk Drive (model SDE3271SC/97 into my macbook (running os 10.5) and it is not showing up even in my Disk Utilities application (i was going to format the drive). What gives?
fire sine
  • 382 Answers
SOURCE: bought a new LaCie drive; isn't recognized by mac or pc
Lacie Porsche drives in my experience or infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a small red or orange light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure. Hope this helps.
Posted on Oct 02, 2007
Benimur
  • 6966 Answers
SOURCE: Averatec USB ports
Hi, A couple of things you can try: 1. In your Device Manager, un-install all USB instances then reboot. Win XP will auto detect and auto install back the USB drivers; 2. On reboot, again in your Device Manager, all instances of USB Root HUB, right click, click on Properties, Power Management tab, un-check "Allow the computer to turn off this device to save power." 3. Download, install and use to format flash drives the HP Drive Key Boot Utility (cp006049.exe) available at http://h18023.www1.hp.com/support/files/server/us/download/23839.html If for some reason none of the above will for you, you may need to install an external/powered multi-port USB 2.0 Hub. Hope this be of some idea/help. Post back how things turned up or should you need additional information. Good luck and kind regards.
Posted on Oct 05, 2007
SOURCE: it keeps asking me to format the disk
I have many thumb (flash) drives,...all of which has asked for a format on at least one accasion...to save them I've always used partitioning software to re-write the partiton...which has made the drives re-usable after every fatal occasion....I strongly suggest constantly backing them up...but if the flash drive ever states that you must format it....grab the partitioning software,,,partition it...and then enjoy it for a few more months before you're required to do it again...
Posted on Dec 06, 2007
sweetyanne
  • 68 Answers
SOURCE: Hard Disk Crash
Actually if the hd is corrupted, you can try to go to safe mode or do a chkdsk and then fix boot otherwise you need to contact drivesavers for that.
Posted on Nov 04, 2008
rickyostrom
  • 274 Answers
SOURCE: thinkpad 390x 2626, won't boot from cd drive
Try pressing F12 at startup, you should get a boot option.
Posted on Nov 19, 2008
I have a hp portable hard drive which i re-formatted but now isn't recognised when plugged into my computer. how do i remedy this?
simplesave what?, they made vast versions of many types.?
SSD, HDD, 2.5" 3.5" and with or without powerpacks.(later best)
DO learn that many Laptops cant do HDD motor currents. a fact.
or is MARGINAL, works now , not later the repeats over and over.
(due to motor spin up failures, drive protects itself (fact2)
but no pc stated, nor OS nor if using GPT formats.
no drive stated, just a drive. (matters big time)
if you are on say a W10 box. and format it GPT
w7 cant read those. not invented yet.
The format prog even tells you that as you do that... a fact. w10
i bet a linux live boot (newest version sees it>? ) a big clue there.
sure.
do to CP, control panel
then go to admin tools
go to disk management next.
let it run out, (mine has 5 drives, and 20 partitions) so takes time to scan it. bam, there you see it.
even a 100% erased drive (no format ) shows up here.
all do, if formatted on a MAC NO SHOW.
if you moved to another PC, say so.. you didnt
format it to NTRS. for sure.
in fact that screen above, right click it and format it to NTFS.
now all Windows boxes see it. even linux.
do not use GPT formats, if offered or other boxes old will not be able to use it. ever. (boxes = PC)
here is the GPT warning read it if you saw it.
http://www.pcdied.com/new-disk1.JPG
all ways to fail is covered here.
covers all modes, of use, and pitfalls all.
http://www.pcdied.com/external-hdd.html
if disk managment fails.
say so. and tell PC and OS you are running , what you have there matters, and answering to 36 years of pC made is impossible.
D-man fails. if motor fails to start. or not plugged in. or powerpack missing on HDD, for sure on 3.5" all must have pack there unless SSD.
if 2.5" it will work on most desktops! (not all)
if your old relic XP laptop with USB 1 or 2 is limited to 100ma
current ,then how can 1amp motor run on that? it cant.
if the PC is thunderbolt USB-c fitted it runs them all.
its high powered is why, power means 5vdc USB-V is high current rated. (as seen on new PC, and custom cable adaptors)
(in all cases, bad power or wrong format is it)
(i bet drive is ok)
Aug 18, 2017 | HP Computers & Internet
Blue screen when usb plugged in to new board old xp home
1.) Ensure XP is updated with latest device drivers
2.) Ensure latest chipset & motherboard drivers are installed
3.) Check USB drive, and USB port
4.) Boot up with any Linux OS Boot up disk and check if USB is working
5.) Install Windows 7 in case new drivers not available on XP
Feb 26, 2013 | Computers & Internet
I bought a new toshiba canvio 3.0/2.0 plus (black) plug it in my macbook but it doesn't show on my desktop as well as on my disk utility, i plug it in another older macbook it shows on the deskto
the disk configuration in your laptop is not complete
  1. Select the drive device in the list of devices, which is the item above any storage volumes on the drive, and which may show the manufacturer name, media size, and so on.
  2. Choose the "Partition" tab that appears.
  3. Select "1 Partition" from the drop-down menu (or more, if you have specific need for more than one volume). When you select a new partition layout from the drop-down menu, each new partition will be formatted to Mac OS Extended (Journaled) by default, but be sure to double-check this by selecting each in the partition diagram and then choosing the format for it.
  4. Click the Options button and ensure "GUID" is selected as the partition scheme.
  5. Click Apply to save the changes.
Sep 21, 2017 | Toshiba E05A100PBU3XS Canvio 1TB USB 3.0...
My computer won't discover my brand new 250 gb Seagate hard drive. It's connected by a USB port in a HP compaq computer running windows xp version 2002. It didn`t come with any software and says it`s plug...
It is possible the usb port is not giving enough power for the device, theres a cable the allows you to connect the device to 2 usb ports to get more juice, maybe that could help.
Mar 21, 2011 | Seagate 320 GB USB 2.0 Portable External...
Have new drive Hitachi SimpleDrive Mini 250GB USB 2.0 Portable External Hard Drive SDM/250RW (Red Wine) and works fine on Dell precision M4300 laptop Vista OS with either one or two usb plugs (so no extra...
Most USB hard drives require an external (or secondary) power cable to power the devices when connected to laptop or netbook computers. In some cases, even older desktop computer models will require a similar cable.
This is due to the specifications for the USB standard as it dictates the amount of voltage that a USB port can deliver. Some USB ports are considered "powered" and are sometimes identified by the USB logo and a small "+" sign to indicate the added voltage.
Note: Not all manufacturers use this logo, so if your computer doesn't have this variation of the logo, it doesn't necessarily mean the USB port is not powered.
This added voltage supplies additional current to power smaller devices, such as portable (or 2.5") USB hard drives. However, in the even that the USB port is not powered, then only the minimum amount of current is supplied. This should be enough to slightly power the drive, but not sustain it, thus causing the clicking noise and there isn't enough current running through to move the arm that reads the data on the hard drive.
Chances are that the USB ports on your Asus Eee are not powered and won't allow your hard drive to run until either a secondary cable is purchased or if you use a powered USB hub instead.
The secondary cable looks a lot like a Y-USB cable with one end that connects to your hard drive and the other end consisting of 2 USB plugs that both connect to existing USB ports on your netbook. Between the 2 USB ports, they can draw enough current to power the hard drive - the downside being that if you only have 1 USB port you cannot utilize the cable or if you have 2, they will both be occupying the ports while the hard drive is in use. These cables can cost about $1-7 depending on brand and can be found online in retailers such as eBay & CompUSA.
The USB powered Hub is a more expensive solution, ranging at about $10-25, but is the higher recommended of the 2 solutions since it will provide its own power supply to the tiny device, will use on 1 of your USB ports and since it's a hub, they usually have anywhere from 3-5 additional USB ports (all powered) for you to use, if needed. Some even include built-in memory card readers and they do not require any additional drivers or software to install and can work on any desktop/laptop/netbook.
Aug 14, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
Light goes on, but is not recognized by computer
Try using another USB cable or try connecting the HD into another computer. If same problem occurred, then the problem is isolated with the HD.
We can only save the HD by reformatting it once it showed up in the Disk Utility or on the desktop. Unfortunately, there's nothing that we could do if the HD is not mounting on the screen of the MacBook and not showing in the Disk Utility.
The only hope that we could think of is once the HD is detected by another computer. Meaning that we could still reformat the HD.
But if not, then you need to get a new one. Good luck!
Nov 22, 2009 | Western Digital WD Passport 250GB Portable...
My Verbatim 320GB portable drive will not work with my iBook G4
Called Verbatim support and they said it is a power issue. They will send you a USB Y cable to get power from both USB ports. Hope it works.
Jun 29, 2009 | Verbatim 160GB USB FireLite: The "drive...
Philips HDD SDE3273FC won't work on MacBook OS X
Initialize drive, (remove old partition and create new for OS X file system).
Jan 04, 2009 | Computers & Internet
Upgrading from MAC OS 10.4 to OS 10.5
Apple has a list of specs to run it. Looks like yours falls within it. Although some things will need other requirements like a webcam for photobooth or ichat. But you should be able to get by. Might be a bit slower than some Macs running it, but as long as you don't have 20 things going on at once, you should be fine. Go to an Apple store and try it out first though to make sure you like it.
Sep 05, 2008 | Apple Mac OS X 10.4
Computers & Internet Logo
610 people viewed this question
David Payne
David Payne
