Question about Amana ARGS7650SS Gas Kitchen Range
Oven burner will not light up - Amana ARGS7650SS Gas Kitchen Range
    Genius:
  • 1,417 Answers
what this indicate or what it means is that there has been a loose of wire connection from the element or weakness from the element
what you will have to do first of all is to unscrew the oven from the stroll with a screwdriver (technician tools ) the trace the wire down to the element (heater or heat provider) it is silver in colour at the lift or right Conner side of the oven to see if there is any form of loose of wire from the connection ,
if any then fix it up to the element , but if non then it meant that the element is bad which will need a replacement .
You can get the element from the below site
/www.maxoncorp.com
directcaterparts.co.uk
premierrange.com
appliancedirectparts.com
all these site offer good service and price you can go shopping
Please note if you which to get the element your self make sure it same size from the weak or old one to avoid incompatible with the the panel .
thank you and thanks for using fixya.
Posted on Jul 19, 2010
My stove is a GE and everything works but the burners and oven.
check your breakers everything you said means not enough voltage
Apr 05, 2014 | GE Stove/Oven/RanSurface Burner Knob -...
The "hot surface" light will
for the burner problem if the hot light wont go out you have a bad burner, that burner has a limiter on it that tells you when the burner is hot. as for the oven light i would try to change the bulb
May 12, 2011 | Kenmore Microwave Ovens
Gas in oven wont come on,burners and broiler ok, oven light comes on but oven won't come on,electrical connections ok, checked
this is a 2 burner oven with 2 ignitors . the bake ignitor is too weak to light the burner . replace it and the bake should work properly .. mm
Jul 13, 2010 | GE JGRP17 Gas Single Oven
Oven burner doesn't light. Igniter doesn't light. Boiler burner does light and Igniter does light
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Mar 01, 2010 | Maytag Ovens
Bottom burner for maytag gas oven will not light. The broiler will turn on and heat, but not the bottom burner.
will have to replace the oven ignitor part #120000035 / this will correct burner problem / mm
Dec 08, 2009 | Ovens
Oven won't light - electronic ignition oven
Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
Aug 12, 2009 | Kenmore 33169 Gas Single Oven
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Top burners often wont light if oven is already lit
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
Dec 07, 2008 | GE JGBP28 Gas Kitchen Range
Amana ARGS7650SS Gas Kitchen Range Logo
57 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
