Question about Refrigerators
I own a Beko AP930 side by side frost free fridge freezer.Yesterday an error code appeared on it ,the code is E8.Could you please tell what this means.Thanks.
  • 2 more comments
  • Anonymous May 17, 2008
    E8 on display what does this mean
  • podgerodge May 17, 2008
    E8 is flashing on the display what should i do to cure it
  • jamesbp May 29, 2008
    E8 flashing on display of Beko fridge-freezer. No other symptoms... Any ideas?
  • Josephine Lucas
    Josephine Lucas Jan 22, 2013
    beko as920 double fridge freezer error code 8 is this the same problem with my ff
Just had this fault fixed on my 930. It is the ice sensor just under the ice cube tray - mine had a broken wire (from rotating several times a day for over a year!)
Fiddley but easy fix yourself with a "leggo" block connector to re join the wire if that is the fault, or ring Beko on 01923 654659 (very helpful company to deal with) for a part.
Part number 4344740185.
The other suggestion about the water filter I respectfully believe is wrong!
Posted on Jul 31, 2008
I have also just fixed the E8 fault on my Beko 930 fridge-freezer. I found the the comments provided by Fixya44 to be useful but too brief - I also had an ice tray sensor broken wire connection and the fix was easy but very, very fiddly. To replace the wire 1) pull out the ice reservoir box ("ice cube container" in the manual), 2) pull out the fresh freeze tray (located above the ice reservoir box) as far as it will travel, 3) undo the snap fit holder on the bottom of the icetray holding the sensor, 4) undo the snapfit clip on the right of the icetray, 5) undo the cover of the electric connector compartment by undoing the screw - this is located in the right roof lining of the freezer compartment, (note the back of the cover is not screwed in but is held in place by a lip tab), 6) prise open the clamp and unclip the ice tray sensor electric plug, 7) replace with the new part by repeating steps 1 to 6 in reverse. The really tricky bit is reconnecting the plug in the roof lining as the space for a hand is very small. Just this bit took me about 30 minutes to make good whilst the job in total took 40 minutes. However the effort was still well worth saving the £100 or so to call out an engineer.....
Posted on Jul 26, 2009
Change the water filter (every 6 months) then press the auto eco button for 5 seconds to reset the 6 month timer. Try ebay or espares.co.uk for good filter prices
Posted on Jul 07, 2008
Above directions are good just don't footer with the bare wires when the power is still on as you''ll look like huggy bear from Starksy Hutch as I did for 1/2 hr and some expletives, all sorted now though
Posted on Oct 25, 2012
Why does the new fan in my Beko AP930 not come on. It worked for 30 minutes when I first installed it.
Three possibilities: 1) new fan motor failed or is jammed by something
2) power is not getting to the new fan. 3) The fan run circuitry is not getting the 'run' signal from the temperature sensing system.
Jul 23, 2014 | Beko Fridge Water Filter Ap930 Ap930x...
Error code E3, BEKO AP930
Hi, the error code E3 on the BEKO AP930 you have a problem with the fridge thermostat open circuit....
Take care
Jul 23, 2010 | Refrigerators
ICING UP FREEZR
this sounds like a defrost timer issue possibly a bad defrost heater is also involed,what was done the first time seems like it needs to be done again.some thing is not telling it to go into a defrost mode may be a sensor issue as well. good luck with this problem
Jan 21, 2010 | Samsung RS2630SH Side by Side Refrigerator
Beko ap930 no water geting to to ice tray
For me, this problem was because the tube was blocked with ice (the part of the tube inside the machine), which is why the tube popped off the back.
Try defrosting the freezer, or pushing hot water through the pipe with a syringe
Oct 28, 2009 | Beko 24 in. D3421F Free-standing...
I have a beko fridge freezer. I had an error code
I got the answer myself and thought I would share it.
The E4 code means that the auto defrost is not working. Call beko and tell them the code and they will tell you what part it is. I think the part number is 421445. It is a little black tube with two wires comming out. The part costs about £10. To fit the part you have to go into the feezer side of the fridge and carefully remove the white plastic at the back which is held with clips and one screw. To find where the part goes look for a long white fatish wire. The black fuse or thermostate is hidden in that. You will see where the wires go when you remove the old one. It is easy to do. Once you replace the part the error light will still be on but will go out after the fridge is back to being cold. Don't forget to replace the inside of the freezer when done! Hope this helps. John
Jun 18, 2009 | Freezers
Fault e8 displayed on beko ap930 fridge freezer
I had the same error message and the ice cube dispenser stopped working. On examining the workings, I found that the wire that should have been connected to the ice cube tray had sheared somehow (???) - a simple splice with lots of insulation tape has apparently fixed the problem.
Jul 03, 2008 | Refrigerators
Beko AP930 with Error code E0 in LHS of display .... what does this mean ? .... nothing in manual
Error codes are printed on underside of plastic cover on top of fridge. Warning electrical components inside! Error code E0 is the FREEZER door not being recognised as closed, switches are normally ok may be problem with printed circuit board. Freezer will work as normal but engineer should be called.
May 08, 2008 | Refrigerators
FLASHING E8 (WARNING) ON MY FRIDGE FREEZER
A model number and serial number would help in any diagnosis.
May 04, 2008 | Freezers
I havew a Beko AP930 displaying error E8. The instruction book does not explain error codes. Can anyone help?
have the same thing and it is a small sensor on the ice maker that can miss align,ours is under warranty and is being repaired its just a case of re-positioning it...ps make sure water filter is changed every 6 months
Apr 25, 2008 | Refrigerators
Frost free fridge/freezer
that is an error code call manuf. for solution
Dec 06, 2007 | Freezers
Refrigerators Logo
1,148 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
