Question about Sony VAIO VGN-S460 Notebook
INTERMITTENT DISPLAY PROBLEM
The disply somtimes work other times show black screen after booting the notebook. Could you let me know what causes this problem>? thanks
  • 2 more comments
  • Dukeoftest Apr 22, 2008
    Closing and open does not fix it. I try to move the display back and forth when it works the display stay on. Thanks
  • klmarley Apr 26, 2008
    My screen flickers and turns black. Moving the screen doesn't seem to cause or correct the problem. If the screen turns black it comes back if I touch the pad. I have connected the unit to another monitor and it works fine. the monitor also works fine in safe mode. I thought that this may be a driver issue but it was not corrected by performing a complete system restore.
    ANY IDEAS?
  • Timothy Brooks
    Timothy Brooks May 11, 2010
    Does opening or closing the display cause a fix or flicker?..then could be cracked wires or a loose terminal.
  • 121 Answers
Sorry, The wires to the screen are damaged (they are in a film like conector), and the repair is not easy. Best of luck.
Posted on Apr 22, 2008
Display problem
this may or may not help but it has worked for me many times in the past in a tight jam. good luck.
Apr 07, 2014 | HP EliteBook 2530p Notebook
Samsung syncmaster 912T disply will disapear. moniter still on just not getting info from cpu. after it is on for and hour somtimes it will not show display
Your description suggests the fault is with the screen, not the system. Can you you test that by connecting both screens to a buddy's computer?
When first powers up display is fine suggests a bad solder joint, revealing itself after heating up.
Oct 27, 2017 | Samsung SyncMaster 912T (Black)
Display Shows on External Monitor, but very faint
one of two causes : inverter board damage ( Replace it) or backlight lamp damager (also replace it).
May 09, 2010 | Toshiba Satellite A135-S4527 Notebook
Screen stays black when booting up on Gateway laptop
there is a inverter in lcd that makes shinely, white .
it looks like inverter issue. need to get service.
May 29, 2009 | Acer Aspire One PC Notebook
My laptop is showing a black screen nad nothing else after booting. what could be the problem with it?
Remove the back panels and remove the RAM and unplug the battery and any source of power. This will purge the memory of any instructions that maybe causing your problem. It sounds like a cooky fix but it works.
The black screen is usually the cause of this.
Let me know if it boots, if not we will find another solution
Apr 01, 2009 | Sony VAIO VGN-S460 Notebook
No Display
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 25, 2009 | Fujitsu Siemens CELSIUS Mobile A Notebook
Gateway 2" monitor won't display
blown capacitors this can be fixed I can help or advise you how to do it but it will require soldering internal components.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
The display screen has turned black
When you connected the external monitor thto the laptop did it display?
If so then you have to reset the monitor port. Hold down the function key and find the FKEY that shows a picture of a monitor. Press that until you get the laptop screen back.
Typical use is:
  • 1 press = external monitor
  • 2 presses = laptop and dual monitor
  • 3 presses = just the laptop screen
Dec 12, 2008 | IBM ThinkPad R40 2722 Notebook
Black display
start your computer then press f8 to go to advance boot menu then select enable vga to boot. when you get to log in and get your screen try to reinstall the video driver
Jun 04, 2008 | Acer Aspire 4315 Notebook
Sony VAIO VGN-S460 Notebook Logo
119 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
