Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Ice maker issues
I have a Whirlpool fridge gc5shexns02. Had to replace the water filter and ever since the ice maker quit working. After a ton of research The clip that drives the harvest arm was broken. So I replaced the whole ice maker (local parts store did not have just the module). Still not harvest or water fill. So I hand filled the tray and waited 12 hours to see if it dumped the hand made ice cubes. It didn't. So harvest mode is not firing. I then tested the voltage to the module and I am getting 34 v(ac) which is a far cry from 120v. One article I read said that the optical sensor boards being bad could cause the voltage to be weak. So off I went to replace the boards.
After replacement I still had 34v at the l & m test point. So with all the new parts I jumpered t & h and closed the door. I can not get harvest mode to start.
I have water but no cycling of made ice cubes. Voltage does not match what I was told to expect. Any help or suggestions would be greatly appreciated. Is it possible the new ice maker was bad out of the box?
Thanks,
Dan...
  • Remow2112 Apr 24, 2008
    Ok, fixed it. Turns out the motor on the new module was bad out of the box. Note to anyone working on a whirpool moduler ice maker. You can test the motor using an ohm meter. Put the probes in the l & m ports and you want a range of (4400 - 8800) ohms. DISCONNECT THE POWER before doing this test. My first new ice maker showed less then 1000 ohms.
    Hope this helps all.
    Dan...
  • 145 Answers
The boards put the 120 volts to the ice maker. If you open the door the red light on the board in the center should blink two time repeatedly. If you push the flap on the left in the light should be solid. If you push in the light switch for the door the light should go out.
Posted on Apr 24, 2008
Ice maker doesn't make ice anymore. The water works and dispenser levers on the door work for both ice (use store bought ice dumped into tray) and water. I replaced the filter after it quit making ice. Not...
you've already done the first thing i suggest, and that is to change the water filter. But if you still cant get ice made, you have a problem with either your ice maker or your water valve, or an electrical issue in the ice maker system.
Apr 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water to ice maker.Ice maker quit making ice.
What I found was the problem was that I had not changed the filter on a regular basis.Because of this the water flow to the ice maker was restricted.What this caused was the water inlet tube on the ice maker to freeze up.On my unit it is a black rubber tube about 11/4 long on the right side.You can see it if you know what you are looking for.If you squeeze it you can tell if it is froze or not.You can use a hair drier to thaw it out or squirt water up into the tube .It does not take very long..To make sure it is clear disconnect the tube on the back of the fridge and blow into it.If there is no restriction the tube is clear.After you have determined the tube is clear add water to the ice tray so the unit will make ice this will start the ice maker to cycle.Its making good ice now.
Jan 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side refrigerator, model # ED25PQ
Under the right side of the fridge in the back there is a dual valve for water and ice. Try changing it out, most likely the ice side is not working. Make sure you unplug the unit first
Nov 19, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not working
what filter? drying filter? Water filter? Dust Filter?
Jun 24, 2008 | Frigidaire FRS26R4A Side by Side...
Ice Maker
  1. Water comes from water pipe, usually with a shut off valve (open??).
  2. Fridge has a small filter (for sand etc.) at inlet. (not clogged??)
  3. Water travels to solenoid valve, and waits for request. (do you hear it click when water requested??)
  4. Water usually goes to a fine filter..(these fail (plug) quite regularly).
  5. Water goes through storage in back of cool section (Inside fridge- is it full of water?).
  6. Water goes to ice maker on fill request.
  7. ?? Is the power switch "on" (to icemaker)??
  8. ?? Is the full / stop filling paddle/bar up?
  9. ...ask me more questions
Apr 21, 2008 | Whirlpool ED5FHEXMQ Side by Side...
If you have a whirlpool icemaker inside of your freezer (I've read on other posts that whirlpool ice makers are installed in various makes and models), there is a white cover over the ice maker (it's square). Remove the square cover with your hands or stick a flat head screwdriver in the side until you can pull it off.
Once the white square cover is removed, you should see a white wheel with gear teeth. In the middle of the white wheel is a plastic snap that should be holding it in. I noticed that one of the little plastic snaps was broken...which caused my "no ice" problem. A simple test is to push the white wheel toward the icemaker. If the wheel starts turning, you have found the problem. You see, behind the whhite wheel are metal contacts that need pressure for the ice maker to work. Without the center plastic snaps holding it it, the pressure is gone...and so is the metal to metal contact.
I previously called Whirlpool, searched all of the web...to no avail. Every other solution was "check for ice blocking the water tube" or "replace your water filter". That's all balony. If your regular water dispenser is working, you don't have an ice problem. And if your water dispenser is working, you don't have to change your fitler either.
If you realize that the little white wheel is the culprit, just google "whirlpool module" and you will see it for sale. I found one on ebay for under thirty buckaroos with free shipping.
Hope this helps.
Apr 20, 2008 | Refrigerators
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
172 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
