Tedelex EC-PD 2000 I pressed the S button (return to the factory setting) on my remote when I wanted to press the mute button. The TV started to initialize and it switched off. When I switched it back on the screen was blank and it went into an endless loop of switching itself off and on again
  • Televison & ... Master
  • 2,005 Answers
Does your set have a usb port on the back?
if so; you will need to contact the manufacturer to obtain a flash download to re-setup your set
these agents may be able to assist you: http://www.amap.co.za/servicesagents.aspx
Posted on Jul 19, 2010
  • 1 more comment
  • battlezone Jul 20, 2010
    Hi
    Thank you for the reply. I had a look in the manual, but there isn't a USB port on the back.
    From left to right
    DVI input
    VGA Input
    HD video input / Component video input
    Composite video input 1 / Super video input 1
    Composite video input 2 / Super video input 2
    Composite video output
    Audio output
    Audio input under HD video
    Audio input under component video status
    Audio input under composite video 1 & S-video 1 status
    Audio input under composite video 2 & S-video 2 status
    Audio input under DVI and VGA
    Antenna input
    Speakers
    Power input
    I can probably not open it up or something?
    Bright side, seems my TV is/was an HD ready TV :)
    I phoned all the numbers in Johannesburg area. They either don't fix TV's or don't exist anymore
    The one shop in Pretoria gave me these two numbers for Tedelex, but no answer
    011 490 9000
    011 490 9163
I have tedelex EC2159 remote codes it should be 3 digits not 4
Pilot remote control codes for TEDELEX:
30 results. Displaying page 1 of 1
NR Brand Model Type Pilot Supertel* Easytel Unitel 1 TEDELEX 1452 R/C P1679Y 2 TEDELEX 1452 TV P1679Y 3 TEDELEX 1455 TV P1655Y 4 TEDELEX 1458 TV P1655Y 5 TEDELEX 1459 TV P1655Y 6 TEDELEX 2052 TV P1679Y 7 TEDELEX 2056 TV P1690N 8 TEDELEX 2092 TV P1679Y 9 TEDELEX 2096 TV P1690N 10 TEDELEX 2098 TV P1655Y 11 TEDELEX 2099 TV P1655Y 12 TEDELEX 2122 TV P1545Y 13 TEDELEX 9227 TV P1690N 14 TEDELEX 9422 TV P1655Y 15 TEDELEX 9427 TV P1655Y 16 TEDELEX 9628 TV P4263 17 TEDELEX EC 2528 TV P4190N 18 TEDELEX EC 2909 TV P4264 19 TEDELEX G 148 TV P4263 20 TEDELEX G 149 TV P4263 21 TEDELEX G 202 TV P4263 22 TEDELEX G 209 TV P4263 23 TEDELEX N 9034 SA VCR P1814 24 TEDELEX RC 94 R/C P1655Y 25 TEDELEX RC 97-PI TV P4263 26 TEDELEX RC 98A R/C P4190N 27 TEDELEX RC 98D TV P4264 28 TEDELEX SOME MODELS VCR 29 TEDELEX SOME MODELS VCR P4205N 30 TEDELEX STUDIO 3000 G TV P1690N
* Note: Supertel, Minitel and PRO-TEL universal remote controls will share the same code.
Feb 26, 2017 | Televison & Video
How can I open the service menu?
Press the helpful button and check link below for various models
First power off your TV using the remote, then press following buttons quickly on your TV remote:
Display (or i+) + 5 + Volume Up + Power
It'll show the hidden service menu on your TV screen.
Once you enter into service menu, you can press Menu (or Options) button again on your remote to switch between various service modes such as Digital, Chassis and VPC.
To navigate between available options press 1 or 4 buttons. To change or modify their values press 3 or 6 buttons.
To save your changes, just press Mute + 0 (or Enter) buttons on the remote.
To restore settings to factory defaults, press 8 + 0 (or Enter) buttons.
PS: For some new models the above mentioned method might not work. You can try following key sequence to access service menu in those new models:
While TV is on, press Left + Right + Mute + Center button + Mute + Menu buttons.
Hidden Secret Service Menu Codes for Sony Samsung LG and Philips TV
TV Service Menus Hidden features you didn know about
Jan 31, 2016 | Televison & Video
I have an old Tedelex tv and want to install a diffrent remote on it. the tv work by by pressing buttons per hand. I am in hospatal and can'nt stand up
I usually get remotes from a cheap Chinese shop. They have codes for most TV makes. Incidentally, they also do remotes for aircon units. If no local shops, you'll get one on ebay.
Feb 08, 2015 | Televison & Video
Volume buttons not working
Either the mute button was pressed. Press the mute button once. If audio does not return, press mute again to return it to its original status. There could had also been a loose audio cables. Make sure loose audio cables are plugged in. Either the speakers are damaged. If so they need to be replaced right away. There could be distorted audios which means the audio cables or damaged and can easily be replaced. Buzzing audio wrong button on the remote was pressed. Press only one of the buttons on the remote one start with CBL,TV,VCR,DVD,and the AUX.
Mar 10, 2014 | Samsung Televison & Video
Restore Sony KDL32L5000 to factory defaults
• Check the input selection by pressing the INPUT button. You may be watching the wrong input.
• If you cannot hear sound from the TV, you may have accidentally pressed the MUTING button on your
remote control; press the MUTING button again or press VOL + to deactivate muting.
• If the remote control is not functioning properly, the batteries may be installed incorrectly or may be low or
an object or light may be interfering with the remote control.
• To reset the TV to factory default settings:
1 Turn on the TV.
2 Press and hold down the V button on the remote, press the POWER button on the TV set. (The TV
will turn itself off, then back on again.)
3 Release the V button when the TV is turn on.
WARNING: The factory reset will clear all of your customized settings including the Parental Lock setting.
When the Password is lost or cannot remember, enter the master password: 4357. This password clears your
previous password and allows you to enter a new password.
Jul 08, 2012 | Sony KDL32L5000 32 in. LCD HDTV
I need the code for a sv 2000 tv it has a dvd player on it
You did not provide your TV brand so I have provided instructions on how to perform a power scan.
  • Remote: Basic Remote (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Press and release the red TV Power button.
    4. Press and release the Up or Down Arrow on the remote until the television turns off.
    5. After the television turns off, press and release the # button.
    6. Test functionality with the TV.
    7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 12, 2011 | DISH Network IR Remote Control
I need the cod for a sv 2000 tv it has a dvd player on it
You did not provide your TV brand so I have provide instructions on how to perform a power scan:
Samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Jun 25, 2011 | Televison & Video
How to reset (manually) factory defaults?
Press Setup,Right Arrow,Press Down 3 Times,Then Enter 2 times this should reset factory settings, I Hope This Is Correct As I Realize You Cant See The Menu But I Studied The Manual And Wrote Out The Exact Key Movements To Navigate The Restore Factory Settings menu. Hope This Helps
Sincerely,
Michael Scott
Nov 16, 2008 | Protron PD-DVR100 DVD Recorder
Need to know how to acess the service menu
First, I would do a factory reset. Press power on the TV to turn it on. Press SET UP on the front of the TV. Press CH- (channel down) Next, on the remote control, press MENU. Make sure the cursor is beside VIDEO and press RETURN. Press the UP and DOWN or + and ? buttons to scroll to the item you want, and press RETURN. Press the UP or DOWN (+ or -) buttons to adjust the item AND press RETURN to save the setting. Do this for each category you want to adjust. We hope this helps you, and please let us know if you need any additional troubleshooting. Best regards. nightdiver
Jul 24, 2006 | Sony KV-27V22 TV
Televison & Video Logo
Top Televison & Video Experts
