Papper keeps jamming - Office Equipment & Supplies
  • 2 more comments
  • Lockjaw May 29, 2008
    With every copy or print job the paper starts to feed and then jams. Display panel says to open door. When I open and close the door, the print resumes and works fine but I waste a sheet of paper with every job. (The side paper guides seem a little tight and will not open wider.)
  • Anonymous Dec 16, 2008
    I also have the same problem. the printer will print for a while but gets jammed up. i have to remove papers constantly and then restart my print jobs. Its so irritating! Do I need to clean out the printer or what?!?
  • kelvin619 Dec 17, 2008
    I have the same problem for my FujiFilm Pictrography 4100 printer. I got an error message when I boot up my printer. It says paper jam. I check inside and there is no paper jam. I open the door and close it.... the error message is still there.
  • James Peters
    James Peters May 11, 2010
    What model is the printer ?
I seem to have fixed the problem on my Samsung SCX-4521F. The paper was feeding about 1 third through and stopping. I figured it was the large soft black paper roller which can be viewed at the back of the paper tray, loosing its grip.
So I initiated a copy function and turned the machine off half way through the soft black paper roller doing its 1 revolution.
This allowed me to access the back of the roller where I slipped a SLENDER toothpick under the rubber making sure the ends were trimmed.
This gives the rubber some extra grip and it is working for me... so far.
Posted on Jun 13, 2009
After replace toner keep geting message JAM INSIDE but there is no jam papper
I have a brother printer too, nine times out of ten you have to make sure everything is closed tight
May 30, 2015 | Brother MFC 7860DW - Multifunction fax /...
Printer says papper jam but thier is not any paper jam
Be sure that there is a paper jammed inside. You cant just see it.
May 09, 2014 | Lexmark S515 Multifunction Printer
Scx 4632f
hi, your printer papper out senser is damaged or papper out senser liver is damaged please check
Apr 02, 2014 | Samsung Office Equipment & Supplies
Incomming fax same page printing contenusly and wasting paper
put machine oil on papper roller let run a few pappers intell it gets worked in then see if paper is sticking if this doesnt work blow it out with air in can there has to be papper jamming the papper side.
Feb 13, 2011 | Ricoh 3310Le Fax Machine, FAX3310Le...
When i have no papper in the printer it keeps saying that it is jammed but i checked evrything and there is no papper
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jan 04, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
PRINTER JAM
look for small, small pice off papper in the printer where pappers pass tru
Sep 29, 2008 | Dell 1720dn Laser Printer
Papper jam.
There should be a door on the back of your printer, scanner, copier. Open that door and see if you have a paper jame there.
Apr 20, 2008 | Office Equipment & Supplies
The top lights stays blinking and printer will not print
Yes definetly,
First cheak that paper was cuts wrincled from any side from top or bottom, after pulling if yes cheak that the
small part of papper jam in to the papper path or sensor earia
or papper feed out sensor actuater arm jam by pulling the papper by you after cheaking those things you will able to solve the problem you are facing,
vyas
Mar 23, 2008 | HP DeskJet 5550 InkJet Printer
514 people viewed this question
jasbo
jasbo
