I have a new high efficiency washing machine. When the tank fills is is not a continuous flow. When the water starts and stops it sounds like the water pipes are rattling in the wall. what can i do about this?
  • antonam Dec 17, 2008
    I'm wondering if this might cause the pipes to break loose from the studs after a period of time...
  • 487 Answers
Actually not much unless you can reach the pipes in your wall
that is just the pressure in the pipes. it will keep doing that. Not to much to worrie about
Posted on Apr 21, 2008
After my toilet fill valve shuts off, water continues sipping into tank slowly. This causes water continuously overflow through overflow tube.
check that the fill valve was installed correctly
adjust the float level so that when full the cistern water level is around 1/2" below the over flow pipe end
what you have now is that the inlet water is not being shut off correctly and the water is still coming in and flowing out of the overflow
Mar 20, 2017 | Washing Machines
My Samsung washing machine wont stop with water filling
First clean the detergent drawer and button trap, then make sure the siphon cap {it might say "MAX" on it) is installed properly. Make sure water pressure is not too high.
Apr 18, 2016 | Samsung Washing Machines
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
Water doesnt stop when filling washing machine
There should be a "fill control" on the panel of the achine that lets you set the fill limit for wash loads ranging from small to large. Obviously, your fill control is not working
Oct 09, 2012 | Washing Machines
I put in a load. The machine filled up but did not stop filling. The dial did not proceede to next step, it stayed at the 10. Overflowing EVERYWHERE. When we moved the dial manually to spin, it drained...
your fill switch is either bad or "gllitched" and the timer cannot move until this switch senses the right amount of water for the load unless its an electronically sensed water/load capacity filled machine,when it starts,the water fills the unit and the pressure switch shuts the water fill off when at selected water level and powers the timer to continue the wash cycle,it works off a "bellows" on air pressure to change a switch by air pressure to operate the machine when full of water
Dec 27, 2010 | Kenmore 22622 Top Load Washer
When the washer starts to fill ,it only fiss for a
All washing machines have an electric controlled fill valve, which is connected to the timer switch. Either or both could be bad, but probably just one. The fill valve is on the back, behind the cabinet back cover, and it senses when to start and when to cut off by the level selected on the machine. Kinda sounds like you may have a timer problem. Is the machine fairly new, <5 years, or does it have some age? From what you describe, it sounds a lot like a bad or faulty timer. Or it could just be a loose connection. Vibrations from the water flow could cause just enough vibration to stop the flow of electricity to the valve or the timer. Highly unlikely, but possible. You will need Name, Model #, and Serial #, if you need to order a timer. I can post the procedures to test the timer and the valve, but you need a multimeter to preform the tests.
Sep 26, 2009 | Washing Machines
Water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Jun 07, 2009 | GE WDSR2080D Top Load Washer
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
