Question about Combi Centre DX - Mango
Gushing Water Help... I am Renting a house and it Has a Britony Combi Yesterday i adjusted the pressure because it was low now out side in my back garden the boiler is releasing water i dont want to have to call out the gas guy for this as it has happened before but he never told me how to fix it when he left. can u help me? Aaron
The pressure release may be faulty, or simply just to much pressure.
Try turning the red nob at the end of the pressure release, that will bring the pressure down.
Other you probably need a new pressure release valve.
Hope that helps.
Posted on Sep 24, 2012
    Problem Solver:
  • 7 Answers
Sounds like youve topped the pressure up too much, the boiler needs to be on 1 bar pressure from a cold state, thats the max really you want to increase it too, in operation the boiler pressure increases due to heat expansion but sounds like you may have more of a problem, if your renting the property then its the landlords duty to ensure your boiler works and its safe- consult the landlord asap and they sohould help you out
Posted on Sep 18, 2008
Flame Pulsing
A pulsing flame is a gas pressure problem. It shutting down is probably because the boiler thinks there is no flame when it goes low on the pulse and shuts the gas valve off. Listen to your pressure regulator and gas valve. If either is causing your problem, you will hear it. If so, smell the end of the vent line from it. If your diaphragm is leaking, you will smell it. I have specific questions but will throw a few general things out here for you. If you don't have a regulator outside of the gas valve, it is inside the gas valve. Try turning the supply pressure up or down a little. Remember where the screw is so you can put it back. Both under and over firing a furnace both have their own bad consequences, so don't adjust it too much either way. If it reacts to adjustment but still pulses, it is probably bad. Check the vent line for a gas smell. And of course, check all the electrical connections. Watch the pilot assembly when it shuts down to confirm why it is shutting down. Are you using natural gas from a city supply or propane? I'll check back here later to see if your still here. Hope it is already fixed though. Roger
Mar 16, 2014 | Heating & Cooling
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
Noisy Hot Water Gushing In Boiler
You may excess air in the lines
Nov 06, 2012 | Water Heaters
Britony Combi se 80 boiler
Steel wool is the way to clean. Hope this helps
Oct 18, 2009 | Water Heaters
I have a britony combi se 80. It keeps cutting out, error 60.
hi mate if you are happy to open the appliance and not disturb any gas connections clean the rectification probe, cause if its a intermittent fault it could be carbon deposits on the probe also make shaw the lead from probe to pcb is connected and not damaged if all ok its the pcb, let me know
Sep 09, 2009 | Combi Centre DX - Mango
Refrigerator gushing water through ice maker filter
Filters themselves don't usually leak. Check full insertion of filter, cracked filter housing or cracked supply line.
Aug 14, 2009 | Whirlpool Refrigerators
I have a chaffaeux combi 80/100 no hot water
sounds like diaphagm valve or micro switch best of luck
May 06, 2009 | Water Heaters
Combi Boiler - Hot water pressure low
the coil inside got clogged
Dec 22, 2008 | Water Heaters
Water filtre cartridge exploding
Ouch. Check your house water pressure for sure. DIY stores like Home Depot or Lowes, etc. have a pressure gauge that screws onto the garden hose faucet outside so you can check for pressure. It should be around 45-50 pounds (PSI). Only other thing I can think of is the filter had a defect that caused it to crack. They're generally real tough cases.
Sep 30, 2006 | Samsung RS2630SH Side by Side Refrigerator
Combi Centre DX - Mango Logo
318 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
