Question about Sharp Office Equipment & Supplies
HOW TO put paper into ShaRP ADDING MACHINE
HOW TO putting paper into ShaRP ADDING MACHINE
  • kakima Jul 20, 2010
    Since you didn't bother to specify the model, I can't give you specific instructions. Would you care to specify the model?
    You may be able to download the appropriate manual from the manufacturer's web site athttp://www.sharpusa.com/CustomerSupport/...
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
Having gone over a month with no response, I assume this is no longer a problem.
Posted on Sep 15, 2010
2 Suggested Answers
  • 168 Answers
SOURCE: Adding adding machine paper to the Ibico 1202
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. > (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in..Look in the back of the printer for a thin slot. (Usually goes under the printer1.gif assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Please remember to leave a rating or feedback if I have helped you with your question.
Posted on Mar 21, 2008
How do I put the tape in my Sharp adding machine model number EL-1750V?
Look for the paper feed button. Tape feeds from the bottom, that is, it unrolls like a P. Sometimes there is a release lever that lets you take tension off the roller while inserting the paper.
Feb 02, 2018 | Sharp Office Equipment & Supplies
Paper jammed. Now it displays a 0e Paper will not advance, and paper could have been pulled backward out of machine. How to I fix this? Adding machine Sharp Compet VX-2652H?
will who ever pulled out the paper incorrectly might have damage the sensor accurator, have a tech come and check it out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 27, 2015 | Sharp Office Equipment & Supplies
How do I put roll of paper in adding machine Canon P100-dh
hi. the is a little slot located in the back side of the machine insert the tip of the paper there and press the upper arrow in the keyboard. .
Mar 07, 2015 | Canon Office Equipment & Supplies
How do I clear a paper jam in my Sharp EL-2630PIII adding machine?
My paper is stuck and jammed in the feeder. I cant add new paper because of the jam. The new paper crinkles up as it feeds. Is there a way to remove the jam of paper that's stuck inside ?
Jun 13, 2014 | Sharp EL-2630P Calculator
Loading paper in a sharp el-1750v adding machine
i can tell you how in the back there is a **** on lower back slide paper in and push the button that looks like an arrow with ripped paper an it should feed
Jan 19, 2012 | Office Equipment & Supplies
How do you put paper in sharp el-1197pIII adding machine?
Follow the illustrated instructions on the first page of this manual.
Jan 11, 2011 | Sharp EL-1197P Calculator
How do you put the adding paper into the machine? My machine is a EL-1197iv
Never insert paper roll if torn. Doing so will cause paper to jam.
Always cut leading edge with scissors first.
1) Insert the leading edge of the paper roll into the opening. (Fig. 1)
2) Turn the power on and feed the paper by pressing . (Fig. 2)
3) Insert the paper roll to the paper holder. (Fig. 3)
DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
DAMAGE TO PRINTING MECHANISM.
Jan 03, 2011 | Sharp EL-1197PIII Calculator
How do you put the adding machine tape into the Sharp EL-1801V Adding machine?
Put the leading edge of the tape into the the opening on the back of the machine. Turn the machine on and press the button with the up arrow, then lift the little metal paper holder and insert the roll.
Mar 08, 2010 | Sharp EL-2630P Calculator
Adding machine problems
Block yBob - did you ever get an answer to your problem. I'm getting ready to install an ink cartridge into the same machine.
Aug 20, 2008 | Office Equipment & Supplies
2,100 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
