I have problems with usb ports on my laptop. not work or anything redconoce
    President:
  • 1,194 Answers
Thanks for using Fixya.
1. Connect the USB device into a different USB port on the laptop or another computer to make sure the problem isn't with the device instead of the port. Check to see if the device has a "Write-Only" tab. Push that tab into the unlocked position if it still isn't working in a different port.
2. Click "Start" and then "My Computer" if the device works in another computer but not on your laptop. Plug a device into the port and wait to see if the USB port shows up in the list of drives. Click on "Map Network Drive" if the drive does not appear. Choose a drive letter from the drop down menu and then double click the location of the USB device. Click "OK" and try to use the port again.
3. Navigate back to the Start menu and then click "Control Panel." Double click on "Device Manager." Scroll down the list of options and click the "+" located to the left of the entry labeled "Universal Serial Bus Controllers." Double click the name of the USB port that appears in the new menu. Click the "Drivers" tab and then click "Update Drivers." Wait for the driver to finish downloading and attempt to use the port again.
4. Close the drivers tab and right click the name of the USB port. Click on "Properties." Click the "Power Management" tab and then un-check the check box labeled as "Allow the computer to turn off this device to save power." Choose the "Communications Port" tab and then scroll down to the box labeled "Resources." Click the "Enable Device" button and then click "OK." Attempt to use the USB port again.
5. Close the Properties tab and right click the name of the USB port. Click on "Uninstall." Restart the laptop and then plug a device into the USB port. Wait for a new window to pop up and follow the on-screen instructions to re-install the USB port software.
6. Restart the computer and press the "F1" button on the laptop's keyboard once the manufacturer's name appears on the screen. Scroll down through the list of options that appear and highlight the option labeled as "Advanced." Press "Enter" and then scroll down and press "Enter" on the "USB Support" option. Press "F10" to save the settings and finish loading the operating system.
7. Open your web browser if your laptop is running the Windows XP operating system. Click on this link and download the Windows XP USB 2.0 driver . Restart the computer and try to use the USB port again.
If the problem is still there then If its a hardware problem, replacing the USB sockets may not be enough, considering they all went at the same time, I would say its a problem on the mother board. Something might have fused with the heat. Laptops have a real problem keeping cool because they are so compact.
Is it still under warranty, return to vendor
Good luck and have a nice day.
Posted on Jul 19, 2010
  • free01leonar Jul 19, 2010
    usb ports on my laptop do not work and I try to turn the corpse and try azap installed pc makes me Faile
USB port problem, need help or advice. My son has a Toshiba Satellite A305-S6916 laptop. It only has 3 USB Ports. It is a dual core 3.0. It has Two USB ports on the right side and one USB port on the
Hey! Thanks for using the forum! I will try to help you.
First off all what happends when you plug in a usb device? Let me kno, after that step i can help you further!
Max
Nov 06, 2014 | Computers & Internet
Usb not working
This could be a problem with your USB drivers. Check through the device manager to see if all the USB ports drivers are installed. If not, re-install the USB drivers. This will solve your problems.
May 19, 2013 | Dell Inspiron 1501 PC Notebook
My Dell Latitude D400 laptop's USB ports stopped working. They used to work fine, now they don't recognize anything (card readers, mouse, camera, etc.) I removed the USB port drivers and reinstalled. It...
USB port is corrupt...if all that you said is what is happening then the best is to
buy a keyboard to USB port convertor....
refer this image....Ebay has it for about 1$
May 10, 2010 | Dell Latitude D400 Notebook
USB port on laptop is not working
make sure the driver is installed
Jan 03, 2010 | Dell Inspiron 8600 Notebook
USB port kills usb
please format your pendrive or anything esle you connect through usb port.
Dec 06, 2009 | Toshiba Satellite A100-S8111TD Notebook
USB port
Hi-
Have you tried reformatting your laptop? chances are the USB drivers and ports is corrupted. try reformatting laptop or have ports USB check.
Hope this helps
Oct 10, 2008 | Compaq Evo N1000C Notebook
Mecer Laptop USB port not detecting
Reset the Bios.That solved the same problem i had.
Aug 30, 2008 | Computers & Internet
USB ports not working
Looks like it is a problem with those ports since you bought the computer.
Pls take it to a local tech to diagnose the problem or contact Acer Tech Support
Feb 13, 2008 | Acer Aspire 9503EWSMi Notebook
Usb ports
You'll want to verify your computer recognizes your usb ports.
In device manager, look to see that you don't have anything with an exclamation mark, question mark, or red X on it. Make sure you have the usb ports listed under Universal Serial Bus controllers. If nothing shows, your usb ports may be dead. Depends on the age of your computer and what might have happened to them.
Device manager- right-click My Computer and go to properties, then select the hardware tab.
Jan 28, 2008 | Acer TravelMate 2300 Notebook
Compaq Presario v2000 w/ dead USB ports
I have the same problem with my Compaq Presario V2000. Lost both USB ports and HP tells me that the motherboard has to be replaced at $300 +..I searched and found a PCMCIA card with two USB ports for $10. No problems with the USB ports on this card..great and cheap solution.
My belief is that the compaq usb ports do not have power limiting circuitry therefore allowing you to overload the output power on the ports. My ports failed after I downloaded into a burglar alarm system I was programming.
Oct 17, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
