Manual for ritetemp cooler 5051b - Heating & Cooling
I have a ritetemp 8082C, how do I open it to replace the batteries?
To replace the batteries in the Ritetemp 8082C thermostat, first switch the Mode switch to Off and the Fan switch to Auto (if they aren't currently in that state). Press up on the catch on the bottom of the thermostat and swing the body of the thermostat away from the back plate on the wall. The lift up to remove the body of the thermostat from the base. Turn the body of the thermostat over to see the battery compartment at the top of the back of the thermostat.
This is shown in the installation manual in different sections. Removing the body is shown on page 3 (page 4 of the PDF). Changing the batteries is shown on page 6 (page 7 of the PDF). Ritetemp has the manual here: http://www.ritetemp-thermostats.com/80XX/images/8082C_installation_guide.pdf .
I hope this helps.
Oct 28, 2017 | Heating & Cooling
Mastercool Adobe P550A portable water cooler. Where can I get a user manual?
try searching on line for a water dispenser manual rather than a water cooler manual
Jun 11, 2015 | Mastercool Heating & Cooling
Someone borrowed my Belmonte music stand and now the threads on the tightener on the vertical post and the two tighteners on the upper portion are all stripped - from being over-tightened. Fixable?
If plastic parts, replacement of the stripped parts would be only solution. Don't loan things to gorillas... Let the gorilla buy you new parts or a new stand.
Jul 29, 2011 | Belmonte 5051B Pro Music Stand
Ruud UBHC AC System - Provides no Aux Heat
Tried this on my unit today, and observed the same results, but got Aux Heat (with A setting), if the H (blue wire) connected to B terminal, as per instructions for my 6036 Ritetemp. However, in this case, when the set temp is reached, I hear the click, but HVAC still blows aux heat indefinitely.
I also have RUUD UBEA 17J10..., and replaced my old honeywell with 6036, and can't get heat pump working. Both of my units are 14 years old, so I'm thinking to replace them soon.
Jan 06, 2010 | Ruud UBHC Air Conditioner
Ritetemp 6022 programmation manuel Where can i
when the furance turns on it never shut off. how can I fix this.
Dec 08, 2009 | Heating & Cooling
Siemens vas 5051b inop problem on power supply pcb.
dead pc is easy to repair.
1) check its power supply and its cables connected to u.p.s.
2)If the front indicater leds are blinking or beep is there try replacing its ram modules.
3)If you know remove the back cover of your computer replace the entire power supply kit with similar wattage power suply.
May 01, 2009 | Computers & Internet
Furnace won't turn on....
jump out thermostat or try jumping out the pressure switch
Feb 23, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
422 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
