Question about Casio Music
When you turn on the wk 3000 the lcd reads pls wait after a few minutes it goes blank no sound no responce
  • Casio Master
  • 5,603 Answers
This ONLY applies if you have a floppy or hard drive in your unit...
SOME of these synths hang up during boot if the floppy or hard disk isn't recognized as working...
Also verify your power adapter is producing the right voltage and is the original.
Posted on Jul 20, 2010
Why is there no sound output?
Hi, I am answering this generically, because there are a few things that can cause this on a lot of keyboards.
  1. Make sure there are no headphones connected. I have removed headphones and the 3.5mm plug comes out leaving the adaptor, this still cuts the speakers.
  2. Sometimes the switch on the headphone socket does not make properly, work the headphone jack in and out a few times.
  3. Local MIDI should be set to ON, if you cannot find this, as it is often buried in some deep menu, link MIDI out to MIDI in with a cable.
  4. Do a reset, be careful as some restore factory defaults and you will lose user presets, so back up, MIDI dump first, others allow resets that do not affect the voices.
  5. connect to your usual software (sequencer, patch librarian, etc) and see if the keyboard has been muted, volume set to zero etc.
  6. Is the volume knob turned up?
All the best, Chris the fader.
Jun 27, 2015 | Music
Problem is after a few minutes i lose all sond comming from my speakers
Not likely a grounding problem. Run a test: Turn on unit with NO sound into the mics and wait 5 minutes... now try the mics. If they start working for a few minutes, then the amp is being overdriven. These small systems can be overheated and a thermal protector shuts them down to protect them. A hidden problem is if the mics are in front of the speakers you MIGHT have ultrasonic (above hearing range) feedback that may be overheating the unit. Put your speakers nearer the audience and mics behind. If problem persists, exercise your warranty.
Oct 21, 2012 | Harbinger HA120 Portable PA System
Yamaha Clavinova CLP-440
It sounds like you have a part overheating and failing, then cooling off and starting again. i would take it into the nearest Yamaha repair facility or contact your local authorized repair to come take a look before it goes out of warranty.
Mar 07, 2017 | Music
How to fix my amplifier head??
Flick your finger nail against the preamp tubes. This will tell you if any are microphonic which most likely the case. It usually takes a few minutes for them to begin squealing.
Jul 10, 2017 | Behringer Bugera 1990 Classic 120W Tube...
I have a casio keyboard WK 3000 and when it is powered up, the screen is frozen. When the keys are pressed, no sound comes after. Also when i try to shut the power off, it doesn't turn off. The only...
Make sure you use ONLY the correct adapter for power. Too small an adapter might cause it to light up but will not operate the unit. The correct adapter should say AD12 on it. It is a 2 volt, center pin minus, and probably 1 or 2 amps capability. Nine volt adapters used with pedals or universal adapters will NOT work with the WK3000.
Jun 26, 2011 | Music
Hi, i have a problem with my casio wk 210 keyboard. when i push a key then the note keeps playing and doesn't stop. i have tried turning off the power and turning off reverb and none of them fix the...
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
Jun 14, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Re: Casio WK-210. Audacity, Jet Audio and Ctrl Pnl allow me to choose a USB PnP "record from" option, however, no sound is being recorded from the Casio to the PC. What am I doing wrong. Many...
Pat, the USB output on the Casio WK-210 is only capable of sending and receiving MIDI information. It's not sending any digital or analog audio. Audacity is primarily for sound file editing.
In order to use the keyboard to record onto your computer you can connect an audio cable from the 1/8" stereo mini-jack to an input on your computer. Then you can record into Audacity.
Or you can acquire MIDI recording software (ie. Logic, Cubase) and then using the USB output on the keyboard, you can control and record multiple MIDI instruments in those programs.
Feb 23, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
My 150 w spider III looses power after on for 60minutes. no volume, all preset button lites go off, but preset names stay lit up. Goes off for a few seconds, comes on, goes off. Have to turn amp off and...
Sounds like a power supply problem. Likely have to go to a repair shop unless you are electronically capable.
I would expect either a cracked board or bad solder joint is causing the problem.
Oct 06, 2009 | Line 6 Spider Iii 120 Stereo Guitar Combo...
Does not fully poweer up
I had the same problem. You might try the keyboard on good fresh high quality batteries. If this solves the problem, buy another ac power adapter. Good luck!!
Dec 26, 2008 | Casio 76 Key Smartmedia Keyboard
Music Logo
201 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
