Question about Sherwood R-925
How-to reprogram eprom/microprocessor software ect.
I am Looking for the how-to on how to program the r-925 eprom/microprocessor so as to not have to reset the unit each time power is lost. The Software needed/wiring schematics of cable needed/ parts list. They shoulda slapped a rs-232 on the back for this purpose lol. I will hehe thanks in advance.
My alesis hr-16 has seveloped a software issue 02..what does that mean?
The software is on an EPROM chip inside.
It can go awry for a number of reasons, including a voltage surge via the earth, coming back from the amp
Always connect everything before powering up your system. If you disconnect to troubleshoot, power down before reconnecting.
Try this if you don't mind losing all your patterns:
Power off
Hold down "ERASE", "DELETE", and "RECORD" while you turn power on
This will clear all your memorized patterns & reinitialize the system.
If that doesn't work, the EPROM chip may need to be reprogrammed or replaced.
Oct 15, 2017 | Alesis Music
MY CYBEX TREADMILL KEEP CUTTING OFF AND ERROR CODE IS 95
This error is most common when a software error has occurred in the program. Usually replacing the EPROM fixes this. If not, then try the microprocessor.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Feb 24, 2015 | Exercise & Fitness
Cybex 625T
Most commonly this error code is caused when a software error has occurred in program. Start by replacing the EPROM. If this does not correct the issue, move on to the microprocessor.
Jul 10, 2014 | Exercise & Fitness
Error eepr problem
If it's Fluke DMM then - corrupt eprom in microprocessor - replace microprocessor or main board
next time put make and model of the unit - it makes it easier
Aug 26, 2013 | Measuring Tools & Sensors
Bios will not boot
I was going to advise "Try downloading and installing the Bios update from the manufacturer website. If the programming on the Bios EPROM was corrupted this should resolve the problem. " problem is even if you did this you wouldn't be able to install the update since there is nothing to tell the computer what devices it controls. Even a bad Bios battery will not cause this situation. You could try getting a replacement EPROM of the Bios from the manufacturer but I would either replace the motherboard or take it to a shop that might be able to reprogram the EPROM with the correct BIOS. I haven't priced an actual BIOS chip in a very long time but it should be relatively cheap.
Aug 08, 2010 | Computers & Internet
I louse BIOS. How I can restore it.
Try opening it and taking out the little coin battery from the moatherboard for about 20 sec or more..put it back in and see if this works first....if it doesnt im not sure you can ...but let me know if this helps!!!
Jun 15, 2010 | E-Machines T5082 PC Desktop
LG 20" memory problem
you will need your mainboard replaced eprom has fail
Nov 30, 2009 | LG 20LS7DC 20 in. LCD TV
GE 31GT660 picture is intensly WHITE
The GE (actually RCA) 31GT660 uses the CTC187 series chassis. This chassis is notorious for bad solder joints on the shields around the tuner and microprocessor. When the solder joints on the shields crack, the microprocessor and EPROM lose their ground and the EPROM's data becomes corrupt. The solder joints on the shields will all have to be resoldered and the EPROM reprogrammed or replaced by a qualified tech familiar with the 187 series chassis.
Aug 22, 2007 | GE 31GT660 TV
Sharp 32L-S400 Parental Programing
There are two ways to solve this problem 1 enter menu and remove old code and replace with new one, 2 reprogram eprom
Aug 01, 2007 | Sharp 32L-S400 32" TV
No settings memory,turns on by itself?
Sounds like your set has a bad eprom. This is the brain that stores all the settings and sends information to the microprocessor to make things happen. If you do not know how to replace it you should take it to a qualified tech to repair it.
Nov 12, 2005 | RCA T25061GY 25 in. Combo
48 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
