Question about Nextar X3-03 Car GPS Receiver
Reseting nextar gps - Nextar X3-03 Car GPS Receiver
    President:
  • 563 Answers
Press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully.
Posted on Aug 29, 2010
3 Suggested Answers
RPFinney
  • 385 Answers
SOURCE: How to reset gps
Hold the power button for 20 seconds plus, to reset it
or press the stylus in the reset hole.
Hope this helps.
Regards
Posted on Jun 22, 2009
issikiki
  • 563 Answers
SOURCE: I can not unfreeze my
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further
How do I update my Nextar x3-08 gps so the new roads will show up ?
visit Nextar.com to order your desired maps update and Check the overview description to see which SD card lists your GPS model number and serial number. Order the matching card.
Remove the existing SD card. This is usually found in a thin, rectangular slot on the side of the Nextar GPS.
Insert the SD card with the maps update into the empty SD card slot. Press until it clicks into place.
Reset the unit by pressing the "Reset" or pushing a pin into the "Reset" hole.
Click the "Navigation" button to have the maps automatically update on the GPS.
May 06, 2015 | Nextar X3-08 Car GPS Receiver
I want to reset my nextar gps passscode.
You simply need to locate the little reset button and press that for a few seconds, this will reset the unit back to factory fresh. Your user manual is below.
http://www.nextar.com/frontend/proddetail.asp?pn=X3-03&co=10000312
http://www.manualowl.com/p/Nextar/X3-03/Manual/28073
Jul 05, 2011 | Nextar X3-03 Car GPS Receiver
Need download drive for nextar x3-08
There is not a driver available to download for this gps. You may try a hard reset which involves pressing the reset button located on the back or bottom with the tip of a paperclip for ten seconds. Otherwise the hardware or software may be corrupted and you will either need to return the unit for exchange or repair to the retail location from which you purchased it or contack nextar customer service to see how they can help you.
Mar 10, 2011 | Nextar X3 GPS Receiver
Finding the reset hole on the nextar I4-Bc
PDF] I4-BC Hardware Manual.pdf 2345k - Adobe PDF - View as html Global Positioning System ("GPS") hardware, operating software or other aspects of this ... outlet again to reset the player. If the problems still exist, ...www.nextar.com/images/Product/I4-BC Hardware Manual.pdf
Aug 15, 2009 | Nextar I4-BC GPS Receiver
My gps is saying waiting for signal and just stands still. name brand is nextar x3t.
I HAVE A NEXTAR GPS SYSTEM AND IT KEEPS SAYING WAITING FOR A SIGNAL I RESET IT AND IT IS STILL DOING THE SAME THING.
Jul 15, 2009 | Nextar GPS
Gps lost sound, the voice is gone. nextar #p3 auto navigation sys
You should first try the reset procedure to see if this resolves the sound problem for you. To do this press the "Reset" button or push the stylus into the "Reset" hole.
For technical support for your Nextar GPS see http://www.nextar.com/frontend/support.asp or you can phone them on 888-849-0846
Please remember to rate my answer. Many thanks.
Jun 24, 2009 | Nextar X3-02 GPS Receiver
I have a new nextar gps serial #ml0809620266. I would like to update the maps. and I don,t understand the procedure I must do to do this.
update available here:
http://www.nextar.com/frontend/proddetail.asp?pn=PART-GPS-MAP09SDC2
Plug the new SD card in and reset the unit.
Jun 23, 2009 | Nextar X3-08 Car GPS Receiver
How to reset gps
Hope this helps.
Regards
Jun 21, 2009 | Nextar Q3 GPS Receiver
Restting nextar q4-4
resetting the Q4-04 , direct from Nextar FAQ's >
nextar q4-04 manuals and faq's
see if that works for you , straight from the manufacturer .
if you need more help , just ask .
J5
Jan 19, 2009 | Nextar Q4-04 Car GPS Receiver
Nextar X3B
let the batter die. then hold the reset button and plug it in at the same time. itll take a second but i loaded up for me after a couple seconds.
Nov 24, 2007 | Nextar X3B GPS Navigation System
Nextar X3-03 Car GPS Receiver Logo
107 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
