Question about Sanyo Cameras
Where do you put the battery to charge - Sanyo Cameras
  • kakima Jul 20, 2010
    What model? Some cameras come with a battery charger, some charge through the USB port. Without knowing the model in question, no one can answer your question.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sanyo Master
  • 102,366 Answers
Having received no response in over a month, I assume this is no longer a problem.
Posted on Sep 15, 2010
641 Ford Tractor late 50 vintage won't charge the battery. Rebuilt the generator it's putting out the right voltage. new battery. Put in 4 different voltage regulators none will charge the battery.
Charging voltage has to be greater than battery voltage. If so, it is reaching the battery? If so, the battery has to charge unless it is defective.
Jul 04, 2017 | Ford Cars & Trucks
1998 mercury grand battery not charging put new alternator still not working
Has the battery been checked to see if it is good?
An alternator cannot charge a bad battery
Dec 29, 2013 | Mercury Grand Marquis Cars & Trucks
Says to charge es20lbs battery before using but it says it is charged already
You need to put a new battery on charge for at least 24 hours to condition it. Putting the electrolyte in the battery will give it some charge, but it will need a full charge to give you a proper chance of the battery doing its' job properly. That is why it says on it to charge it.
Sep 15, 2013 | Motorcycles
Battery
Might be the camera's battery terminals, not the battery itself. Take a qtip and some isopropyl aclohol and clean the terminals in the battery well of camera.
Jul 23, 2013 | Nikon D3000 Digital Camera
WHY IS TI THAT THE BATTERY KEEPS LOOSING ITS CHARGE AND IT DOES NOT HOLD CHARGE?
put a volt meter on the battery,,,,it should read 12.6 before starting..and 14.25,,when running.....and 13.75 when you shut it down,,,,,if not its not charging...you need a good battery to turn on the regulator/alternator/stator/rotor to charge the battery,if its not 12.6 your dead in the water
May 05, 2013 | 2007 Vento Phantom R4i
I have a 2001 Dyna Low Rider, ever since I put it on the battery tender it just clicks when I try to start it, what could be the problem?
A Battery Tender will not charge a battery. They will maintain a "Charged" battery. Typically, if you put it on a low battery it will stay low of charge. Try cleaning the battery terminals and charge the battery, then turn the Battery Tender on.
Oct 24, 2012 | 2001 Harley Davidson FXDL Dyna Low Rider
The bike dies, after a fully charged battery.
Bike has magneito (thats spelled wrong ) On line youtube veido shows how to fix that.
Apr 01, 2012 | MBK Motorcycles
Starts good with a jump from other battery ,but when i take cables off my motorcycle then trunes off.
Battery and/or charging system is not good. Put charger on battery, bring to full charge, then put load tester on battery ensuring battery not weak or a dead cell. If battery is good, check charging system.
Apr 15, 2011 | 1991 Yamaha FZR 1000
I had replaced with a new battery and its just worked for one and form after next days it dont get charged.....the shopkeeper says the mobile is not getting charged.......
In case the battery is not getting charged. It can be due to 3 reasons
1. The power adapter through which you are tryiing to charge the battery is u/s Check with another adapter and see if its charging then the problem is with the charger else.
2. Take out the battery and put it on another phone and try to charge it. If it is charging then the problem is with the mobile charging point and not the battery. If not charging then the problem is with the battery only.
3. Mobile charging point is not working due to which the battery is not charging to check this out just put your battery on another phone and check if its charging. If charging then you are required to get your charging point on your mobile repaired.
Feb 04, 2011 | Motorola Mobility ROKR E8 Cellular Phone
Will not star or turn over.
CHECK BATTERY CABLES MAKE SURE THEY ARE NOT CORRODED AND LOOSE.ALSO CHECK BATTERY VOLTAGE.SHOULD BE 12.6 VOLTS IF NOT REPLACED BATTERY.BEFORE REMOVING NEGATIVE BATTERY CABLE TURN OF RADIO FIRST.AFTER INSTALLING NEW BATTERY.WITH ENGINE RUNNING CHECK ALTERNATOR OUT PUT AT BATTERY SHOULD BE 13.5 TO 14.5 VOLTS.DOING THIS WILL MAY SURE BATTERY GETTING GOOD CHARGE.2 REASON BATTERIES STOP WORKING.THEY FAIL FROM OLD AGE AND ALTERNATOR CHARGING SYSTEM NOT WORKING.IF BATTERY CABLES VERY OLD I WOULD REPLACE THEM.THAT WILL HELP BATTERY GET BETTER CHARGE.OLD BATTERY CABLES PUT A RESISTANCE ON CHARGING CIRCUIT CAUSE ALTERNATOR WORK HARDER TO KEEP BATTERY CHARGED WHICH WILL SHORTEN THE ALTERNATOR LIFE.
Jan 26, 2011 | 1999 Oldsmobile Alero
Cameras Logo
16 people viewed this question
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
