Question about Kenmore Dryers
Timer installation - Kenmore Dryers
  • capnned Jul 19, 2010
    No solution from first expert.
    There are a red, blue and black wire that I can't identify a terminal for.
    Can you help. Thanks
    No. I found my own answer but thanks anyway.
    Top Expert:
  • Kenmore Master
  • 77,499 Answers
How to Replace the Timer on a Kenmore Dryer Instructions Things You'll Need:
  • Phillips head screwdriver
  • Replacement Kenmore dryer timer
  1. Step 1 Unplug the Kenmore dryer from the wall outlet. Move the dryer away from the wall so that the control console can sit in the service position without hitting the wall.
  2. Step 2 Locate the screws that fasten the front of the control console to the top of the Kenmore dryer. There is one screw at each that may or may not be covered by decorative trim. Use a Phillips head screwdriver to remove the screws.
  3. Step 3 Use your fingers to pull the timer knob off the timer shaft.
  4. Step 4 Grab each end of the control console with your hands, lift the front up and turn the control console over into its service position. The control console will sit on its hinges while in this position.
  5. Step 5 Use your fingers to press in the plastic locking tabs that secure the wiring harness to the timer. Pull the wiring harness off the timer.
  6. Step 6 Use a Phillips head screwdriver to remove the screws that fasten the timer to the control console. Remove the timer from the Kenmore dryer, and take it with you to the appliance repair store. You should also have the model number of your Kenmore dryer with you as well. Make sure that the replacement timer matches the timer that came out of the dryer.
  7. Step 7 Align the new timer over the mounting holes in the control console. Secure the timer to the control console using the retaining screws. Connect the wiring harness to the new timer by pushing it into place until the locking tabs connect.
  8. Step 8 Pull the control console front back down to rest on the Kenmore dryer top. Fasten the front of the control console to the Kenmore dryer top using the retaining screws. Push the dryer back into its normal working position, and plug the dryer back into the dryer wall outlet.
Posted on Jul 19, 2010
  • 2 more comments
    Timer has been removed from dryer but need wiring directions. Have a red,blue and black wire I can't identify terminals for. Is the a color wiring diagram available.
    Many thanks.
  • yadayada
    yadayada Jul 19, 2010
    U asked for timer install instructions, that is what i gave you, i don't have the actual wiring diagram here at fixya.
  • yadayada
    Here is a web page with Maytag dryer wiring diagrams i was able to find, choose from the list provided on the right click the one that applies to see diagram
    http://fixitnow.com/appliantology/laundr...
  • yadayada
    I need the model number of the dryer, Kenmore doesn't make anything, they contract that to Whirlpool and Maytag and then re badge it for sales as a Kenmore.
    President:
  • 1,554 Answers
Please indicate the exact model number of the dryer for us to determine and outline for you the necessary steps in installing the timer. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with an expert as long as you need assistance regarding the issue stated herein.
  • Jahn27
    Jahn27 Jul 19, 2010
    There's no solution because an information was requested from you, the exact model number of the dryer. No expert can tell you directly which wire goes to which terminal without knowing what exactly is being wired.
    Gave this info previously but here it is again: Kenmore Dryer model #11067422600. Problem is can't identify terminal for black, red and blue wires. I think black wire is load but can't identify terminal.
    Can you help?
Intermatic e1010
Is this new timer installation, or older timer that stopped functioning?
1) Copy following link to help identify timer, download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#E1020
2) If this is new installation, then check wiring for single pole installation. This timer will not work for 3-way switching.
http://waterheatertimer.org/How-to-wire-timers.html
3) If timer worked before, and now clock motor has stopped working:
Turn power off, use compressed air to blow out timer, then see if you can spray highly flammable vapor from WD40 can into the motor.gears.
4) There are replacement trippers for this timer, but no replacement clock motors.
Buy another single-pole in-wall timer.
Dec 03, 2012 | Intermatic Hardware & Accessories
Installing the battery can't get the door opened to insert battery
Drawer pulls straight out. Use small screwdriver or metal nail file.
Copy following link for illustration and CR2 battery, and ez-to-follow programming, and wiring options.
http://waterheatertimer.org/images/ST01C-program.html#battery
Remember the drawer is also 'plugged' into the timer, so do not bend small metal prongs on drawer.
This timer comes with 1 year limited warranty against defects in workmanship.
The battery operates timer functions, so once battery is installed, the timer can be programmed before timer is installed in wall.
Be sure to reset timer before programming to eliminate stray code on the memory chip.
Once timer is programmed, the programs remain inside memory chip forever, even with power loss and no battery, until timer is reset of re-programmed.
Reset this timer: Hold down on-off button and momentarily push round reset button with paper clip. Keep holding down on-off until display changes, then release on-off button and begin setting current time and programs.
Nov 27, 2012 | Intermatic & Self-Adjusting Wall Switch...
How do I reset the intermatic EI400 light timer
Copy following link to identify Ei400 series programmable countdown timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#Ei200
Hold down ON/OFF button and fully press-and-release small round reset button using paper clip.
Keep holding ON/OFF button until display changes
This timer uses CR2 battery installed in tray below the buttons.
Reset timer after installing new battery.
If functionality is not restored after new battery install and reset, then timer has gone bad.
This timer has 1 year limited warranty through Intermatic for defects in workmanship.
Ei400 can be wired for single-pole or 3-way.
Timer requires no neutral wire since battery operates the timer and relay circuit
Nov 13, 2012 | Day-Timer Intermatic Ei600c Digital 7 Day...
No digital display, does that mean the battery is dead
You posted under Intermatic ST01C timer.
Display on this timer goes blank when new CR2 battery is needed and when timer has gone bad.
Many times when a new battery is installed, the timer has to be reset and then reprogrammed.
If timer cannot be reprogrammed after battery install, then timer has gone bad.
Open following links for ST01C resources: ez programming and reset instructions.
http://waterheatertimer.org/images/ST01C-battery-tray-0-400.jpg
http://waterheatertimer.org/ST01C-program.html
Jul 13, 2011 | Intermatic Inc. ST01C Digital In-Wall...
How do I set my timer
Question posted under photo of Raindrip timer:
Open following links for possible help identifying product and downloading manual:
http://raindrip.com/install-a-timer-or-controller/timer-installation
More water timer links
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
May 23, 2011 | Raindrip R673CT Digital Water Timer
Steps for timer R672C I can't remember....
Question posted under photo of Raindrip timer.
Open following link to identify timer and download possible manual
Apr 29, 2011 | Raindrip R673CT Digital Water Timer
Manual for defrost timer model# T000067709 a defferent timer was installed ,but now installing the right one need know the wiring for new timer
Hi, installing a defrost timer is not difficult if you know what the wires represent. Since you don't have a manual and you are removing the timer that was put on in place of the original one, I would call the manufacturer of the freezer for help on this. If you mis-wire it, you can burn the motor for the timer out. The freezer it self should have a schematic diagram pasted on it showing the wiring for the defrost timer? Check on it and see. Keep me posted and I will continue to look for one.
Sincerely,
Shastalaker7
Mar 16, 2010 | Randell 10.7 cu. ft. / 303 liter Chest...
Cannot get the timer switch to function w/ 3-way Levitron NOM 057
When installing a digital timer switch into a 3-way lighting circuit, you typically have to install a jumper wire across the "travelers" on the 3-way switch at the other end of the circuit, in order to get the timer to function.
If you have an Intermatic brand timer, the jumper is included with the timer switch, usually it will be a small, about 2-3 inches long wire with fork terminals on each end.
You should have the power turned off before installing the jumper. Also, there is a distance limit (75-80 feet of wiring) as to how far apart the two (2) switches can be from one another, in order for the timer to work (with the installed jumper).
Normally, the travelers are one the same side of a 3-way switch, but you can use a voltage detector to confirm which wires are which (prior to turning off the power) to make installing the jumper easier. If you contact the manufacturer of your particular timer, they can email you a owners guide/installation pamphlet that shows the proper installation procedures for your timer switch.
If you have an Intermatic product, you can use the link below to contact them for the needed info.
http://www.intermatic.com/products/timers.aspx
Hope you find this Very Helpful and best regards!
Sep 07, 2009 | Intermatic Hardware & Accessories
Wiring with another 3-way switch, works when other 3-way switch is on, clicks on/off when other 3 way switch is off
When installing a digital timer switch into a 3-way lighting circuit, you typically have to install a jumper wire across the "travelers" on the 3-way switch at the other end of the circuit, in order to get the timer to function properly, otherwise the switch operates erratically, as you've experienced
With an Intermatic brand timer, the jumper is included with the timer switch, usually it will be a small, about 2-3 inches long wire with fork terminals on each end.
If want, you can use the link below to contact Intermatic to get a spare users guide for your particular timer.
Sep 06, 2009 | Intermatic Inc. ST01C Digital In-Wall...
Dryers Logo
117 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
