Question about Pitco Frialator SG14 Deep Fryer
Pitco fryer i have a pitco fryer it just started to bubble kinda like foam on the eges even tho nothing is in the fryer i turn it off and it turns off but it still seems like something is cooking under the oil??
  • Pitco Frialator Expert
  • 684 Answers
Try removing the oil and boil out the fry tank.
Fryer cleaning manual is downloadable on PITCO site at http://www.middleby.com
Posted on Jun 06, 2011
How do i turn up the temperature on my pitco frilator
Hi there!
You can download owner's manual with programming guide for Pitco Frialator at www.pitco.com
Regards.
Feb 02, 2013 | Pitco Frialator SG18S Deep Fryer
I have a Pitco Frialator 35CS Deep fryer that is leaking natural gas leak inside gas fryer door just above gas valve assembly the leak is bubbling through each of the 3 flues above the gas valve any help...
Opening fryer door during operation does not correct gas leak problem.
If there is gas leak on your fryer's system, you have to fix the leak or replace parts if necessary.
You can download parts, operation and owner's manual at pitco web on http://www.middleby.com
Regards.
Jan 16, 2011 | Pitco Frialator 35CS Deep Fryer
I have a pitco deep fryer sg16. the problem is the pilot turn but when i try to turn the knob to turn it up, it's not starting and i hear a 'click' and then the pilot turn off . please help...
I think that the gas valve is defective and needs replacement. Visit http://www.middleby.com and go to PITCO web, you will be able to locate there the nearest authorized parts and service dealer in case you need parts and service.
Apr 05, 2010 | Pitco Frialator SG14 Deep Fryer
The fryer is a pitco 35cs can u tell me y it heats up to 550 and shuts the pilot down
It shuts down because it is tripping the high limit. Apply a soap solution to the lines going from the gas valve to the thermostat. If bubbles appear there is a leak and needs to be corrected. If no bubbles appear then the thermostat is probably your problem.
Feb 24, 2010 | Pitco Frialator 35CS Deep Fryer
Fryer heats up to 550 degrees and shuts down pilot and triggers the reset button which thermostat is it the operating on or the high end on i have already replaced the gas valve
Either the thermostat is bad or there is a gas leak between the gas valve and the thermostat. Use a soap solution and apply it to the 1/4" gas lines between the thermostat and gas valve. If bubbles appear then you need to fix the gas leak. If no bubbles appear then set the gas valve to the pilot position, remove the gas line marked "out" (the left one) from the gas valve. Turn the gas valve to on. The burners should turn on. Place you finger over the hole where the disconnected line was and the burners should turn off within 10 -15 seconds. If this happens then the thermostat is your problem.
When placng seafood in fryer at work a foam quickly forms and rises to the top of the fryer. What's causing this and how can I change this?
The seafood contains water, the water reacts with the oil and causes the bubbling.
Try placing the seafood onto some absorbent paper for a few minutes before adding it to the fryer.
Or try dunking it in to seal it for a few seconds before you fry it off
Jul 20, 2009 | Pitco Frialator 45C Deep Fryer
Fryer is taking to long to filter oil
make sure the pipe connections are tight and in place..check for clog!
Dec 06, 2008 | Pitco Frialator SG18S Deep Fryer
Wiring diagrammed of Pitco model 7-2wkss
Sorry to break this to you but all pitco fryer model numbers start with an S, please make sure what manufacture this fryer is made by.
Thank You
Jul 12, 2008 | Pitco Frialator SG14 Deep Fryer
Fryer maybe leaking propane
Hello
To see if this is leaking you can make a soap solution of 1 tablespoon of dishwashing soap to 1 cup of water to see if it bubbles. Just apply it around the knob on the gas valve or pilot valve.If it bubbles it is leaking and will need replaced. This will rule out a draft of air coming from somewhere else.
Hope this helps
May 31, 2008 | Pitco Frialator Kitchen Appliances -...
Pitco Frialator SG14 Deep Fryer Logo
321 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
