Question about Panasonic PT-47WX49 47" Rear Projection Television
Turns off by itself is old, Sept 1996. Pt-46G40U
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC.
If this is the case the power LED should be blinking 3 times when trying to power the set up.
You should be able to get a local service center to repair this at
your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and
heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old
heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center
circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews
Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their
phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the
phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a
good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this
information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Posted on Jul 26, 2010
Panasonic PT-51G50CU
HEY !!
ITS A CIRCUIT BOARD PROBLEM ... IC MAY HAVE BLOWN OFF ...
Jan 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
I have a 2007 PT Cruiser. I replaced a dead battery in July. Same problem in Sept. Again same problem in last week in Nov. Local Midas has been wonderful, replacing 2 batteries for free thanks to...
You need to have the charging system checked. It may be overcharging the battery which would destroy any battery. I would suspect the voltage regulator is defective.
Nov 20, 2010 | 2007 Chrysler PT Cruiser Touring Hatchback
PANASONIC PT-46G40U CONVERGENCE PROBLEM HELP...
Have you checked the bias resistors for Exact Value. They normally change value when the stk's take a dive.
Dec 09, 2009 | Panasonic PT-46G40 46 in. Rear Projection...
I have a 96 T100 and I would like to know how to test the Brake Power Booster
if the brake pedal gets hard then the bosster is defective, u may also hear a hissing noise from under the dash.
Nov 12, 2009 | 1996 Toyota T100
Telescoping steering wheel
its old and most likely needs some kind of lubrication
Nov 28, 2017 | 1996 Lexus LS 400
Color shift
There is going to be 2 ICs. Both should be replaced at the same time.
May 12, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Pt 56tw53 picture trouble
I had the same problem with my TV, It seems the high voltage trasnformer blew which in turn casued the pin cushion?? to blow. It then shuts the tv off to prevent more damage to it. $500 with service charges to get it fixed!
Nov 05, 2005 | Panasonic PT-56TW53 56" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
