Question about Samsung HL-R6167W TV
Hl67a510j1f- clicking noise and tv would take longer and longer for picture to come up.now picture is gone all together
Probable cap problem on the power supply
Posted on Jul 19, 2010
Hi I have a sony kp-53HS10 TV. When i turn it on it use to make a clicking noise and than the tv would turn on, but now the clicking noise is gone and nothing comes on. A red light under the tv stays on....
Sounds like a Power Board / Video Board issue - stand by power is still ok - and why you have a red light - but the set is unable to power up the panel to drive a picture. Or the video board is the issue an is no longer processing the image to your panel. Based on the clicking noise - I lean towards the power board as the issue.
Dec 21, 2017 | Sony KP-53HS10 TV
Tv making loud buzzing noise
A common cause are failure of decopling capacitors in the audio section, and or the circuit board power distribution that feeds the audio board. Most of the capacitors are surface mount components. The standard fix is to start by changing the circuit boards that have the defective parts.
If the set is under warranty, call for warranty service. Out of warranty service is expensive for these TV sets.
Jerry G.
Jun 12, 2012 | LG 32LG30 32 in. LCD HDTV
While we were watching Sony KF60WE610 TV suddenly a loud noise came from the back of the TV,. Sound and picture were gone, and the red light started blinking. We waited 2 minutes and turn on the TV . Sound...
Tv now,have a LED light indication "LAMP" on the frame are blinking or flashing.Metallic sound are clicking noises?Yes,sound like the board that call the Ballast board it is dead.This Ballast board only job are to ignite the tv projection lamp only.U have some mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Partstore.com,Ebay.com to buy a new Ballast board for the replacement.The tv projection lamp might have to be replacement change too,because,when the Ballast board has died and exploded the voltages and current high voltages could have more than the tv projection lamp now could take.
Jul 21, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
Replaced the lamp bulb on my samsung HLP5663. It went on right away. Though the problem was fixed. Turned the tv on a little while ago and the picture is gone. The timer light is blinking. Any ideas what's...
Now tv turn on.Hear alots of clicking or squiling,loud motor noises turn on?Alot of clicking,the Ballast board it dead,this board help ignite the projection lamp.Tv also have a colors wheels.The colors wheel is dead,if hear squiling noises,loud motor noises.
Jul 14, 2010 | Samsung DLP HL-P5663W 56" TV
My tv has no picture but has sound whats wrong?
Steady scrapping sound like a bad bearing is color wheel gone bad. Buzzing sound every 15 seconds is lamp bad.
Apr 18, 2010 | Mitsubishi WD-Y57 57" Projection HDTV
Sound but no picture
Hi
From the information you have provided the problem is with the convergence. If you have gone into the menu after the TV has been on for an hour or more and tried adjusting the focus/conversion and the focus did not correct the problem the convergence ICs have failed and will need to be replaced along with a few defective resistors. If all the colors are incorrect a open fuse in the voltage supply to the amplifiers is possible.Convergence failure is a very common problem with this TV set. There could be other parts that are not within factory specs. The only way to be positive of the problem is to have the circuitry diagnosed by someone with the proper TV test equipment to determine what parts that are no longer within specs. A small TV repair shop will many times be less expensive than a large repair facility.
Please revert for further clarifications.
A Fixya Rating would be appreciated if you have found this information useful .
Thanks
Rylee
Feb 13, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Sharp LC-32GD9E
Is this TV connected to a digital box or directly to an antenna? If its connected to a box then suspect the box first. If the box has been swapped with another one and still does the same thing, then the TV has a bad tuner and/or digital board. The tuner in most TV's is part of the digital board and must be replaced together.
Jun 09, 2008 | Sharp Televison & Video
NO PICTURE JUST A HORIBLE CLICK/WHINE
Hi,possibly the line output transister has gone short,proberbly caused by a dry joint,or worst case it is the line out put transformer itself and that could be a bit pricey to replace.
Apr 15, 2008 | Beko 324250WN 28" TV
Samsung HL-R6167W TV Logo
85 people viewed this question
Henry  Thomas
Henry Thomas
