Question about Bosch 24 in. SMU70 Built-in Dishwasher
The dishwasher will not move from wash cycle ...has run for 2 to the rince cycle4 hrs will not drain or move to the rince cycle
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems to be an issue with the timer that has gone bad, they don’t often fail but if everything else is working fine then it is the Timer that has gone bad and needs to be replaced. If the timer appears to be working fine then the issue is with the heating element which is not heating up water and as the water is unable to reach a higher temperature the unit stops at heating cycle i.e. rinse... To resolve this issue you’ll have to repair the heating system problem. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 19, 2010
White powder remains on the dishes after washing
Sound like over detergent or washer is not graining properly
adds to bad rince cycling of same water it washed with
Check drain if installed right may be back draining
Jul 20, 2015 | LG Dishwashers
During what cylce does the soap door open? the spring had broken and the door wouldn't open. i've replaced the spring and i'm questioning if i've put the assembly back together properly
1s it fills with water to rince off any food or anything else on te dishes then it refills , with the wash cycle then the soap door opens , then it drains once moreand refills to rince thendrains again
Nov 26, 2010 | Whirlpool 24 in. DP840D Free-standing...
The cold water keeps running in the rinse cycle. it nrver fills up it drains out as it flows in
you kind of lost me with that one, but the washer should spray in cold water when in the rince cycle , spining , draining, and spray of cold water. Thats a normal rince.
Dec 12, 2009 | Whirlpool LSQ9600L Top Load Washer
Our dishwasher continues to run for way to long.
mine is the same,i find a 45deg cycle is a lot shorter and washes just as good
Nov 03, 2009 | Washing Machines
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Won't drain, as clogged with lint
check the pump for possible obstructions
May 10, 2008 | GE WJSE3110A Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Machine blocks at rince cycle
running empty or full makes no difference. problem may be not draining to test this, put some water in appliance from a jug then start the cycle. (first action is to drain) see if water disappears. get back to me if you wish
Apr 02, 2007 | Siemens WXLP1460 Front Load
Dishwashers Logo
49 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
