Had a paper jam, removed paper and printer now says system error paper jam remove paper then push start there is no more paper in the printer and pressing start doesn,t help neither does opening the printer
  • corny677 Apr 25, 2008
    1. I try to print somthing
    2. It doesn't want to print
    3. It keeps making these wierd noices
    4. I look at the little screen, it says - clear paper jam, then try to print...
    5. I open the top thingy, I take out the little paper stuck in there (when there actually was somthing stuck), close it again.
    6. I try to print again., but it keeps saying the same things over and over and over again.
    Scholar:
  • 103 Answers
Usually this is caused by breaking a paper path sensor when the paper jam is removed. If you are lucky and you did not do any damage then it may also be caused by some bits of paper that are stuck in the sensor that sees the "Paper". If this is the case, simply cleaning it out real good might fix it. Good Luck!
Posted on Apr 22, 2008
Paper got jammed. Removed. Still says paper jam, but I can't see any. What should I do next?
Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam,+but+there+is+not...
iFixitThere is no paper jammed anywhere! each time I would finish with the steps and ... I have to turn off and turn on the printer to get it going again. ... and the grinding sound and the paper jam message still comes up. i am going to try .... well no luck Iremoved ink and they are not dry - new- and now it says paper jam and not so ...
Fixing Brother Printer "Paper Jam" Error with No ... - YouTube
? 1:54
https://www.youtube.com/watch?v=SqWNFVIR6JA
May 30, 2014 - Uploaded by Refresh Cartridges
Fixing Brother Printer "Paper Jam" Error with No Paper Jammed.... problem occurred again. i try this many times but the problem is still in there. ... There was paper jam front rear on my brother j450dw that wasn't going away, that was ... How to remove jammed paper HP LaserJet Professional P1102 Printer ...
How to fix a printer paper jam. - Computer Hope
Dec 03, 2015 | Office Equipment & Supplies
My printer keeps telling me that i have a system error. Remover paper jam then press start but nothing happens. Help
Where does this "system error" message appear? On your printer display or on your computer screen? Try to remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reinsert the cartridges. Then load some paper. Try to print again and see if the error appears again.
May 05, 2011 | Lexmark X125M All-In-One Printer
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
Oct 14, 2010 | HP Photosmart C7250 All-In-One Thermal...
Paper error showing. I pulled out paper jam and none showing, yet cannot get it to print
When the Printing job initiated, the pages will print slowly and we cannot pull the paper from the printer. That will lead to the paper push becomes inactive.
Thnigs to do for rectifify the problem :
01. Please remove the toner / cartridge from the Printer..
02. Please remove the jammed sheets from the roller.
03. If any other opening available in the printer, that also can be opened.
04. Please try to pull out all loose sheets available in the printer.
05. Clean the roller with good cloth and remove all dusts from the printer.
06. Install the papers in the In Tray properly.
07. Reboot the system along with the Printer.
The above points will solve your paper jam problem in the printer.
Have a Nice day
Jul 17, 2009 | Office Equipment & Supplies
PAPER JAM ERROR 201.02
if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
Mar 20, 2009 | Lexmark T640 Laser Printer
Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Jan 03, 2009 | Dell 3100cn Laser Printer
Paper jam
Remove the paper following the procedure below.
(1) Load a single sheet of the same paper in the Auto Sheet Feeder in portrait orientation.
Do not load it in the landscape orientation.
(2) Turn off the machine.
(3) Turn on the machine.
The paper is fed and then pushes out the jammed paper as it ejects.
If you cannot remove the jammed paper or the paper jam error continues after removing the paper, contact your Canon Service representative.
James Mac
Sep 09, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Paper Jam but not really???
If it's a brand new printer, try removing and reinstalling the printhead. An incorrectly installed printhead will give you a false paper jam error.
Jul 05, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Print cartridge is stalled
this will need to be taken to the service center for servicing.NO easy aasy to solve this problem
Jun 08, 2007 | HP PSC 2410 All-In-One InkJet Printer
Printer jam
There is an easy fix for Lexmark E232 paper jams at the beginning of the paper path. This fix only works when the problem is that the paper starts to feed, but does not quite make it out of the paper tray.
The problem is the pickup paper rollers. If you remove the paper tray and press down on the paper indicator (the red lever to the left of the paper tray) you can see the twin rollers attached to a spring loaded armature.
Chances are these rollers are worn and are very smooth to the touch. This slick smooth surface does not have enough friction to push the paper up to the next roller.
To fix this, remove both rollers, they slide off easily. Then simply turn both rollers inside out and replace them on the armature. Notice how much "stickier" they feel now? Chances are your paper jam problems are over, until the rollers wear out again.
At that point you will have to replace them.
Mar 30, 2007 | Lexmark E232 Laser Printer
194 people viewed this question
jasbo
jasbo
