Question about Cobra 29 LTD CB Radio
Fuse keeps blowing when turning on power - Cobra 29 LTD CB Radio
    Champion:
  • 219 Answers
When it does this voltage was hooked up backwards you will have to change the resistor.Don't try it again or you'll mess up the radio worst. The more you change the fuses the more it will mess up in the radio since you alwayed blew the resistor next to go will be your voltage regulator then the IC chip and so on.
Posted on Jul 20, 2010
Brack lights wont light up on my 1988 ford ranger we keep blowing fuse and put in new brake switch
If you keep blowing the brake fuse than you have a short in the system. Unplug the brake switch. Install a new fuse. If it did not blow than the problem is after the brake switch. Next unplug the turn signal switch, then plug the stop light switch back in and press the brake pedal. Did the fuse blow. If not than the wiring is good in between the two switches. With the turn signal switch disconnected use a jumper wire in between the light green wire (power from the brake switch) and the orange with light blue wire (power to the right brake lamp). If the fuse blows than there is a short in the right side brake circuit between the plug in and the rear socket assembly. If the fuse does not blow than jump from the light green wire to the Light green with orange wire (power to the left brake lamp). If the fuse blows than the problem is in the left hand brake wiring circuit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 04, 2013 | Cars & Trucks
Power Windows and Turn Signals Not Working - 15A Fuse keeps blowing
If a fuse keeps on blowing there is a short in the wireing to that circut, Your best bet is to take it into a auto electric shop to be check out,
Nov 28, 2012 | 2005 Subaru Impreza 2.5
Fuse keeps blowing up as power is turned on..help.
Greg, If the fuse keeps on blowing there is a problem with the internal amp. It was probaly caused buy a electrical power surge, Or a (********) up Sub patch cord,
Oct 04, 2012 | Athena AS-P4000 Subwoofer
1987 Chevy silverado gauge / idle fuse keeps blowing
The 20amp ga/idle fuse powers a hot fuel module which powers the oil pressure switch, the fuel pump relay, and the fuel gauge in the tank.
Any of the four components including the fuel pump can blow the fuse.
Jul 23, 2012 | Chevrolet Cars & Trucks
2001 mustang v6 automatic convertible keeps blowing fuse #10 (park, tail lamps)
The fuse doesn't blow till you turn on the light switch? If it blows before turning on light switch, look for a short to ground between fuse box and light switch.
If it blows after turning on light switch, I believe they make a short finder tool.
Jan 15, 2018 | 2001 Ford Mustang
Ignition fuse keeps blowing when i turn the key
It MUST be the starter relay coil - or the power wire that feeds it. Likely a short in the relay coil (AKA starter selenoid).
Sep 15, 2009 | 2003 Saturn L-Series
My tv keeps blowing a fuse when I turn on set.
DO NOT keep feeding it fuses more damage can accur-check rectifiers in power supply-then check regulator-chech H.O.transistor.if you need more help im gonna need a model number to go furthor
Sep 04, 2009 | Televison & Video
Engine 1 fuse keeps blowing when you turn the key
sounds as if you have a power shortage in the van. first establish what fuse keeps blowing this will help in narrowing down the short.once short is located check all connections ,wires,and plugs.
Jul 12, 2009 | 1999 Chevrolet Express
No parking lights, fuse keeps blowing.
There is a ground not connected or a wire open that is causing it to blow
Mar 08, 2009 | 1999 Pontiac Montana
Have a kenwood kac849 600w amp keep blowing fuse on amp as soon as power is too it power wire got wet and now this can i bypass that fuse some how
It would be very dangerous to bypass a fuse. If it keeps blowing, bypassing the fuse will only create lots of internal damage and maybe a fire as well. The fuse is blowing for a reason, the amplifier is not going to somehow start working because you bypassed the fuse. You also need to stop trying to turn it on, every time it blows the fuse, it keeps stressing the components inside. You have a shorted power supply, probably water damage as well since the power wire got wet.
I repair car amplifiers for a living, and can tell you with all honesty that bypassing the fuse would be a terrible mistake to make, the amplifier would end up being un-fixable with holes burned right into the board.
Please, just take it in for service or get a new amplifier. That is the only sensible thing to do. The amp will not start working bypassing the fuse, it will only start smoking.
Jul 10, 2008 | Kenwood Car Audio & Video
Cobra 29 LTD CB Radio Logo
100 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
