Question about Phase Linear PCD120U CD Player
How do I set the clock on my phase linear PCD120U car radio
2 Suggested Answers
SOURCE: Jensen Phase Linear car radio
Take off the face plate and it is located in the lower left corner
Posted on Mar 31, 2008
SETTING CLOCK ON JENSEN PHASE PCD120U
Display Selector (DSP)
This unit can display either the clock time or
radio frequency/CD player functions. Ordinarily,
the radio frequency or CD player track
indication is displayed, but the unit will display
the time when the DSP button (18) is pressed.
The time will display for approximately 5
seconds then return to the radio or CD player
function display. The correct time-of-day can be
set by pressing and holding the DSP button.
Setting the Clock
To set the clock, perform the following steps:
1. Turn the vehicle ignition and radio on.
2. Press and hold the DSP button (18) until
the time display flashes.
3. Within 5 seconds, turn the MULTI/JOG
control (3) clockwise to adjust the minutes
to the desired setting.
4. Turn the MULTI/JOG control counterclockwise
to adjust the hour and the “AM”/
Jan 28, 2010 | Vehicle Parts & Accessories
I want to install a unit into my work truck
go to a reputable stereo store and buy the wire harness connector for your truck to universal and one from universal to your stereo; also buy an installation kit for your model truck, (this will contain all the plastics necessary to fit the stereo to your dashboard),these usually contain several configurations for different vehicles so follow the instructions carefully. these may seem rather daunting at first, but if you fermiliarise yourself with all parts/instructions before starting it shouldn't be too hard or take too long; good luck
Nov 14, 2009 | Phase Linear PCD120U CD Player
No cd audio from my phase linear uv8
It sounds like you have a factory amp in the vehicle. Check behind the radio to see if you have the blue wire from the deck hooked up to anything. You probably do. So take the blue with white stripe wire coming from the deck and hook that up instead of the solid blue wire.
Jan 20, 2009 | Phase Linear UDV9010 Car DVD Player
My Phase Linear UV8 and my Ipod
I wasn't able to find the manual for your Head unit. But, if you have jlink capability with your UV8 and you have an ipod jlink cable, you should just be able to plug the cable in. Then hook up your ipod and the head unit should recognize it when you try to select "ipod" for your source. I wish I could offer more info but like I said I wasn't able to see the manual and I am basing my answer off of what it takes for Kenwood headunits which use a similar "bus" type cable like your jlink. I hope I could help. Let me know if you need furthur assistance. I would happily help.
-Andrew Hawkins
Nov 24, 2008 | Phase Linear PCD120U CD Player
Mar 17, 2008 | Phase Linear 160W AM/FM/CD Receiver W/...
Reset button location
If you cant find the reset button on the front of the radio you can either pull the plug out of the back for about 5 to 10 seconds or just pull the fuse that controll the constant wire of the radio. NOT the one that is in the fuse box on the inside of the car but the one under the hood for about 5 to 10 secs. Or undo the negative Battery terminal of the car battery for 5 to 10 secs.
Good Luck
Dec 15, 2007 | Phase Linear PCD120U CD Player
Setting the clok
I hope this helps as there were no other instructions avaiable for that model. If this is no good, I will try harder to get the exact manual.
Oct 30, 2007 | Phase Linear UDV9010 Car DVD Player
PCD120U volume issue
i think I know what your problem is ... if you hold down the menu/select button ( the button between the volume buttons) there will be a volume option it'll say P --- volume. I think that sets a default volume that the cd player will always reset to once the cd player is turned off then on again.
Jun 02, 2007 | Phase Linear PCD120UCS CD Player/Receiver...
Phase Linear PCD120U CD Player Logo
78 people viewed this question
Top Phase Linear Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
