Question about Whirlpool Duet GHW9150P Front Load Washer
I have a Duet Whirlpool washer and it is throwing a F35 code can you help me
  • gladtu Jul 19, 2010
    I will try this and return a comment
  • 10,515 Answers
This indicate that there is a Problem with Pressure Switch.On Most of the Whirlpool Washer's ( Duet ), if you Open the top panel, then there would be 3 Screws. After that you would have an access to Pressure Switch.With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after doing this, you will likely need to replace the pressure switch.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 19, 2010
ghappliances
  • 126 Answers
SOURCE: Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
Posted on Sep 15, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
  • 4 Answers
SOURCE: duet washer with f35 code
unplug it from the wall and let stand for 5 mins - sortof like rebooting the pc
Plug back in and reset the dial to whatever you require
Posted on Mar 24, 2009
SOURCE: whirpool duet washer - error code f35. shuts off
Hi, I did the procedure stated above and don't know if it solved the problem with the F35 error yet but I'm pretty sure it will. But, I did find a nail in the trap! I'm sure that was causing the error. However, I wish I had known that water was going to pour out of the trap. I didn't use the washer last so maybe it didn't drain properly and I should have ran it on the spin & drain cycle before cleaning the trap? Anyway, just a heads up to other people attempting this procedure. If there is a way to avoid the water running all over your floor, do that before opening the trap to clean it. Thanks for the solution, mstechwizard!!
Posted on Jul 28, 2010
marka19
  • 1430 Answers
SOURCE: whirlpool duet washer troubleshooting: What does
This indicates that the pressure switch or also called the analog pressure sensor has failed. First you will need to remove the top lid. Usually 2 or 3 screws on the back and the top comes right off. The pressure switch has a clear hose and a clump of wires going to it. Then unplug the hose and blow thru it it should be clear. Check the hose for leaks or obstructions. Also in the back of the washer on the left hand side is a air dome this is where it gets it pressure reading from, make sure it is not obstructed. If all is clear the pressure switch will need to be replaced. Here is a link to help with accessing the pressure switch also if you need diagrams or illustrations of your particular model.
Posted on Sep 20, 2010
I have a Whirlpool Duet Washer, washer starts and then stops code F35
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Nov 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam WFW9600TW00 code F35
Kevin
Oct 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code f35 and sud on washer machine/whirlpool duet front loader
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
May 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am getting a code F35 mid cycle,have to unplug washer to reset...any help?
F35ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked
Whirlpool Duet Washer Fault Codes
Dec 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer with f35 code
Mar 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sep 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
27 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
