Question about LG WM-1832C Front Load Washer
Spin cycle noise. no longer sounds smooth
During the spin cycle the machine has gotten louder and sounds like the bearings are wearing out? even when you spin the tub with no clothes in it when off it sounds like that. the overall sound of the machine is alot louder. are there rollers/bearings in there that can be changed by the owner. where can you buy the parts and how easy is it to do .
  • 1,543 Answers
The rear half of the outer wash drum (which contains the rear bearing and tub shaft seal) needs to be replaced. On a 1 - 10 scale, this rates a difficulty rating of about an 8. An experienced appliance tech can do it in about 2 hours, and hit you up for about $500. I do not suggest this as a do it yourself repair. Did you know that the new LG machines use a balance ring to make them much smoother running? (Hint: It may be wiser to replace the machine.)
You can find a service provider, to do the repair or just get parts here:
http://www.lg.com/us/support/repair/support-repair-provider-lookup.jsp
Posted on Jul 19, 2010
Noisy during spin cycle
Yes that is definitely bearing noise you here.
Jun 21, 2017 | LG Washing Machines
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Oct 22, 2014 | Washing Machines
During spin cycle washer is making loud noise
If it is making a sound like a loud rumbling sound similar to a jet plane taking off, it probally due to the seal has failed causing water to leak into the bearings. The bearings begin to rust, and no longer round and the noise gets progressively louder. It can be rather expensive to fix. Get a few estimates before deciding whether it is worth fixing.
Aug 30, 2010 | Maytag Neptune MAH6500A Front Load Washer
The washing machine started making a grinding noise during wash cycle (minor) and a much louder grinding noise during the spin cycle. Is this a bearing? and is it replacable? Maytag MAV7600
sounds like a bearing... although it could be the water pump... water pump is an easy fix... bearing is not an easy fix... take the belt off the bottom of the pump (under the machine) and see if it spins freely by turning it w/ your hand... or if it seems really stiff... if it looks good then it's def. your bearing...
Jan 15, 2010 | Maytag MAV7600 Top Load Washer
When spinning it seems the washer is getting louder and louder during the spin cycle. It is a very steady noise no grinding to it. Maybe a bearing?
make sure heavy items are evenly distributed in the barrel. if to loud , stop the machin by openning the lid and make sure the weight is evenly distributed. never just throw laundry in , place it so wieght is evenly placed around.
Jun 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Loud spin cycle
OTHER THEN CHECKING THE WATER PUMP I THINK YOUR RIGHT THE BEARING ARE GOING,IT WILL WORK FINE TILL THEY LOCKUP THEN THE BELT WILL BURN OFF,BUT I WOULD CHECK THE WATER PUMP ALOT OF TIMES IT JUST THAT,LET ME KNOW -MIKE
Nov 03, 2008 | Frigidaire FTF530ES
Loud Noise
okay If these efforts fail, Next, test the timer motor, inspect the pump for blockage (see below), test the machine motor.the sound during spin cycle may be due to gears on the motor shaft wobble, the bearings may be worn out or some of the moving parts may be misaligned.
its a sign that the motor, the rotor, stator, or brushes may be worn .or the motor is overheating and may require lubrication, the motor's windings may be wearing out
If the motor is too hot to touch, something may be blocking ventilation around the motor.
the , bearings may be worn out
Inspect the water pump for a blockage
Inspect the coupling
Inspect the transmission
Adjust the drive belt tension
Check the motor bearings
Check the drum brakes .
Sep 09, 2008 | Maytag MAH6500 Neptune Front Loading...
Front Loading Washer LOUD NOISE
IF IT ROARS LIKE A JET PLANE TAKING OFF, THE SPIN BEARING IS FAILING. PROBABLY, THE REAR SEAL HAS FAILED ALLOWING WATER TO GET INTO THE BEARING.
THE BEARING HAS LOST ITS LUBRICATION SO IT IS GETTING DRY. IT WILL CONTINUE TO GET LOUDER AND LOUDER THE LONGER REPAIRS ARE PUT OFF.
THE ENTIRE BACK HALF OF THE OUTER TUB WILL HAVE TO BE REPLACED. THE BEARING IS PART OF THAT ASSEMBLY. CAN BE A COSTLY REPAIR.
Apr 04, 2008 | Washing Machines
Amana Top Load Washer model# LW3502W Washer leaks water somewhere between wash & rinse cycle best I can tell...drain hose checks out fine. At beginning of wash cycle the first minute or two of agitation...
Sounds like the water seal is damaged and the leaking water has damaged the top bearing which is just below the water seal. You will need to have the hub & seal kit replaced.
Oct 30, 2007 | Amana ALW480DA Top Load Washer
Loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
LG WM-1832C Front Load Washer Logo
510 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
