Question about Ubi Soft Entertainment Petz: Horsez 2
I need the safe code - Ubi Soft Entertainment Petz: Horsez 2
  • 82 Answers
Check www.neoseeker.com for help
Posted on Jul 30, 2010
Says code error
How To: Open A Locked Sentry Safe If You Forgot ...
? 5:21
https://www.youtube.com/watch?v=Mr8QrvVAtuI
Jul 15, 2014 - Uploaded by TipsNNTricks
I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
' Sentry® Safe ' Lost Your Combination
https://www.sentrysafe.com/.../Lost_Your_Combination
Sentry GroupCombo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership. Step 1. Safe Info. Step 2. Notary Form. Step 3
opening a electronic safe forgotten the lock code ready to ...
www.instructables.com/.../OPENING-A-ELECTRONIC-SAF...
InstructablesJul 6, 2009 - I HAVE A SAFE GAURD COMPANIES SAFE I HAVE FORGOTTEN THE LOCK CODE TO OPEN IT. THEIR IS NO ALTERNATIVE OF KEY ...
How to Crack a Safe (with Pictures) - wikiHow
Jan 10, 2016 | Home Security
Tip
How to chanmge codes on most digital safes
To change the code on most digital safes. <br />you need to access the red button usually found inside the safe by the battery area. <br />Press the red button until you see two flashes. then enter your new code.<br /><br />PLEASE try the code BEFORE you close safe!! <br /><br />Thanks
on Apr 29, 2011 | Safe International Digital Electronic Safe...
My safe, a Cathedral EA15 Will not lock. Any suggestions people?
Instructions
  1. 1
    Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
  2. 2
    Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
  1. 1
    Enter your code to open the safe.
  2. 2
    Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
  3. 3
    Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
  1. 1
    Use your code to open the electronic digital safe's door.
  2. 2
    Locate and remove the battery cover on the inside of the door.
  3. 3
    Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
  4. 4
    Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
Feb 08, 2015 | Locks & Locksmithing
I need a default code for my Sentry safe
You will most likely need to contact them again and tell them what happened.
Aug 01, 2014 | Sentry FIRE-SAFE Combination Safe DS3431,...
How do i get the audi radio off safe mode?
IMPORTANT NOTE: You must have the security anti-theft code for yours Audi Concert radio from the car manufacturer! For Audi Concert the sequence of programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
3. By the #1 key you will set up the first safe code digit.
4. By the #2 key you will set up the second safe code digit.
5. By the #3 key you will set up the third safe code digit.
6. By the #4 key you will set up the four-th safe code digit.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
Please rate my response. Thanks!
Apr 26, 2010 | 2000 Audi A4
Safe won't accept the code and the keys are lost
Without the keys and safe code you will need to call a locksmith. Even then they might be skeptical about opening the safe for you. There should not be any "backdoor" way of opening the safe for security reasons otherwise it defeats the reason for having the safe. I would contact the safe manufacturer for further instructions or you will need to cut open the safe if the locksmith and manufacturer cannot help you.
Sep 23, 2009 | Locks & Locksmithing
I cannot open safe with the usual code.Safeguard electronic digit
To open a Safe International Digital Electronic Safe
User override key to open safe
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
Apr 27, 2009 | Safe International Digital Electronic Safe...
Need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Apr 06, 2009 | Safe International Digital Electronic Safe...
Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Mar 22, 2009 | Sentry Fireproof Safe
Ubi Soft Entertainment Petz: Horsez 2 Logo
64 people viewed this question
Top Ubi Soft Entertainment Video Game Consoles & Games Experts
Colin Stickland
Colin Stickland
Adam Jasar
Level 1 Expert
Edward Talavera
Edward Talavera
Are you an Ubi Soft Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
