Hello I have an hp 6820s notebook.when I power it up it has weird colors - blue lines all over the screen. i reinstalled the drivers but after a little while the problem comes back.... Also the laptop gets very warm. thansk for your help. marijke
    Sergeant:
    Champion:
  • 265 Answers
Connect it to a regular monitor - if it looks good your laptop screen is bad.
If the external monitor is bad, then the video hardware in your laptop is bad.
Posted on Jul 19, 2010
HP Photosmart C4280 All-in-One printer, printing in only black blue and weird pinky red
Replace color ink cartridge ,black cartridge is not required because of black prints are ok..
Sep 04, 2012 | HP Photosmart C4280 All-in-One InkJet...
Hi. The colour on my HP/Compaq 6820s laptop is a bit dull in comparison to my second extended Samsung monitor. I want to adjust the colour settings on the laptop, but all I can find on the keyboard is...
If you right hand mouse click on your desktop picture, a menu will become available. Click on Screen resolution and then Advanced settings. There will be options inside that window to allow you adjustment of the display.
Hope that helps.
Nov 25, 2010 | HP Smart Buy - HP Compaq 6820s Notebook PC...
I have a HP dv5000 notebook and the screen started showing weird colord lines and eventually turned black. I replaced the inverter and it worked for a couple of days then it did the same thing. I...
The problem is not from the inverter of the laptop. It is the module that is faulty, the module is like a flex in the laptop that assists in getting information from the motherboard to the screen, if it is faulty, it will start showing weird colors or start having some screen malfunctions.
Have the module replaced and the laptop will be in good condition once again. I had such experience with my HP530 and i replaced the module, trust me it worked perfectly fine.
Take care and good luck
Oct 14, 2010 | HP Computers & Internet
My Hp Compaq 6820s don't start when I press power button.
This simply means that the battery is dead. Pull the battery out and try to start it again (with the power adapter plugged in obviously). If it starts up, you need a new battery, if it does not start up you may have a bad power adapter or broken power jack.
Feb 26, 2010 | HP Compaq 6820s Notebook
Hp 6820s will not power up.
Try removing the battery and see if the light is normal.
If so, you may need to replace the battery.
Sep 28, 2009 | HP Computers & Internet
Vertical white lines appear on screen and music will play, beeping and a "chopper" noise have also occured. Replaced motherboard in Dec 08.
To isolate the issue.please connect the notebook to external monitor with the help of VGA port.(Blue PORT) on the notebook.if it good with out any lines.you need to fix the LCD screen of the Notebook.
May 10, 2009 | HP Pavillion ZV6000 Notebook
The screen of my laptop
If you get weird colors and poor resolution, then it is probably just the driver, that need reinstalling, in this case you will be able to read text normally, only photos look bad.
If you do not have the disk you can reinstall driver from factory website.
If you instead get only a bunch of floating stripes on the screen , then there is an hardware fault.
Either the connector/flat cable to LCD, or the video adapter.
Connect an external screen to laptop.
If external monitor works, then it is probably the video ribbon cable, the connector, or the LCD. Still not too expensive to fix.
If the external screen does not work, then it is the video adapter that is integrated on motherboard.
In this case check your guaranty terms.
If you need service you can call the number listed on the owner manual.
regards
Sep 11, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Vertical lines in my laptop screen
Try using an external monitor,every laptop has a blue VGA connector,just connect a monitor there and check is those lines
disappear,if it does,probably you have a problem with the internal connection of your monitor to the motherboard.
Sep 07, 2008 | HP Pavilion dv6000z Notebook
Hp 1200 color being wierd
remove your driver from your computer and reinstall the driver into your computer
May 11, 2008 | HP cp1700 Color Inkjet Printer
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
