Question about Dell Dimension 4600 PC Desktop
Dell jukebox on my computer
I believe that someone has deleted the jukebox on my computer. My question is: How do I get it back?
    Scholar:
  • 103 Answers
By "Jukebox", do you mean MusicMatch Jukebox?
If so, you can download it here http://www.download.com/Musicmatch-Jukebox/3000-2167_4-10020670.html
Posted on Apr 21, 2008
MY MOTHER HAD A GATEWAY DESKTOP COMPUTER, AN SHE
start your computer. when your computer is starting continue press F8 or F5 and then select SAFE-MODE to start your computer..
in safe mode login with administrator.
and then go to Control Panel. in control patel go to users and group.
select your username and then remove password
Oct 02, 2014 | Computers & Internet
E drive was deleted from dell latitude d620,need to reinstall
Wait a minute, you gave your computer to someone and they deleted the E drive? What was the E Drive? Most times it only appears when you put something in the USB Port unless you have 2 Disc drives, a cd drive and a dvd drive.
Are you sure your E drive has not been hidden by a virus or infection? It might still be there.
Apr 20, 2012 | Computers & Internet
Dell jukebox not working, want to transfer music
Mine has also ceased to charge. For awhile it would charge if I manipulated the charging plug in the socket but now doesn't respond to anything. It does make a nice paper weight now. I suspect mine has a bad connection in the charging circuit somewhere, perhaps just the socket has gone bad. Who knows? --- GB
Aug 22, 2009 | Dell DJ MP3 Player
I installed IE8 and now jukebox does not come up
I would upgrade to the latest version of Musicmatch.
Jun 28, 2009 | Musicmatch Jukebox 7.0 (1575956454) for PC
Cannot get my computer to recognize my Dell Jukebox
Assuming that you don't have windows vista, you can load the Dell DJ Explorer program that came with your DJ. It comes up as a regular looking window that should "see" your DJ when you plug it in. If it doesn't, where it says "not connected", right click and then click refresh. Sometimes it works better to plug in the DJ first, then load dj explorer. When it sees it, "not connected" should change to the name of your DJ. Double click that and it should then 'read' your dj, showing all the files on it. Then its just a tedious amount of copy and paste to another folder on your computer (like your My Music folder), and your music is restored to your computer. Take care, as DJ Explorer can also delete files from your DJ if you tell it to.
If you no longer have the DJ drivers and DJ Explorer and Musicmatch loaded on your computer, you can still download that stuff from the Dell site.
If you Do have Vista, try to find a friend with XP. Load the DJ explorer software on their computer, and pull your music off the dj to your friend's computer, then use a USB drive or something to move it to yours. Or better yet, upgrade your computer from VIsta to Xp (yes, I said upgrade - Vista is ****)
Jan 28, 2009 | Dell DJ MP3 Player
First Gen Dell DJ 20 Gig "File Cannot Be Written" Transfer Issue
Yahoo jukebox was bought out by Rhapsody. I had the same problem and their only solution was for me to buy a Rhapsody subscription. I know this is not the solution you want to hear but that seems to be the only way to keep any music that was stored using the yahoo jukebox.
Apr 08, 2008 | Dell DJ MP3 Player
Dell DJ Gen 2 Won't connect
if your Dell DJ player is no longer recognized by the upgrade firmware even with the correct, original device driver installed, then you will need to install a windows 'MTP' driver by doing the following. Note that this applies to Windows XP only.
1. make sure you have the SP2 XP upgrade.
2. Install Windows Media Player 10 or roll it back to version 10 if you are using a later version. You can roll it back by going to 'Add or Remove programs' and uninstalling any WMP upgrade from the 'Change or Remove Programs' dialog window. Note: don't uninstall WMP enitrely from the 'Add/remove windows components' dialog.
3. Go get this file: fixup.zip Unzip it in a temporary directory and run the fixup.cmd by double-clicking in explorer or using the windows 'Run' command. Follow the instructions it prints in its DOS window about deleting the Dell device in the hardware manager.
4. plug your DJ player into the USB port. XP should now say 'Found MTP device' or something similar.
5. Get the Dell DJ 1.02 firmware from their support site appropriate for your player. Run the firmware upgrade. The software should detect your player this time.
A good reference for the Dell DJ stuff is here: gotzune.com
Note: I can't personally recommend the 'PlayForSure' firmware as I have not been successful upgrading to it. WMP 11 does not seem to work with the Dell DJ but WMP10 does and the device Sync function works just fine.
For almost ALL of the MP3 players out there that seem bricked due to a firmware upgrade failure or some other reason, they can be usually restored in a simlar way by installing a basic 'MTP' driver which allows windows to at least send a file to it, and by putting the player into a recovery mode as defined by the manufacturer.
Sep 24, 2007 | Dell DJ MP3 Player
Player Turns On, but Won't Play Music
Yo fud, go to www.creative.com and search through the Knowledge Base. It should point you in the right direction.
Feb 12, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Deleting files
If you've got it connected to your computer, you can do the same things that you would with any connected hard drive. In this case you should be able to delete files and then empty the recycle bin.
After that, go to My Computer and right click the icon for your Jukebox and select Properties. There you should be able to use Disk Cleanup to purge old system files, etc.
Oct 30, 2006 | Archos Jukebox Recorder MP3 Player
Dell Dimension 4600 PC Desktop Logo
103 people viewed this question
Alun Cox
