Question about ElectroVoice . Speaker
I have an old set of EV 1502 PA Speakers. One of my Cabs the 15" driver stopped working... I can plug the Horn and the 15" Driver in Separately and they both work which I think means I have a problem with the Crossover.. I just don't know how to test it to find out what part of the crossover is bad.... any help???
  • 17,130 Answers
The crossover network is a combination of a LCR circuit. since all these arre passive components you will not have a problem to find the actual fault. Since you have confirmed with the drivers, the line in to the network from the speaker wires must be traced for continutiy, use a good multimeter. now check carefully on the PCB-printed circuit board.- for any track damage on it, if so loop and connect. The main driver is usually in parallel to the main line but with a croos over of a cpacitor and a series inductor. This will be the culprit, either it has come off from the PCB or open out by burning off. replace or reconnect. I am sure it can be sorted out easily by your carefully analysis. Hope this helps. Good day
Posted on Jul 20, 2010
Can I connect only one speaker to a yamaha emx 312 sc power mixer?
First it is certain that you would not want to plug both outputs of the stereo power amp into one speaker combining both channels into the same speaker. (see image from manual below - also link to manual)
Next I would be very concerned about only using the one side of the main amp out as it could cause an unbalanced load, or you could be driving the load into dead air connection and any of these conditions are destined to cause premature failure of the power amp.
Taking a quick scan of the manual for this unit, it appears what is pretty common to most powered mixers, hook up two matched speakers/loads to each chanel of the output.
Your best bet is to shed those monster cabs, there really is no need for them especially with this sized powered mixer, and get yourself a nice pair of full range cabs like EV1202;s, EV SX300's, or some nice 2 or 3 way 15" JBL's/
Just my opinon.
Link to Yamaha EMX 312 Owner's Manual:
Yamaha EMX Series Owners Manual
Dec 06, 2013 | Yamaha Music
I have a blown tweeter on my SP3 and I want to replace it but I don't know how to get it out of the enclosure?
There are a number of versions of SP-3, but normally you would remove the screws holding the horn into the cabinet, take out the horn and then unscrew the driver from the horn. At that point, either replace the diaphragm on the driver or the whole driver.
Aug 17, 2013 | Peavey New Peavey Sp3 15" 3 Way PA Speaker
How do i biamp these speakers they have a biamp plug in the rear do i need a special cable to do this
The two input jacks are parallel connected, to allow you to chain extra speakers together. There is no facility on this model to bypass the crossover and bi-amplify horn and driver separately. Nor should you need to. Just make sure you use a power amp rated for at least 400 watts per channel at 8 ohms.
Sep 23, 2011 | Peavey PV 115 Speaker PA Passive
I have a two way peavey p115 speaker system and audio has stopped coming out of the high frequency driver . I tested the high frequency driver with a multi meter and it is fines.I also have a working...
Testing the driver with an ohmmeter is incomplete test. Sometimes the magnets break off the drivers rendering no sound. Sometimes the voice coil shorts and if you don't interpret the ohmmeter readings correctly you can overlook a faulty driver. Remove the horn and look for damage such as lost magnet from the back. Also the peavey cabs have a protection circuit so if you did not try another speaker to the same wores going to the driver, it may be the Polyfuse on the protection circuit or other components.
May 02, 2011 | Peavey PV 115 Speaker PA Passive
Behringer b415 horn stop working how and where i get replacement
First thing is to test the horn as the crossover circuit may be the problem. If you need the part(s) for the crossover you can get them via DIgiKey.com, however repalcing the horn driver you may have to go through FullCompass.com and if the part has to come from Behringer it takes months.
Mar 16, 2011 | Behringer B415dsp Eurolive 600watt 15 PA...
I HAVE THE MTX TP112 SPEAKER, THE HORN TWEETER STOPPED WORKING. CAN I GET A NEW HORN OR THE TWEETER ATTACHED TO THE HORN ALONE? I CAN'T FIND
It is a one piece horn need to replace the whole thing. These are not like normal PA speakers where the driver can be unscrewed from the horn lens and replaced.
Jan 09, 2010 | MTX 12" 2-Way Professional Loudspeaker...
No sound from EV SH-1502 ER 15" driver
Either the 15" speaker is dead, or the passive crossover inside the unit. The simplest way to identify your problem is to remover the speaker that isn't working from the enclosure, and exchange it with the speaker that is working. If there's no sound still, it's the speaker itself that is the problem. If it works in the other cabinet, then put the "working" speaker in the cabinet you took the "bad" speaker out of, and if it doesn't work, then there's a problem with the crossover in the first cabinet. I believe you can buy a replacement crossover from EV. If it's your speaker, do a google search for "speaker re-coning" in your area - it's cheaper to re-cone the speaker than buy a new one.
Jun 18, 2009 | ElectroVoice . Speaker
Monitor hp 1502 15"
Dear Client, you can download driver from the following link.
Monitor L 1502 15 Driver
Best regards
May 27, 2009 | HP Compaq 1501 15" LCD Monitor
ElectroVoice . Speaker Logo
859 people viewed this question
Top ElectroVoice Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Are you an ElectroVoice Audio Player and Recorder Expert? Answer questions, earn points and help others
