Question about HP Pavilion dv6000z Notebook
Where is battery pack located.
Want to remove battery pack
  • 661 Answers
The battery is on the bottom. There is a little slide switch there that releases it.
Posted on Jul 19, 2010
  • 86 Answers
There should be two or three little sliders on the bottom of the machine. Pull them back and the battery should pop free.
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Jan 23, 2016 | Ryobi Garden
How can i remove my sim card to my nokia c7?
The SIM card is located beneath the battery pack. You must release the back cover latch, lift it up, remove the battery pack, and, then, access the SIM card slot. Please, refer to pages #8 and #9 of your phone's user guide (which you can download from this location, in case you happen to miss it) for further details.
Hope you are able to sort your problems out soon.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
May 11, 2011 | Nokia C7 (8 GB) Smartphone
Where is the thermostat?
It's located under the ignition coil pack.
Follow these instructions to replace the thermostat
  1. Disconnect the negative battery cable.
  2. Drain the cooling system.
  3. Remove the air intake tube, crankcase breather and PCV hose.
  4. Remove the ignition coil pack and bracket.
  5. Remove the upper radiator hose.
  6. Remove the ignition coil pack bracket.
  7. Unfasten the heater hose inlet tube bracket bolt and remove the heater hose inlet tube from the thermostat housing.
  8. Remove the three thermostat housing attaching bolts, then remove the thermostat housing and gasket.
Mar 06, 2011 | 1994 Ford Escort
Wont start battery and starter work fine. sprayed
Hi and welcome to FixYa!
Looks like that you have a faulty coil pack. If the coil pack is faulty it tends not to give current to the plugs. No wonder the car will not start. The coil pack is located at the side of the engine, you will need to remove the cap where the plug wires are connected. Once you removed the cap you will gain access to the coil pack. You will need to pull it out and have it replaced.
Hope this helps and thank you for using FixYa! Have a good one!
Feb 14, 2011 | 1997 Honda Civic del Sol
How to reset your nintendo DS
Hi. Here's the procedure on how to reset the console. Take note that if you are going to do this procedure this will erase all of the data saved on the system and restore the unit to its original factory settings.
Remove the cover for the battery compartment. The compartment is located on the back of the DS Lite unit, and the cover has a small screw holding it in place. You will need a Phillips size 0 screwdriver to remove it.
  • 2 Take out the DS Lite's battery pack. There is a tab at the top of the battery pack. Insert your fingernail or the end of the screwdriver carefully into the edge of this tab and pop out the pack.
  • 3 Keep the battery pack out of the unit for at least 10 seconds. If you keep the battery pack out for too short of a time, it will not reset the unit.
  • 4 Put the battery pack back into the unit. Just line it up in the compartment and push it back into place.
  • 5 Replace the cover. Secure the cover back into place with the screw.
  • 6 Turn on the DS Lite. If the unit has properly reset, a screen will come up that reads "Before you begin, you must adjust system settings." You can now enter all-new settings and information on your DS Lite. If you do not get the system settings screen, you did not keep the battery pack out long enough. Repeat the steps and leave your battery pack out for a longer period of time.
  • Sep 12, 2010 | Nintendo DS Console
    Need to change the batteries in a Stanley bar flex light. lost instructions. how do you change the batteries.
    I know this thread is old, but I just had to change the battery pack in mine. I could not locate a 4 pin battery pack so here's what I did:
    You'll need: 3 NiMH 1.2v AA solder tab batteries, Razor blade, #1 Phillips driver, Kapton tap (standard electrical tape will do), soldering gun/iron, spare 18awg wire
    1. Use a razor blade to remove the black sticker from the bottom of the flashlight base, it covers the magnets
    2. remove the three outer phillips screws (the inner ones hold the magnets in and can stay installed)
    3. Pull off the bottom plate
    4. Pull out the battery pack and disconnect it from the flashlight at the 4-pin queeze connector
    5. Remove the outer wrap and end protectors from the old pack keeping the end protectors in tact
    6. Assemble the 3 new batteries in the same configuration as the old pack using Kapton tape, connecting + to - at the same two spots (use the old pack as a reference)
    7. Carefully desolder the 2 wire leads from the old battery pack
    8. connect up the 2 power wires to the same two spots as the old pack and insert the temperature probe between two of the batteries as in the old pack
    9. Put the end caps on the new pack and wrap the entire thing in Kapton tape to simulate the plastic wrapper you removed
    10. Install pack in to base, secure bottom plate and re-adhere black sticker(if needed you can use non-foam double-sided tape or spray adhesive)
    The old pack was rated at 1300mAh and I used three 2000mAh each for a total of 6000mAh so theoretically the light should run for about 6 times as long between charges.
    Aug 28, 2010 | Garden
    I have a pride go go elite traveller 4 and need some new batteries, but what batteries and connection am i looking for?
    Rachel you need 2 12/12AH batteries that are located in the battery pack under the seat. Simply pull the battery pack from the scooter and with a standard phillips screwdriver remove the many screws attaching the battery pack together (simply turn the pack over to get to the screws) There will be two wire on each battery and also a heat sensor attached to the side of one battery remove the wires from each battery and carefully reove the heat sensor. You can bring one of the batterys to your local battery warehouse type store or a provider and purchase 2 new ones reinstall like you removed attaching red wire to red terminals and black to black terminals and reattach the heat sensor to the side of one battery (you can use packaging tape to reattach). replace all the screws to put the case back together and reinstall in your scooter. Charge the batteries with you charger until the charge light is green then happy riding HOPE THIS HELPS
    Aug 20, 2010 | Pride Mobility Products Go-Go Elite...
    How to replace the ignition module in a 1993 oldsmobile eighty-eight royale
    Find coil pack I think it is on the front passenger side. Disconnect negative battery cable. Remove electrical connector from module. Remove the four or six bolts that fasten the coil pack/module to the motor. Mark location of coil packs before removing from module. Replace in reverse order.
    Mar 11, 2010 | 1993 Oldsmobile Eighty Eight
    How do you restart nintendogs
    No No No! Bad Silver! Before You See The Nintendo Sign (It may be after) Press and Hold A +B + X + Y + L Trigger + R Trigger and that's all. Taking Apart Your DS gives you a 99% Chance of epic fail. -_-
    Feb 12, 2010 | Nintendo DS Lite
    HP Pavilion dv6000z Notebook Logo
    26 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
