Question about RCA P52926 52" Rear Projection Television
Heres the board
Thanks for all the help.
  • RCA Master
  • 8,617 Answers
Thats the main power filter board. No longer available. I will try searching for you. however that board powers the power scan board, and usually with that Chassis ITC222 its the power scan board that causes all the problems.
Posted on Apr 21, 2008
GE model Pfs22miwww. Condenser fan and compressor not running. Tested start cal it is ok. Changed ontology board. Condenser fan now running. Still no compressor
Have you changed out the WR55X10942 Motherboard? Here is a link to test points on the motherboard HERE and here is a service manual HERE I don't mind helping answer your questions so feel free to contact me, Thanks Sea Breeze
WR55X10942 Main Control Board
Mar 22, 2013 | GE G.e Refrigerator Wr55x10942 Motherboard...
I have a Toshiba 65H82 television with the wavy line problem. I have read the solutions on this site. It talks about the "hyper board." The list of boards in the service manual does not list a...
Hyper board is located under metal shield mounted on signal board in tv, buy repair kit from HERE and replace capacitors in hyper board to solve wavy picture problem in Toshiba 65H82
Thanks.
Mar 29, 2011 | Televison & Video
The sound is working but the screen is showing black
Hello, Thanks for the opportunity to help.
What your experiencing is a bad back light or inverter board.
The inverter board is a circuit board responsible for producing the electric down conversion for the back light. This board is found on or on the sides of the actually lcd display. these boards can be purchase for under what it would cost to repair this tv at a local shop.
Here is the part number for this board click here
Now you may check www.shopjimmy.com to see if they have the board in stock or not. You might also check www.ebay.com for said part.
Working on these TV's is a skill and it takes allot of effort to do. Please keep in mind safety and risk while opening these tv's. We are not responsible if you decide to do this yourself. Remember also we are not there so there is no basic way to diagnose without a two way conversation and a look see feel approach.
The common issue is the back light or its inverter board in your case.
Thanks for giving me the opportunity to help, Thanks for using Fixya.com
Jan 25, 2011 | Toshiba 22AV500U 22 in. LCD TV
Tv is going on and off
Basics first:
try plugging into a different wall outlet try using a different surge protector
If still same problem then the power board or inverter board need replacing or servicing. You can get your boards here at a good price. To install the boards require opening the back cover of the tv. I can walk you through it, CLICK HERE to find your boards. Contact me at the link below for further help..........please rate if this helps you thanks :-)
http://tvtechwork.webs.com/
Oct 22, 2010 | Insignia 42" Flat-Panel Plasma HDTV
Frig lights on but not cooling
The GSH25JRF uses a mother control board and we need to unplug and have a look for burn mark on both sides of the board. The board has 2 different numbers for the same board. WR55X10942 or PT number 1531075 Main Control Board. The board is located behind your refrigerator and under a covered panel screwed down with sheet metal screws. We will need to also look at the start relay and start capacitor if the board looks OK on both sides. Here is what to look for on the board, burn marks, signs of heat or loose solder connections. Let me know if I can help you more I will be here to assist you, Thanks Sea Breeze
Aug 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Fans comes on for 3sec
Here are a couple of things...heres the Intel site about this board, with connections (with a very clear front panel drawing) diagrammed:
http://support.intel.com/support/motherboards/desktop/d850gb/sb/CS-013238.htm
and here is a page of pictures of this model board to compare to youre to make sure it is the same board:
Jun 04, 2008 | Intel Desktop Board D850GB Motherboard
RCA P52926 52" Rear Projection Television Logo
89 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
