Question about Dyson Washing Machines
Got dyson cro2 flowcheck washing machine and its come up with f11 f1 f2 faults and its v205 can anyone help?
SOURCE: Fault F11
no.needs engineer
Posted on Sep 26, 2008
jonniewalker
  • 1031 Answers
SOURCE: dyson cro1 fault f11 came up after interupted power suply
normally error like this disappear when a hard reset is performed? did you leave the unit turned off by plugging out from wall power for one night ??
The F11 fault is a fuse blown on the circuit board.
Apparently this fuse failing can blow the board so you may have to change the board if needed. The board is located at the back of the machine so you need to take the back off, unplug the board, change the fuse which you can buy at Maplins and put the board back.
If it works fine, if not then you need a new board. Hope this helps you.
First make sure machine is turned off.
Second press & hold temperature button .
Thirdly press the on button & hold at the same time as the temperature button.
Fourthly release the 2 buttons at the same time .
Fifthly press the soil button .
Sixly turn machine off then back on & F11 message saying fault F11 must disappear.
if not try this process once again. if the error is not cleared then you will have to do as i have said you earlier.
Posted on Jan 18, 2009
  • 105 Answers
SOURCE: DYSON washine machine fault
To Clear F11 Code after a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
Posted on Feb 10, 2009
  • 107 Answers
SOURCE: FAULT CODE F11
F-11 like a Kenmore means communication error between the motor control and the main control. Check connections, unplug and replug computer connections and see if problem persists. I've seen cases where either board or even both can be bad.
Posted on Mar 14, 2009
GodBlessU
  • 3513 Answers
SOURCE: f11 fault code
Please find the steps that needs to be taken for trouble shooting F11 fault code specially if there was a power cut.
3, Power on
You will now hear the door lock release so you can get to your pants.
I am sure it would help you to resolve the issue.
God Bless.
Posted on Jul 09, 2009
I HAVE FAULT F11 HOW DO I FIX IT
Dyson Memory CRO1 Front... Fault f11 Solutions - Fixya
www.fixya.com > ... > Dyson > Dyson Memory CRO1 Front Load Washer
Dyson Memory CRO1 Front Load Washer, fault f11 related issues. Get free help, solutions & advice from top Dyson experts.
Aug 08, 2015 | Dyson Flowcheck CRO1 Front Load Washer
Dyson CRO1 F11 Fault
until what cycle does this unit proceed?
Jul 26, 2008 | Dyson Flowcheck CRO1 Front Load Washer
F11 fault on Dyson Contratotor any ideas what this means
Turn off washing machine...Press and hold temperature button turn on machine whilst still de-pressing temperature, holding down both buttons,let them both up together, press soil type for 2 secs, then turn off and message should be gone.
Aug 25, 2011 | Dyson Flowcheck CRO1 Front Load Washer
Have a cro2 flowcheck and cant get the door open after a wash. Tried the temp/soil solution and it doesnt work.
Sorry to hear you're having difficulties with your Dyson Contrarotator. It's probably best if you get in touch with us directly, so one of our experts can run through some troubleshooting over the phone, and provide the information and assistance you need. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 19, 2011 | Dyson Flowcheck CRO1 Front Load Washer
F11 message
May be the fuse located on the PCB board ( bottom right hand side when looking from rear of washer ) - check and replace ( 10A 250V miniature fuse )- Can get from Maplins.
May 22, 2010 | Dyson Flowcheck CRO1 Front Load Washer
F11 fault code
3, Power on
God Bless.
Jul 09, 2009 | Dyson Flowcheck CRO1 Front Load Washer
How to repair a F 11 fault on a DYSON CR01 flow check
f11 fault code is a problem with the main power board (could be blown fuse) or a blown board check the fuse the board is behind the back plate in the bottem right corner (looking from the back of the machine.(!unplug before you take apart!)
May 29, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Dyson cro1 fault f11 came up after interupted power suply
Jan 18, 2009 | Dyson Flowcheck CRO1 Front Load Washer
3, Power on
Sep 05, 2008 | Dyson Flowcheck CRO1 Front Load Washer
Washing Machines Logo
136 people viewed this question
Top Dyson Washing Machines Experts
Starnley Johnwells
Starnley Johnwells
Gerry Harvey
Gerry Harvey
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
