I have intalled windows 7 on my axioo m54sr laptop the problem is i can't get connected trhough wi fi is it because i don't have the driver? is windows 7 driver for this laptop existed?
  • 55 Answers
SOURCE: can't download compaq 754 tu laptop wi fi drivers
Hi
Try this link:-
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3674870&lc=en&cc=us&dlc=en&submit.y=10&submit.x=2&lang=en&cc=us
Posted on May 20, 2008
Silverblade
  • 173 Answers
SOURCE: Wi-Fi problem Toshiba A15-S157 laptop
If your laptop has a di-fi switch/button chances are you have one integrated on the main board of the laptop, check if the wi-fi adapter is installed properly by going to the Device Manager and check Network Adapters normally a wi-fi adapter will show up if not check if you have any devices listed under network devices(Network Controller, Ethernet Controller). Now if the wi-fi card is installed and the status on the Device Manager say's that it's working properly, you may now check your laptop for a 3rd pary wi-fi utility/application that manages your connection look for it on the System Tray on the lower right hand side near the clock or go to all programs and look for any WLAN utility, when you open the utility make sure the wi-fi radio is turned on or enabled.
Posted on Nov 05, 2008
Danseo246
  • 35 Answers
SOURCE: Want Instant wi fi when turning on my laptop
Hp comes with a wi-fi utility and I dont find it very useful, so first, you might want to uninstall the software from add or remove programs and then use windows to manage your wi-fi.
Once you connect to a wireless network from 'network connections', it will automatically be set to default and should connect at the computer startup.
If it does not connect automatically.go to 'change order of prefered networks' and put your prefered network on top and set to automatically.
Posted on Dec 29, 2008
  • 47 Answers
SOURCE: my problem laptop not working wi fi connection connect phone
ok.
its knows that vista isfull of bags and corraps.
the fing is a computer with vista req a heavy vid card such as 9xxx (dont go on 8800 it is waste of money) and you need 2-4 gb ram for your computer to work perfect and so the best fing you can do try to download windows7 beta it is like windows vista but acts like xp wich is the best so look for a good downloadand goodluck.
Posted on Aug 15, 2009
Jack_Dawson
  • 287 Answers
SOURCE: Toshiba does not connect to wi-fi unless other laptop is on wi-fi
1. Reinstall the wireless driver.
2. Restart your system.
Posted on Jan 04, 2010
My HP Elitebook 6930p wi-fi connection stopped working
It sounds like windows update may have changed your driver to a generic one. Download and install the driver again from the HP link for your model laptop here HP EliteBook 6930p Notebook PC
Oct 17, 2015 | HP EliteBook 6930p Notebook PC
Wlan card disabled
The Dell Latitude E6400 laptop comes with an Intel Core 2 Duo processor for fast computing and an NVIDIA graphics card for video playback, gaming and Web browsing. The laptop has a built in Wi-Fi card, letting you connect to the Internet on-the-go. However, if you're unfamiliar with Dell or the laptop's factory installed Windows Vista operating system, you might not know how to enable to Wi-Fi.
Slide the switch on the side of the laptop toward the front of the laptop. This switch enables Wi-Fi connectivity on the Dell Latitude E6400. When switched into the back position, the Wi-Fi is turned off. Turn on your Dell Latitude E6400 laptop and log into Windows Vista. Click on the Windows "Start" button. Click on "Wireless," located in the Start menu's "Show" list. A list of currently broadcasting wireless networks appears on screen. With your Wi-Fi enabled, you can connect to any of these available networks. Secured networks ask you for a password when you click "Connect," while unsecured networks connect automatically.
Feb 03, 2013 | Dell Latitude E6400 Notebook
Can not get to wifi
Wi-Fi technology enables wireless Internet and network access through public and private hot spots.
These hot spots are widely located in homes, restaurants, bookstores, coffee shops and other businesses, so you can keep connected wherever you may travel.
To connect to Wi-Fi, you must have an enabled wireless adapter on your computer.
Most modern laptops and many desktops have this adapter built into the system, but many lack such capabilities.
However, a wireless adapter is easily installed via USB, which allows you to connect to available networks through Windows 7.
Enable your wireless adapter. Most laptops have a hot key labeled with a radio antenna.
Hold the "Fn" key and press this key to toggle wireless on or off.
Desktops likely have a physical antenna on the back of your computer that is typically always on. If you don't see such a hot key or antenna, you need to acquire a USB wireless adapter.
Attach the USB wireless adapter to an available USB port on your computer.
Windows 7 will automatically install the necessary drivers for most adapters.
If it does not, insert the CD that came with the USB wireless adapter into your drive and choose to install their drivers.
Restart your computer if you do not see a wireless icon in your Windows 7 notification area.
Click the wireless icon in the Windows 7 notification area and click the network name to which you want to connect.
If this is your home network, the correct network will likely be the one with the strongest signal.
Click "Connect" and enter the wireless security passphrase, if required.
Only secured networks will ask for a passphrase, but some public networks will require browser authentication instead.
Open your browser and navigate to any website.
If the hot spot requires browser authentication, your website request is redirected to an information page.
Follow the instructions on this page to get Wi-Fi.
This may entail clicking "Accept," entering a given password or entering a cell phone number.
After authentication, attempt your website again to verify accessibility.
Hope this helps
Oct 29, 2012 | Acer Iconia Tab A200
Can i make a hp officejet 6110 printer wireless
SETTING UP A WIRELESS PRINTER WITHOUT A WIRELESS ROUTER - WINDOWS 7
Install Virtual Router first "Turn any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot Spot."
EditByBSEditor: Virtual Router turns any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot SPOT using Windows 7's Wireless Hosted Network (Virtual Wifi) technology.
The Wireless Network Create/shared with Virtual Router uses WPA2 Encryption, and there is not way to turn off that encryption. This is actually a feature of the Wireless Hosted Network API's built into Windows 7 and 2008 R2 to ensure the best security possible.
You can give your "virtual" wireless network any name you want, and also set the password to anything. Just make sure the password is at least 8 characters. http://www.brothersoft.com/virtual-router-327895.html Then install Connectify-Me Connectify is an easy to use software router for Windows 7 computers. After downloading and installing the lightweight application, Connectify utilizes your computers' built in Wi-Fi card to wirelessly share any available Internet connection: a cable modem, a cellular card, or even another Wi-Fi network. Other Wi-Fi enabled devices including laptops, smart phones, music players, and gaming systems can see and join your Connectify hotspot just like any other Wi-Fi access point and are kept safe and secure by password-protected WPA2 Encryption. http://www.connectify.me/ Then reboot computer
Aug 18, 2012 | HP OfficeJet 6110 All-In-One InkJet...
My notebook cannot connect to the wireless router. its on my wifi but i cannot connect to the internet. it says dns server error
Hi Dear Being able to connect to a wireless network or wi-fi hotspot is fundamental for mobile work and play. The step by step directions in the wi-fi tutorial below will help you set up your laptop so you can connect to a network wirelessly for Internet access or to share files with other computers on the network. Examples are given for Windows XP, Vista/7, and Mac.
  1. Find the wireless network icon on your computer (on Windows, you'll find an icon that looks like 2 computers in your taskbar on the bottom right; Macs will have a wireless symbol in the top right).
  2. View available wi-fi networks by either right-clicking the icon and selecting "View Available Wireless Networks" (Windows XP) or left-clicking the icon and selecting to "Connect or disconnect..." (Windows Vista). On Mac OS X and Windows 7, all you have to do is click on the wi-fi icon to see the list of available networks.
  3. Choose the network to connect to by clicking the "Connect" button (or just selecting it on Win7/Mac).
  4. Enter the security key -- if the wireless network is encrypted (with WEP, WPA or WPA2), you'll be prompted to enter the network password or passphrase. This will be stored for you for next time, so you'll only have to enter it once.
  5. On Windows 7, select the type of network this is -- Windows 7 automatically sets up security for different network location types (Home, Work, or Public).
  6. Start browsing or sharing! You should now be connected to the wi-fi network; open your browser and visit a website to confirm.
Tips:
  1. Make sure you have a firewall and updated antivirus software especially if you're accessing a public wi-fi hotspot. Open or unsecured wireless networks are not safe at all.
  2. In Windows XP, make sure you have updated to SP3 so you have the latest WPA2 security drivers.
  3. Some wireless networks are set up to hide their SSID (or network name); if you don't find the wi-fi network in your list, ask someone at the establishment for the SSID information.
  4. If you are able to connect to the network but not the Internet, make sure your network adapter is set to automatically get its IP address from the router or try other wireless troubleshooting tips.
  5. If you can't find the wireless network icon, try going to your control panel (or system settings) and the network connections section then right-clicking on the Wireless Network Connection to "View Available Wireless Networks". If the wireless network you're looking for isn't in the list, you can manually add it by going to the wireless network connection properties as above and clicking on the selection to add a network. On Macs, click on the wireless icon, then "Join Another Network...". You'll have to enter the network name (SSID) and the security information (e.g., WPA password).
Sep 20, 2011 | D-Link DIR-600 Router
Describe your 7" G-Netbook
There may be many reasons for this. Please check the following things one by one.
1. If you have another known good laptop then try it with your wi-fi router. See if the wi-fi router is able to connect to the internet
2. If you don't have another laptop then use an ethernet cable (RJ45) cable to connect to the wi-fi router. See if this helps.
3. While connected with the wi-fi router see if you can access the router. open any internet browser and type 192.168.0.0. you should get the router page. If you don't get then you have to configure the router first.
4. Check the internet settings of your browser. There will be "internet options" or similar in the menu of your browser. Click that. In the GUI you will get "connections" tab. Click that and select the proper wi-fi setup.
Jul 28, 2011 | Sylvania G-Netbook
Lost wi-fi facility
Hi, Well you have formatted the system, so you need to install the Wi-Fi driver in order to access the Wi-Fi. ou must be having the driver CD, If you dot have just download the wi-fi driver from internet and install it on your Laptop and re-start the laptop and you will be able to access the Wi-Fi again.
Regards, polysandy
Apr 26, 2010 | Acer Travelmate 2200 Notebook
I have a problem witch wi-fi. my wi-fi can'not found internet or som conetction. I need drivers for wi=fi
here is the download link for your Wi-Fi driver
For Windows Vista :
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_wifi_realtek_28824A.exe
For Windows 7 :
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_wifi_atheros_TC00190600E.exe
Download and install the driver according to your operating system.
Your Wi-Fi will work fine now.
That's it.
Jan 24, 2010 | Toshiba Satellite L305D-S5881 Notebook
Samsung np-nc10 shows good signal for site wi fi but wont connect
Go here and download the latest Wi Fi card drivers for your samsung, from samsung.
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=NP-NC10
Hope it works
Jim
Dec 20, 2009 | Samsung NC10-14GW Notebook
Wi-fi problem
I went to the Proxim website (www.proxim.com) to see if I could find info on the card, but Proxim looks like they make you register before you can get any information.
You probably just need a Vista driver. Go to the Proxim site, register, and see if one is available.
Good luck.
Dec 09, 2007 | Proxim ORiNOCO Gold 802.11b Wireless...
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
