Question about Bosch Drills
A bit is stuck in the chuck of my Bosch drill
A bit is stuck in the chuck of my Bosch PSB 750-2RE drill. I can't open the chuck. Help please !
  • 10,865 Answers
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Posted on Jul 19, 2010
    Problem Solver:
  • 7 Answers
Place drill bit in a vice and then use a steel punch and hammer to push chuck off drill bit - have someone hold tool so it doe not fall on floor!
Posted on Nov 25, 2011
Chuck stuck open on my psb700 re
not much can be done as the chuck is not specifically designed to handle hammer drill operations (they crack the scroll thread adjuster inside )
best get a new chuck and if you do a lot of hammering get a proper hammer drill that has a push in operation not an ordinary electrical drill with a hammer capability
Sep 09, 2016 | Bosch Drills
How do you remove the keyless chuck on a Bosch PSB600 RES drill?
Here's a link to an exploded view:
Bosch PSB 600 2 0603338003 Spare Parts
If you need more help - you should contact Bosch directly:
Contact Bosch
Apr 14, 2015 | Bosch Drills
Bosch psb 750-2R
manufacturer can supply you with a new chuck. Mounting bolt is typically through the front opening into the back portion near the drive assembly
Jul 04, 2014 | Drills
Drillbit stuck
Can not see what model you have. Is it a keyless chuck or an SDS chuck? With a keyless chuck hold the machine in a vice by the drill bit. now tap the chuck with a hammer or pin punch & hammer. DONOT hit the chuck on the jaws gut on the rim around them. I have had success using this method. If it is an SDS type chuck pull the chuck cap up as far as possible along the bit them if there are any ring springs you will have to try remove them then slide the sleeve up the bit, now you should be able to remove any steel balls. If the bit does not come out now hold bit in vice as before and tap on tool holder.
Mar 02, 2014 | Bosch Drills
Broken drill bit stuck inside drill
if you open chuck all the way the drill bit should just fall out
Dec 11, 2013 | Bosch 13624 24V Cordless Hammer Drills
Psb 650 re
You have wound the threaded section of the jaws fast the thread in the case so sorry the chuck is broken as the teeth will be damaged. Best replace it with a new chuck
Jun 18, 2013 | Bosch Drills
The keyless chuck on my "PSB 5000 RE" electric drill has jamed up and cannot be used. Can it be replaced or is the whole electric drill a throw-away?
chucks are screwed to the drill by a left hand theaded screw. try to get the jaws open enough to access screw then replace with new keyed jacobs chuck. they are brill.
Aug 12, 2010 | Bosch Garden
How do you replace the chuck on a Bosch 650 RE
while holding the drill like a gun, hold the lock button REALLY tight and pull the black part to the right really hard. this will unlock the chuck and if you keep twisting the black part to the right it will loosen it enough so that you can remove it
Jan 03, 2010 | Bosch Drills
Hi, I let a friend use my Bosch 5600 PSE key less
you can't drill counterclockwise the bits are setup to drill clockwise and the chuck would become loose. try using two wrenches to free up the chuck then spray a little wd40 in it it is just bound up
Nov 05, 2009 | Microwave Ovens
Bit stuck in Bosch PS20 keyless chuck
These units have only been out for a short while and most are on warranty. Take it to a Bosch Service center in your area and they will replace the front of the unit. Unfortunatly this is a problem with this type of unit. The bit will deform slightly from the impacting action and lock itself in the chuck.
Jan 17, 2009 | Bosch PS20 2 Factory Reconditioned 10.8V...
Drills Logo
2,647 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
