Question about Vermont American Tool Company Vermont American (VER30026) 14 in Universal Shank Metal Cutting Jigsaw Bl
Unable to remove screw on 18320 carbon hole saw
Package gave no indication that secrew was non standard and a special allen wrench was needed and which should have been provided.
  • 661 Answers
It isn't all that special. it is just a metric one. You can pick a set of metric allens up pretty cheap at harbor freight or any other auto parts store.
Posted on Jul 19, 2010
Prssure washer m1000 3 hp used to wash boat water leaks from inside cannot find allen wrench to fit wrench has small hole in center
They are probably not allen head screws but rather tamper proof Torx screws. You can break out the small pin or you can now buy special Torx bits with holes to remove tamper proof screws. They should be available at most hardware outlets or at shops that sell Chinese imports. Torx bits are prefixed with a "T" and the size you are looking for is probably about a T20, but the sets come with an assortment of sizes up to about T40.
Apr 22, 2011 | McCulloch FHH18A Electric Pressure Washer
Need new ignition lock cylinder
You will need a tool like a allen wrench, somthing small with a 90 degree angle, and some torx bits. Disconnect the battery, wait for 5 minutes, then using the torx bit remove the lower column cover. Look up inside the column to the top cover, some models the top cover is held on with inverted torx. If you see a star looking screw you will need to remove them too. Aftre that gently raise the upper cover, turn the key to run. On top of the lock housing there will be a small hole, put the allen wrench in the hole, press down, hold the key to the start and pull out on the lock. It is not as bad as it sounds. Good Luck.
May 05, 2009 | GMC Savanna Cars & Trucks
How to change the oil filter on an 2005 audi A3 2.0L Fsi
There should be a square hole for a 3/8 ratchet or a octagon for a wrench to remove th adapter. Some had allen wrench fittings which would be a recessed octagon
Apr 29, 2009 | 2005 Audi A3
Need to replace mirror-glue failed- can't remove the button from mirror. help!
There is a small hole wear you insert a allen wrench or allen key to loosen a set screw to get the button out.
Apr 19, 2009 | Buick Regal Cars & Trucks
Cannot find a way lock the blade so as to remove the blade
Got it. The header states it is a table saw but you indicate it is a mitre saw. The instructions for this that I found are in French (which I don't read) but I can see pictures and the solution is there is a hole in the motor housing in the center that you would need to find out what size allen wrench fits the shaft that is in there and then lower the guard and use a wrench on the hex nut while holding the hex key. Let me know if this works please.
Mar 22, 2009 | Delta Saws
Access to oil plug 2004 lowrider
get an allen key of the correct size saw of (from the long end) enough to fit in the hole plus enough to get a spanner on , fit the sawn allen key to the hole and use an appropriate spanner to undo
hope this helped
Jan 18, 2009 | 2004 Harley Davidson FXDL - FXDLI Dyna Low...
Can anyone give me step by step instructions on how to remove light engine from sony kdf60wf655 tv thanks
I have the same Sony TV and just replaced my bulb. I ordered the bulb from sony.com and the package included the allen wrench you will need and simple step by step instructions are also included. There are two hand tightened screws on the lower rear corners of your TB. Remove these screws by hand and remove the botton gray panel of the TV. You will see the light package in the bottom center. Remove the hand tightened screw and swing the metal holder away. The gray cover now will come off by pulling lightly on the bottom. This will expose the lamp. You will need the allen wrench supplied with the bulb to remove the allen screw on the left. Once removed, the plastic cage containing the bulb will slide straight out. Push the new bulb in and tighten the allen screw. Replace the gray cover and swing the hold back in place the hand tighten the screw that holds it in place. Replace the gray bottom panel and hand tighten the two screws on the lower rear corners. That's the whole deal.
Jan 17, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
How to remove bottom plate
you will need either a t15 or a t20 torx bit. you should find these at any hardware store.
Aug 24, 2008 | Bissell 5770 Healthy Home Bagless Upright...
Vermont American Tool Company Vermont American (VER30026) 14 in Universal Shank Metal Cutting Jigsaw Bl Logo
82 people viewed this question
Top Vermont American Tool Company Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Vermont American Tool Company Saw Expert? Answer questions, earn points and help others
