Question about Lexmark X2500 All-In-One Printer
I need a download link for the image to text OCR application for the Lexmark X7550 scanner
    President:
  • 1,138 Answers
On this url you will find a list of possible downloadable sites for Lexmark OCR software
1. http://www.wuhu-online.com/lexmark/lexmark_ocr_software-xh2.html
Posted on Jul 19, 2010
OCR doesn't work with WINDOWS 7 and my Lexmark X5650es printer
Try this approach:1. Uninstall your existing printer driver. On your computer, go to Start menu > Programs > Lexmark X5600 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.2. When your pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.3. Use the link below to download and re-install the corresponding printer driver for your operating system:- Lexmark X5650 Printer Driver for Windows 7 32-bit- Lexmark X5650 Printer Driver for Windows 7 64-bitSimply follow the instructions on your computer screen to complete the installation.4. To re-install the Lexmark OCR scan software, insert the printer software installation CD in your pc CD-ROM drive.5. Click on Install > Install Additional Software > select the Lexmark OCR Scan Software > continue with normal installation steps.
Then try to create a PDF or Scan and Edit text (OCR) to verify that the problem is fixed.
If that doesn't help, please contact Lexmark Technical Support Center at 1-800-539-6275 for additional assistance.
Feb 13, 2012 | Lexmark X Office Equipment & Supplies
Everytime i scan a document on my lexmark all in one it doesn't come up as a letter in order for me to edit it for my changes.
When you scan a document, basically all you're doing is taking a picture of it. You end up with an image file that you can view, but not a text file that you can edit. You need an optical character recognition (OCR) program to convert the scanned image into text.
The CD that comes with an all-in-one printer or standalone scanner almost always includes some OCR software. You didn't give a model number so I can't look it up on Lexmark's site to see what downloads are available, but you can check for yourself if you don't have the disc. OCR capability is also available if you have Microsoft Office installed, and you can find under "Microsoft Office Tools". Several free OCR applications are also available on the Web.
OCR programs aren't 100% accurate. The don't always get it right, so expect to have to do some correcting in the text file that's created. Some fonts, sizes and page layouts confuse the software, and some programs are better than others. But in any case, it's better than having to type the entire document in by hand.
Jul 20, 2011 | Office Equipment & Supplies
How do I use my x5495 to scan a resume and then to edit it with my Dell XP computer?
You'll need to scan the document with an OCR software package (Optical character recognition) that will recognize the letters themselves and transmit them to word processing application, such as Word for Windows. Most scanner packages come with some form of OCR utility, so check your installed software. You may already be set up!
Best of luck, William
Mar 03, 2011 | Lexmark Office Equipment & Supplies
I have a Lexmark 6150 and have misplaced my disk. I have a new computer and need to scan a document. I'm told I need to insert the OCR application located in my OCR directory of which I do not have. HELP!
The OCR application/software can only be installed using the installation cd. It's not available for download. I advise you to call Lexmark at 1-800-LEXMARK (1-800-539-6275) for the installation cd. They can better assist you with this request. They might be able to send you one for free. If you need more assistance, leave a comment. I'll get right back to it.
Apr 19, 2010 | Lexmark X6100 Flatbed Scanner
After I scan text, I cannot put it into a Word document, edit, or anything. I have an Epson 2400. thanks I do not have the scanner directions.
In order to scan to word so a document is editable you need to use Optical Character Recognition Software (OCR). You can download free ocr software from www.simpleocr.com Use that software and then either export once scanned to Word or Save as a Word document in the OCR application.
Jan 22, 2010 | Epson Perfection 2400 Photo Flatbed...
I want to install the OCR (scan as text) software for my Lexmark X1270. It worked on my old computer, but on my new one it tells me to use my CD, which I don't have any more. I've tried re-installing the...
Without CD you can't install OCR or Optical character recognition software because OCR function is not installed in scanner but in computer. Usually when you buy new scanner you get CD or DVD with drivers and some lite version of OCR and some other programs for graphic editing.
Oct 24, 2009 | Lexmark X1270 All-In-One InkJet Printer
I need to find out how to change the settings on a 4022sp from text to text/ocr
As far as I am aware this model does not have that function.
I have seen a similar scanner where the document was retrieved from the scanner to an application on a network workstation that then went on to OCR the image.
You may want to look at it from that angle.
Aug 25, 2009 | Office Equipment & Supplies
I just bought a new lexmark copier, scanner, fax,
This should give you a good explanation of what ocr is.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1268319518_0_en,00.html
Jul 07, 2009 | Lexmark X3550 All-In-One Printer
X5495 - OCR Program Missing.
Do you have MS Office 2003 or 2007? If so, there is a Microsoft Document Imaging tool that you can use to scan text documents. You can also search www.download.com for free OCR tools you can use for the same purpose.
Apr 15, 2009 | Lexmark X5495 All-in-One &USB...
Lexmark X2500 All-In-One Printer Logo
489 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
