Question about HP Compaq Business nx7010 Notebook
My Compaq 7010 has a faulty Power Button; can this be replaced?
  • HP Master
  • 4,806 Answers
Yes you can usually replace the power buttons on these units.
All you need to do is google the part. Sites like eBay are the best place to start. Just search for the part via your laptop model number.
Regards.
Posted on Jul 19, 2010
    Genius:
  • 1,040 Answers
yes. Visit to the service station and they will do the job
thanks for using fixya
My Stylus 7010 freezes when I press the shutter button in camera mode.
Try factory resetting it. Use then user manual for how to factory reset... Else you can call up customer care for a service centre location near you and if its in the warranty period you probably won't be charged.
Oct 09, 2014 | Olympus Stylus 7010 Digital Camera
Blinking power button
Try replacing the CMOS Battery. If that doesn't fix it, try having someone check the Power Supply.
Aug 04, 2014 | Dell, Inc Dell OptiPlex 7010 - Core i5...
No view of Olympus 7010 screen after dropping
You'll have to take the camera in for service to replace the component that was damaged in the fall.
Unfortunately, the cost to repair the camera will most likely be as much or more than just buying a new, replacement camera.
Feb 13, 2012 | Olympus Stylus 7010 µ 7010 Digital Camera
The small rubber button on my compaq presario V2000 isn't working. When I open the screen of my laptop the light on the screen will switch on for just a moment, and then switch off. How can I fix it so the...
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Mar 08, 2011 | HP Compaq Presario V2000 Notebook
I have a olympus 7010 digital camera. everytime i try to turn the camera on, a orange light flashes and turns off. i've tried charging the battery numerous times.
The Olympus Stylus 7010 has a rechargeable lithium ion battery that will eventually wear out-- your battery could be at the point where it does not hold a charge any longer.
Have you previously noticed a degradation in battery life? If so, you can try replacing the battery or connecting the camera to a constant power source (like an AC adapter) to troubleshoot.
Mar 04, 2011 | Olympus Stylus 7010 Digital Camera
Mon ecran hp compaq nx 7010 affiche des lignes blanches et lorsque je le branche sur ecran externe ok
What is happening to your laptop is the power line connecting some row of pixels is failing so only partial colors are showing up causing the white lines. Usually screen replacement is the only answer to fix it and you may find cheaper LCD replacements on Ebay or Amazon.
Qu'est-ce qui se passe ? votre ordinateur portable est la ligne reliant certains rang?e de pixels est un ?chec alors que les couleurs sont partielle montrant par causer les lignes blanches. Habituellement remplacement d'?cran est la seule r?ponse pour le r?parer et vous pouvez trouver moins cher remplacements LCD sur Ebay ou Amazon.
Feb 14, 2011 | HP Compaq Business nx7010 Notebook
Compaq 5000 push power button starts up shows loading windows then stops light stay on but will not boot. Replaced hard drive no help.
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 02, 2010 | Compaq computers10: Proliant 5000 CPU Card
I try to power up the unit and it will not power up I tried the escape button trick it worked but I had nothig on my screen I tried to hook up an external monator and still nothing. I think I have a issue...
hope this helps
Sep 21, 2010 | HP Compaq Presario F500 F700 and G6000...
HP compaq nx 7010
Sorry to dissappoint You mate, but NX7010 has no built-in microphone... VERY illogical design, for its time, but it's the sad truth. Buy an external one, plug it in and You shall see, that the sliders and tickers are suddenly working.
Feb 22, 2009 | HP Compaq nx7010 Notebook
Laptop not turning on
you would atleast be able to access the bios if it was just the hard drive issue.
If you are running just off the battery try running with your power supply on it and see if that does anything else
if not you may have a short in the power supply some where.
Aug 07, 2008 | HP Compaq nx7010 Notebook
HP Compaq Business nx7010 Notebook Logo
110 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
