Question about Stihl Ts 700 Cut Off Saw Model Name Plate Tag
Stihl 410 wont start put new spark plug but no spark
    Sergeant:
  • 200 Answers
Try a new coil.Hope this helps and Thank You for asking!!!
Posted on Jul 19, 2010
How do I fix a Stihl ts420 that won't start?
you have spark and fuel ( quickstart) but it wont fire
probably because the third component to make an engine run is missing and that is compression
If it is 4 stroke then it will be a valve problem or rings--if 2 stroke it will be crank shaft seals or rings
If it is a 2 stroke ,then it is a good thing it didn't start because there is no lubricating oil in starter fluid
Jan 29, 2016 | Stihl Garden
Ts 410 won't start
check for spark, check for fuel, if you have both poss pot and piston
Apr 13, 2014 | Stihl Ts 410 420 Cut Off Saw...
Stihl ts400 starting problem
sounds like your getting air leak around a gasket
Jan 30, 2018 | Stihl Ts400 Cut Off Saw Carb Carburetor...
029 stihl wont start
Disconnect the stop switch to rule out a problem here, if there is still no spark with the plug out and earthed against the cylinder, then it sounds like a replacment ignition unit is required
Nov 25, 2012 | Stihl Garden
Stihl ts 400 wont start
If there is good fuel in the tank and the plug gets wet with fuel, and there is a good spark stating the obvious it should go, if not there could be a mechanical issue, piston scored, rings worn etc,
Apr 16, 2012 | Saws
Stihl 011 av wont start
Flooded? Try a new plug, or get that one cleaned up. If it is sparking and wet, it should fire, even if it doesn't run, it should spark. Did you put the jets or the needle valves back to where they were? I think they start out at 1 1/4 turns out , then adjust the low and high. If it is fouling out with too much gas, the low speed jet is open too far.
May 07, 2010 | Oregon Scientific Complete Carburetor for...
Changing spark plug on a Stihl 410 cut off saw,
right by the decompression valve is the spark plug. if you remove the one screw for the valve you will see that to get access to the plug is very easy,
Feb 15, 2010 | Saws
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
STIHL FS110R weedeater won't start, does not hit at all. Cleaned plug, spark arrester and air filter, what's up? Like new!
my son flooded out my stihl weedeater, I took it had a new filter put in and it started right up. he went to use it again and now it wont start! It sat overnight and i still can start it! Any suggestions please
Mar 11, 2009 | Garden
Stihl Ts 700  Cut Off Saw Model Name Plate Tag Logo
826 people viewed this question
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
rlev_7
Level 1 Expert
Spud Howell
Are you a Stihl Saw Expert? Answer questions, earn points and help others
