I have the same problem, Code f and h flash, I press cancel once and then start and it works.... but it is frustrating cause i do this 10 times during the washing cycle. help..
Do you want to run diagnostics? Why did you change the actuator? Press cancel twice and unplug the unit. Did it work again? Have you checked the cold water valve. Most likely what has happen though, you pressed the start button to long. It is very easy to do this. I have done many service calls where they have pressed the button more then a quick press to start it. So just try, press the cancel and see if it comes out of pause. One quick press, less that 3 seconds. If you need more help, I am here.
1. Press PAUSE/CANCEL button on the touch-pad twice. 2. Drain the unit, then check that the Drain hose and Drain Pump Filter is clear of foreign objects. 3. Check/ Replace Touch-pad/LED assembly. 4. Check harness connections. 5. Check the CCU.
Remove the front panel and check the pump filter for objects then grab the tech sheet behind the white box and use the diagnostic instructions. You have any non-HE soap in there or 2 much the machine will overamp and act all weird and then shut down with error code flashing. If it is an F-21 it means a Long drain. Possible cause: Clogged filter, clogged/failed pump.
While the machine is on press "end of cycle" for 3 seconds, then wait
for 2 minutes to try the door. Try this again if it does not open, this
is the child lock program - to lock and unlock; it is the same
procedure.
Check your washer plug to see if the connections are
tightly
screwed. You can also plug off for half an hour to reset. How abt a nice rating
for the free help? Thnks
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds. * Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet. * Press the Pause/Cancel/Stop button twice to clear the "PF" in the display. * Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
After power outage that will happen do this to fix.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
