Question about Dell 924 All-in-One InkJet Printer
I have a dell 924 printer and I cannot seem to find the right port for it. can you help me?
  • candlemakerk Jul 19, 2010
    I forgot that the dell 924 is on my toshiba satellite A205
Dell all in one, 924 printer will print, but will do nothing when ask to scan!
Posted on Oct 05, 2010
    President:
  • 1,335 Answers
The system will assign the port. You can download the driver and manual for the 924 at
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?c=us&cs=19&l=en&s=dhs&~ck=anavml
To connect the printer, connect the printer and computer using a USB cable, download and install the driver, turn on the printer. The system should sense the printer and install it so it can be used. Let me know if this solves the problem. Thanks.
Posted on Jul 19, 2010
  • Robert Kitaji Jul 19, 2010
    I'm not sure what your comment about the A205 is about, but you should be able to plug the 924 into the USB port and install the software. Is there something I'm missing?
  • 1003 Answers
SOURCE: Dell 924 paper feed
you need to clean paper feed rollers with isopropanol alcohol on a microfiber towel or get a sheet of cardstock to print on as it prints it will force out any foriegn material
To correct paper feed function make sure feed sensor lever isnt broken
Posted on Jan 07, 2008
damanpreet_c
  • 69 Answers
SOURCE: dell 924 printer
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 06, 2008
  • 514 Answers
SOURCE: Dell Printer 924 error #1203
go to page 59 of the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it) look for
code 1203 in the middle of the page. good luck!
Posted on Feb 28, 2009
ohms
  • 1879 Answers
SOURCE: Mac Compatible problem with Dell 924 Printer
no mac driver for that printer
Posted on Apr 14, 2009
Yomitako
  • 70 Answers
SOURCE: mac compatible with Dell All In One 924 Printer
Unfortunately, there is no offical driver for Mac OS X for this specific printer, but you can try following this link to see if the steps there can at least help you try to use the printer under that operating system. If it does, great, but if it doesn't, I'm afraid you're out of luck
Posted on May 10, 2009
How do I Enable bidirectional communication on a dell 924 printer? Thanks
Go to Start
Control Panel
Printers
Right click on your printer, left click Properties, left click Ports.
Make sure to check the box Enable Bidirectional Support. (Enable Biodirectional Support)
Jan 22, 2011 | Dell Office Equipment & Supplies
Dell printers 924 "no communication with computer". cable is OK. Prints test on printer but not from computer. Unplugged and reconnected and restart computer did not solve problem.
i think you must have wrong configured the port;click on printer and select properties;select port and try all LPT & COM ports one by one
Dec 01, 2009 | Dell 924 All-in-One InkJet Printer
Dell 924 - can't fnd manual - don't think it's hooked up right
You need a power lead to the printer and a usb lead going between the printer and the computer. The manual is available to download at http://support.euro.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf
Jan 20, 2009 | Dell 924 All-in-One InkJet Printer
Will my dell 924 printer still work without the blue cartridge
when you put the black in you had to also put the blue in do you have the empty cartridge if so put it back in for right now and see if this helps
Jan 09, 2009 | Dell 924 All-in-One InkJet Printer
924 printer error 1203 on new color cardridge
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 08, 2009 | Dell 924 All-in-One InkJet Printer
DELL 924 iNKJET All In One Printer
Ok well I've had this same problem before....what I did was insert the Dell AIO 924 CDs and did the installations, after installation completes you should be able to acess the Dell All in One Center at which point you should be able to scan.
This may help
Nov 13, 2008 | Dell 924 All-in-One InkJet Printer
Right cartridge incorrect
I also have a problem with my Dell 924 it's driving me mad! it just keeps flashing right cartridge incorrect: Can someone please help me!
Inversnaid
Sep 02, 2008 | Dell 924 All-in-One InkJet Printer
USB Cable?
It should connect directly to the printer. Exactly where varies from model to model, but there should be a small port it will fit in. Just FYI, the printer will not be powered by the USB cable, it will require a separate power cord (which you probably already knew and had plugged in).
Aug 28, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
192 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
