Question about HP Hewlett Packard LaserJet P3005n Printer
Error 49.4602 on p3005n printer.after restarting printer priblem solve but after few time error appear again and we restart the printer. Then error removed.
SOURCE: hp 2355 all in one error message
mine HP was acting the same way after a jam. I contacted hp and they told me it was a hardware issue and that I would need to purchase a new printer. I found a KB on thier site for this issue. It involved removing both ink carts and then reseting the printer with the ink carts out. it seemed to work.
Posted on Jul 03, 2008
APremkumar
  • 564 Answers
SOURCE: hp 3325 printer printing test page and not printing other pages
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on Apr 06, 2009
  • 102 Answers
SOURCE: Problem prompt on DIMM error
If the printer freezes or crashes at memory count or if the printer shows error Mem test failure replace DIMM or if the printer display is completely blank in that case obviuosly you can try reseating Mmeory Module.
However that doesn't fix the problem formatter board is faulty.
Need to get Formatter replaced.
Thanks and Regards
Neeraj Sharma
Posted on Jul 03, 2009
Jimsta01
  • 405 Answers
SOURCE: Error code 49-4602 - printing error
Check the following link, it will explain the error number 49 you have.
http://www.printertechs.com/tech/error-codes/error-codes-20-49.php
Posted on Apr 05, 2010
  • 8 Answers
SOURCE: mem check failure replace dimm
Hi<br /> <br /> The formatter board in the printer is faulty. The heat from the chips softens the soldier and makes the joints bad causing all types of misleading errors.<br /> To solve the problem you can try two differant methords, both will endevour to melt the soldier joints back to good.<br /> <br /> Slide the right hand cover to the back of the printer and remove.<br /> <br /> Open metal door to see formatter board<br /> <br /> Disconnect the three wires from the top left of board, they only go in one way so you do not need to mark them.<br /> <br /> Undo the screws around the board and pull the board free.<br /> <br /> Using a hot air paint stripper heat up the reverse side of the board applying plenty of heat to the soldier joints<br /> <br /> Reasemble<br /> <br /> Do a cold restart and away it should go.<br /> <br /> Alternative to the hot air gun you can but the board in the oven.<br /> Trust me on this one it will survive.<br /> <br /> Support the board at the edges on small blocks of wood to stop it from touching the pan<br /> <br /> Pre heat the oven to 180 degrees<br /> (soldier melts around 165)<br /> <br /> Put the board in for eight minutes and then remove, let cool befour touching.<br /> <br /> Reasemble<br /> <br /> Do a cold restart and the printer should work.<br /> <br /> Chris<!-- from fixya rte -->
Posted on Aug 12, 2010
What does it mean check ink u163 0f canon pixma 360
re filled inks have being installed that's why u get u163 or u162 error
try following to resolve yours error u163 or u162
  1. Turn off your printer and turn it on again.
  2. After the printer initializes, try to copy or print something. The error will appear again.
  3. When the error is displayed on the display panel of the printer, press and hold the STOP/RESET button and wait until it self restarts.
  4. Release the STOP/RESET button while the printer is restarting.
  5. Wait for a few seconds and the pending print jobs will commence.
Jul 22, 2014 | Canon Pixma MX360 Printer
I have canon pixma 310 its say chech ink u163 what thats mean
Good Day Sandip920!
Error U163 means, the printer detected that your black ink cartridge has been refilled with new ink.
It is very easy to clear this error and keep your printer printing.
How?
1. Turn on your printer.
2. When error U163 appears, press and hold the STOP/RESET buton on the printer. Hold it down until the printer self restart and initialize.
3. if after U163 is cleared off and appear another error, U162, press and hold again the STOP/RESET button and wait till printer self restart and initialize again.
Hope this helps!
Don't forget to rate my answer.
Thanks for asking Fixya.
Sep 16, 2011 | Canon PIXMA MX310 All-In-One Printer
Mem check failure replace dimm error message shown on hp laserjet p3005n printer .please sugest me how to solve this error.
THE DIMM is a memory module that has either dislogged ( moved the unit recently?) or is damaged. Check the integrity of the Memory module by unseating and reseating first . If that fails to fix it get a new module.
Please rate my hyelp++++Thanks for using FIXYA
Aug 04, 2010 | HP LaserJet P3005n Printer
HP printer error 10.92.02 and 10.92.01 - cartridges not engaged . . just changed the cyan cartridge and this error appeared - help
I don't know what printer you are using because a P3005N is a monochrome printer and doesn't use a cyan cartridge.
For a lot of colorlaserjets you can try the following steps. Remove all the cartridges, close all doors and power on the printer and then power it off. Insert the cartridges one by one and power the machine on and down each time you inserted a cartridge.
Feb 18, 2010 | HP LaserJet P3005n Printer
Paper jam error message
This problem is a detection problem, due to a bad sensor selection or incorrect label size.
If the labels are white labels with a separation between each, select TRANSMISSIVE. If the labels are preprinted, select the TRANSMISSIVE PREPRINTED LABELS and set the threshold doing this.
With the printer in ONLINE, press PAUSE once, the message PAUSE appears in the display, press and hold on the PAUSE key, TRANSMISSIVE is displayed, release the key and press PAUSE until labels starts to feed, let feed some labels (5 or 6) and release the key. Press Restart and start to print.
Dec 08, 2009 | Toshiba TEC B-SX4 Thermal Label Printer
Thanks and Regards
Neeraj Sharma
Jun 27, 2009 | HP LaserJet P3005n Printer
Printer printer twice in one page
i think the settings not correct , resetting the printer properties properly and check , if the problem not solved then uninstall the printer driver and restart the system and after restarting the system reinstall the printer driver properly by using proper port setting and then restart the system . When the system start then check
Jun 02, 2009 | HP LaserJet P3005n Printer
HP 8250 Printer restarts after shut off
i have a problem with my hp 8250 the error code Oxc18a030a keeps on coming up and says to put my 8250 off than on every time i do this the same message appears
May 16, 2009 | HP Photosmart 8250 InkJet Printer
4.4C0B error in printer
Hi there try removing the additional memory the test.
Thanks J
Jan 18, 2008 | HP LaserJet P3005n Printer
HP Hewlett Packard LaserJet P3005n Printer Logo
2,277 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
