Question about RCA ViSYS 2-Line Speakerphone
Voicemail messages recording and playing back
When the phone rings and there is no answer it goes on recording but it doesn't record . The answerer is on.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 120 Answers
Turn off turn back on keep trying if not turn off leave 1 day it should work
Posted on Jul 19, 2010
Why won't the answering machine, when set to 'answer on' not record a message?.It goes to voice mail. Is my machine defective?
Maybe the answering machine is set to pick up at say"5 rings" and the voice mail is set to pickup at "4 rings" . Change the voicemail setting to a higher setting than the answering machine. That may be the problem.
Aug 26, 2014 | Lands Phones
My Vtech phone answering machine no longer records incoming messages on its base. Help
From the sound of it it I think its either: your mailbox is full or the feature has been turn off accidentally.
Vtech's support recommend the following (I've removed things like 'make sure its plugged in' and 'is your answering system is turned on' etc..)
1 Some answering systems have an announce only option, which plays your greeting but won't record messages. Make sure your system is set to record messages.
2 Your answering system's message capacity may be full. You must erase old messages to make room for new ones.
3 If you have voicemail service in addition to your answering system, your caller's message may be going into voicemail before your answering system picks up the call. Program your voicemail to pick up at least 2 rings after your answering system is set to answer the call.
May 05, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
KXTG9341 Top light flashing and 'New Voicemail' message on handset display, but no new message recorded on the answering machine.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone.
Please contact your telephone company for instructions on accessing their voicemail system.
Feb 27, 2014 | Panasonic DECT 6.0 Expandable Cordless...
If I get this AT&T 1739 answering machine will it retreive messages when I am on the phone with someone else, also can I record my own message on it for my business
Without call waiting or a second line, callers will get a busy signal if you're already on a call. This happens at the switchboard; it doesn't matter what type of answering machine you have because the second call doesn't get that far.
You can record your own message on the 1739 but, as mentioned above, if you're already on a call then the second call never gets that far.
Mar 08, 2012 | AT&T ATT1739 Digital Answering Machine
A man answers my phone with "The answering machine is off. Please leave a message" Sometimes it leaves a message and sometimes it doesn't. The menu options I get will not restore it to my...
"The answering machine is off. Please leave a message" (sic) This doesn't make sense.... how can one leave a message if the answering machine is OFF! Unless it goes to a voicemail etc? It's just not possible?
I suggest that you use your manual, and reset up your system again, perform a Factory Reset and then set up what you need to do again, this will clear any erroneous data that maybe causing any problems.
Whats seems to be happening is that the default "Voice" is being activated instead of the recorded message? I think you need to do it again.
After you have done this, record your message and set the answering machine to ON. Then test it from another phone.
NOTE sometimes with answering machines, if they ring more than a certain number of times, without being answered, the AP may switch OFF, ON or indeed do "Other" functions" that may be assigned, so ensure that this "Feature' isn't active or enabled or whatever.
May 16, 2011 | Uniden Cordless Phone
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
Mar 30, 2011 | Uniden Cordless Phone
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Apr 14, 2009 | Lands Phones
Buzzing
you need to ring up ur service prover you they can fix the line for you its not the phone
Mar 02, 2009 | Vtech 5.8GHz Analog Cordless Phone
I want to leave my own answering message on my voicemail, how do I do that?
Press Menu. Then the unit will say "record outgoing message" Press the REC/Memo button and the unit will say "recording" and beep. The display will start counting in seconds. Speak your message. Press the play/stop button to stop recording the message will be played back to you.
Sep 22, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
RCA ViSYS 2-Line Speakerphone Logo
215 people viewed this question
Top RCA Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
