Question about DCS RGS-486GD Gas Kitchen Range
Left rear iginitor continues to clik when knob is off
Pushing on the knob may cause the clicking to stop. When the burner is lite, the clicking will stop.
    Brigadier General:
  • 3,917 Answers
Hi
The problem is a bad or shorted ignition switches for these burners. Unfortunately these parts are no longer available due to age of the product. If your mom does not care, you can unplug the stove from the outlet and she could use it with a lighter (at least until you will get a new one).
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 19, 2010
Igniters won't lite on stovetop
Check the wiring connection to igniter. If electricity is reaching the igniter and still nada, then the igniter is bad and needs replacement.
Oct 26, 2015 | Kitchen Ranges
Why would the left burner activate the right igniter?
Sometimes a lot of the holes in the burner get plugged. I use a toothpick to clean them out.
Hope this helps.
Mar 20, 2015 | Kitchen Ranges
Sears Kenmore gas stove, the front left and the left and right rear burners turn on when the knob is turned to the lite position. The right front burner doesn't turn on when put lite position. N
If there is no clicking sound like you hear when you turn on the other burners than I'm going to say that either the electrode is bad or the spark switch, which is what you turn to turn on the burner to begin with. Both parts are cheap so it may be a good maintenance thing to change all of the burners. Make sure you have your model and go to www.repairclinic.com and order both parts, and if you don't need one send it back for a full refund even if you installed it. good luck
Apr 29, 2012 | Kitchen Ranges
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 | GE Cooktops
How do i start the pilot light on a JGBP28wek6ww
That model is an electronic ignition, ther isn't a standing pilot on it(no liitle flame that stays lit). Light the burner by pushing in on the knob and turnlig to "LITE" position, you will hear a clicking noise the sound of the electric spark igniting the burner, turn the knob to adjust the flame size. Keep in mind that all igniters spark whenever any of the knobs are turned to the "LITE" position. Good luck !
Nov 30, 2009 | Televison & Video
When I turn on a burner, all the other burners click like they are trying to turn on as well. The clicking is continuous and really annoying! Thanks for your help! Tammie
Anytime you turn on a gas range all burners click for safety reasons. If a knob has been turned by mistake the gas lights to prevent gas from escaping into the room. If you turn the control knob past the LITE position after the burner lights you should be OK and stop the clicking. If the clicking continues regardless you have a defective ignitor switch that must be replaced.
Aug 26, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Ignition will not stop clicking...
Did you clean your stove recently? If the switches under the burner knobs get wet they will cause the burners to click. Unplug the unit or shut off the power for a day. Once the swithes dry, it should work normal.
May 05, 2009 | GE 30 in. Profile JGP932 Gas Cooktop
Ignition problems
It sounds like the round burner orifices are dirty. Remove the round orifices and clean in warm soapy water, using a plastic scrubber or toothbrush to remove and dirt and residue around the sides of the burner. Do the same on the little electrode that protrudes at some position around the burner orifice seat.
The system works by the spark ignition module knowing a gas knob is open, and sensing for a flame by ionization within the exhaust gases of the flame. If things are dirty, then the module cannot read the ionization and shuts down the burner, and will also cause the spark to continue.
Also make sure all the burner orifices are properly seated in their holder. If not, the same thing will happen.
Jan 14, 2009 | Gaggenau 23 in. KG 260 Gas Cooktop
Ticking sound of gas igniter continues after off.
try to clean the place wen u remove the control knob,by using a vacium.
Nov 19, 2008 | Cooktops
DCS RGS-486GD Gas Kitchen Range Logo
32 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal De
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
