Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
I plug the cord in the lawn mower and the battery will not charge
    Champion:
  • 313 Answers
May need new battery not holding
Posted on May 29, 2008
I have a cc 500 bat push mower the battery charger was leftout on rain the light dont come on for charger is it fried also does it have a plug that i can plug extenstion cord in or do I n
The charger lead should have been connected to a Residual Current Device, or Earth Leakage Breaker that should have flipped the power off. There should be a reset button on the plug.
Charge the mower for 14 hours before initial use. Charge mower indoors in a dry area out of the weather. DO NOT charge in rain or wet locations. IMPORTANT: Use only the battery charger provided with this mower. Plug the battery charger into the battery first, and then into any standard 110/120 volt household electrical outlet. See Fig. 3-9 for B battery charging location. A C NOTE: If an extension cord is required, use one that is at least wire size 16 AWG. Connect the extension cord to charger before plugging extension cord into electrical outlet. NOTE: You may charge the battery with the battery removed from the mower. IMPORTANT: Always recharge battery fully. It takes 14 hours to recharge a completely discharged battery. A flashing light on the battery charger indicates the battery is less than 80 percent charged; a solid green light indicates the battery is 80 to 100 percent charged. A full charge will be achieved in less than 14 hours if the batteries were only partially discharged. NOTE: It is recommended that the mower be charged once every two months during storage. IMPORTANT: Always disconnect battery charger (or extension cord, if used) from the electrical outlet first, then disconnect battery charger from battery. NOTE: It is recommended that the mower be charged immediately after it has been discharged. Storing batteries in a discharged state could reduce future performance. WARNING: The battery contains corrosive fluid and toxic material - HANDLE WITH CARE. Keep away from children. Do not puncture, disassemble, mutilate, or incinerate. Explosive gases could be vented during charging or discharging. Use in a well ventilated area, away from sources of ignition.
Cub Cadet CC500 BAT Operator Manual Charging The Battery
Cub Cadet CC 500 BAT Review Pros Cons and Verdict
It is a 48 volt battery, so the charger for this is special. contact Cub Cadet direct for a replacement.
Service Parts
Aug 09, 2017 | Cub Cadet Garden
Batteries shows fully charged. 24 volt shows 27 volts fully charged but shows RED light when install in mower.
it's never the motor, it's always the batteries.
you are most likely testing the batteries with just a meter and not under load
you will need a tool to put the battery under a load, it will end up costing more than two new batteries.
just replace the pair and you will be fine, i have done enough of these over the last few years.
good luck and you will have no problems with the new batteries.
May 21, 2015 | Electric Earthwise Corded Lawn Mower...
Key won't start my mower
starer is dirty take apart and clean dirt out of it reassemble star it
Sep 08, 2014 | Toro Recycler 22" 149cc Personal Pace Lawn...
How do I repair the charge switch. When placed on charge the charging light pulsates on/off.
it might be the charger is bad if you can use a voltmeter check and see if continuosly get volts from charger try that first
Jun 22, 2014 | Remington PowerMower 17-Inch 60-Volt...
My Craftsman 16 hp and 42 battery not charging is it normal?
get mower started and check the charging voltage at battery. it should be at least 13.5 at battery.check cables to battery and the inline charging fuse, its located somewhere in charging system.if its charging, but battery is still dead. it could be a bad battery. or alternator. . Examine the lawn mower electrical system by starting the lawn mower up, and then removing the battery. If the lawn mower turns off after the battery is disconnected, the lawn mower electrical system is the culprit.
its a good possibility that the battery is bad if it has been in use for 4-5 years.
check the fuses first. good-day !
Oct 02, 2011 | Garden
I have a black and decker 18 in lawn-mower. I bought a haeavy duty extension cord to connect power to the lawn mover. It was working then suddenly it stop and blew the switch. I plug the cord to a...
I would say the outlet/ cord. here is a recommended types and lengths of extension cord, Tim:
http://support.mtdproducts.com/app/answers/detail/a_id/435/~/what-type-%26-size-of-extension-cord-can-be-used-with-an-electric-mower%3F
May 29, 2011 | Black & Decker Black and Decker & Grass...
Briggs and Stratton Troy Built 21inch 190cc 650 series Gas Powered self propelled Lawn Mower. I moved to new house and the movers lost the manual. I bought it last year so only one seasons use. How do I...
If how you described you unit is true you do not have an electric mower you have a gas powered mower, you DO NOT have a battery!!!??? Place the throttle lever to choke position and prime carb with primer bulb 3-5 times then pull cord. Wala!!!! It's running rite. That guy at Loews must have been smokin somthin. Good Luck...
Apr 22, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
My rl500 robomower will not charge when pluged in-just a row of dashes desplay on and off and a sound of a clunck or a click is heard.
Sound like a problem with the power inverter board. It may have swollen or blown or leaky capacitors which control the current flow through the board. This board is attached to where the plugin cord attaches too.
Oct 10, 2010 | Friendly Robotics RoboMower 21Inch...
Batter life in the second season
When batteries are only used seasonally, and they are stored, they can become damaged from weather or from storing them when they are not fully charged. In general, batteries used seasonally will have a shorter lifespan, so it sounds like you likely need a new battery. Check out http://www.batteryinternational.com/electric-lawn-maintenance-batteries.html for a replacement, and be sure to charge it fully before storing.
May 19, 2009 | Remington PowerMower 17-Inch 60-Volt...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
64 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
