Question about Magic Chef Dryers
I REPLACED THE BLOWER FAN BLADE , THE UBIT RAN WELL, WHEN TURNED OFF ,TRIED TO RESTART NOTHIN HAPPEN. WONT COME ON.
  • Magic Chef Master
  • 8,220 Answers
Did you clean out the dryer and vent?i REPLACED THE BLOWER FAN BLADE , THE UBIT RAN - 224997a.jpg670f53d.jpg6dfa421.jpgThe thermal fuse i REPLACED THE BLOWER FAN BLADE , THE UBIT RAN - 0e4bfd7.jpgblown. Replace the limit that comes with it too. That limit take a beating when that blower wears out and starts slipping. 0e4bfd7.jpg
Posted on Jul 19, 2010
  • Dan Webster
    Dan Webster Jul 19, 2010
    Their are 2 thermal fuses. Use the one that is the same color dot as yours. One of them is for gas the other is for electric heat. The gas one blows at 250f and the electric one blows at 300f. That is the only diff. I have had people tell me one blowed out and they used the other one till it went.
Fan heater blower on dimplex cadogan CGN 20 not working properly0 optimyst electric stove
Take it out and see if the fan wil turn by hand. It may have somethng obstructing it. The clicking is the motor overload. It wil burn out if it continues to keep clicking.
www.dimplex.co.uk/assets/.../Cadogan_Stove_Instructions_Issue_2.pdf
Jun 29, 2014 | Heating & Cooling
Ac compressor will not start
Hello, sounds like a faulty capacitor. Check the capacitor to see if it is puffed up at the terminals. It will be located inside the outside unit and looks like like a can that is oval or round.
Jun 17, 2012 | Goodman Heating & Cooling
The fan in the compressor for the HVAC unit quit running last night this morning after 2 attempts it started and ran fine , cooled form 76 to 72 in about 45 minutes, but when I tried to start it again the...
Replace the fan motor and capacitor. If you want to go the cheaper route, change the capacitor first and try to run the unit. The cap. is what gets the fan motor running on start up. Another way to test it is to manually turn the fan bade and while it's still turning, make sure your hands are clear of the blades and turn the condensor on. If the fan runs normally, then it's your fan capacitor.
Jul 02, 2011 | Amana Heating & Cooling
Have a rheem 90 plus gas furnace the problem is that when you call for cooling the indoor blower does not come on. On the control board there are 2 green lights and one orange light. The top green ligt is...
At your thermostat turn the fan from auto to on, if the blower motor still does not come on, down at the furnace remove the blower door, turn power off first. Locate the blower motor leads, switch the cool lead which is usually black with the blue wire which is usually medium high.
Make sure while you are at it to see if the blower motor will turn by hand. Put door back on turn on power, leave the fan switch to `on` still. Blower should turn on. If not then either the blower motor is either burned out or you have a line/lolw voltage wiring problem.
You did not state if the outdoor ubit was operating, that will make it easier to troubleshoot.
Jun 17, 2010 | Heating & Cooling
Replace the blower motor
Couple of possibilities asn.
The blower motor may be worn out or something has jammed up the fan blade.
If it hasn't blown the fuse already it may have damaged the blower resistor.
The resistor depends on the airflow from the blower to keep it cool.
Pull the blower motor out, check the shaft and fan blade for looseness and debris. If there is debris in there make sure you get it all out from up inside the housing too.
The blower is fairly accessible and inexpensive on this model of car.
Under the right side of the dash there is a hush panel to remove. you will see the motor housing pointing down. Undo the connector to the motor, 3 or 4 screws retain the motor to the case. Lower it down.
Reverse to reinstall.
Any more questions please ask me.
KL
Jan 03, 2010 | 1999 Oldsmobile Intrigue
Blower motor wont start
Every air conditioner is equipped with at least two motors, the compressor and the fan motor. It is possible for the fan motor to be defective and the compressor to be running. If this is the case the unit will appear to be running and may even sound "normal" but no air is blowing out the front or back of the unit. If, after removing the cover of the unit you discover the fan blade is very stiff and difficult to rotate, the fan motor should be replaced. If the fan blade turns freely the circuit powering the fan motor will require electrical troubleshooting. It may be necessary to have a qualified technician locate the cause of the problem, which may be either a problem with the capacitor, the selector switch or the motor itself.
Jun 06, 2009 | Goodman CKL42AR42 Air Conditioner
Suction
hi!!! clean motor blower blades ,they collect alot of duct and the air in chopped,Good luck.Clean blower fan blades..
Feb 04, 2009 | Electrolux Centralux Vacuum
Replacement fan
please check the of fan , no of blades and direction of flow & also if possible pic of fan . it can be easily avl in open mkt.
ravi
Jan 31, 2008 | Fedders A6P09S2A Air Conditioner
HP Pavilion DV2036e Wont Boot
how long it stays on???let me know
Dec 17, 2007 | HP Pavilion dv1000 Notebook
Dryers Logo
37 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
