Question about Asko Dishwashers
ASKO EXCELLENCE MODEL 1503. GIVING AN F2 CODE. PUMP IS CLEAn. LAST FEW TIMES FINISHES TIME, YET THERE IS WATER UP TO THE HEATING ELEMENT IN THE BOTTOM OF DISHWAHER, WHAT IS WRONG
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Water not heating up
DSBELL, see if your model has a serial number in the range of FR3701001 to FR5008380. If so they had a quality issue with the heater. The element itself should be round and not angular. Call for service, it will be covered. If this is not the case you will have to ohm out the heater, should read between 10 and 30 ohms. If that's ok, make sure the door switches are operating ok, this heater runs through the nuetral side of that door switch. There is also a high limit thermostat on the right side of the motor that should read closed. Catriver...post back.
Posted on Jan 21, 2007
SOURCE: My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Posted on Jan 19, 2010
Macmarkus
  • 2605 Answers
SOURCE: Asko D1776 - Heating element stays on after the
Welcome to FixYa.
Based on your description it is likely a faulty control board, unfortunately. Here's what you can do to check...
**Turn off any power to the unit...safety first**
You'll need to access the control, this is best done by way of removing the front panel, i.e.
Once to this point, identify the wires on contact PF2 and inspect the closest relay to it, which will be K1.
If you are capable, measure amperage from PF2 when the unit is idle there shouldn't be power present, you'll require an ammeter.
Having said all that, it may be obvious when you visually inspect the control, if it's burnt up or if the relay looks burnt inside.
This is an example of a damaged control but it may not be as extreme with a heater relay defective...
Let me know what you find and I'll try to help you further if necessary. For the control should be available at "repairclinic.com"...but if not let me know I may have one left.
Good luck and thanks for choosing FixYa.
Regards,
Macmarkus :)
Posted on Nov 17, 2010
jyackle5
  • 8197 Answers
SOURCE: replaceing heating element in Asko D1996
Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel. Locate your dishwasher's heating element. Open the dishwasher door and look into the tub. It is the thin, circular tube at the base of your dishwasher. It may or may not be covered. If it is covered, remove the lower dishrack, and then remove the cover.
Your heating element is going to have two metal terminals. One at each end. Each terminal reaches downwards, into the base of the dishwasher. Mentally mark the area where each terminal enters the base of the tub.
Now you need to gain access to the heating element's wiring. You can do this by first removing the lower kickplate panel of the dishwasher. There will be at least two screws (but maybe four) holding the kickplate panel in place. They are located either on the top or the bottom of the panel. If the screws are located on the top, you may need to open the dishwasher door in order to gain access to them. Close the door to remove the panel, though.
Now look into the lower access area that you have just uncovered. Pinpoint the area where the heating element terminals extend through the base of the dishwasher. They will each have a wire connected to it. Label each of the wires so that you will be able to properly reconnect them later. Now you can pull the wires off the terminals.
Each wire is connected to a terminal using a slip-on connector. Grasp the connector and pull on it firmly.
DO NOT pull on the wire itself. Pull only from the connector. You may decide you need to use a pair of needle nosed pliers to help you.
Both terminals are secured in place with a lock nut. You can use a crescent wrench or a pair of pliers to losen, and then remove each lock nut. Reach into the dishwasher and lift the element out. Discard it. Situate your new heating element in place of the old one. Slip the terminals through the holes in the base of the dishwasher. Replace each of the lock nuts. Use a crescent wrench or a pair of pliers to tighten them in place. Now reattach each of the wires - remember, you labeled them earlier so you'd know which one leads to which terminal. Put the lower kickplate panel back in place. If you removed a heating element cover, replace it now. Replace the lower dishrack, and close the dishwasher door. Restore power to your dishwasher.
Posted on Jan 22, 2011
What does the Code C3 mean on my Asko Dryer
Here is the list for the DRYER not sure what model... guys please post MODELS!!!!!!!!!!!!!!!!!!!!!
Asko
Dryer
Failure Code Condition Check/Repair
F1 Condensate drain overfilling.
1. Check condensate reservoir pump and drain tube.
F2 Maximum drying time exceeded (3hrs) 1. Check for tripped circuit breaker or blown fuse
2. Check ductwork for lint build-up
3. Check hi-limit and cycling thermostat
4. Check heating element
F3 Thermistor fault 1. Open thermistor, replace
2. Bad wiring to thermistor
F4 Too much lint in the lint filter, front housing, or in the condenser.1. Clean lint from lint filter and/or condenser
F5 Fault in the moisture sensor ยท Lint covering sensor in front of housing1. Bad sensor
2. Bad wiring to sensor
Sep 26, 2014 | Asko Dryers
Asko advisory center
Try these... -Clean out the drain pump inside and below.
- Pull the suction boot off the drain pump, clean out any gookus.
- Blow through the drain hose starting from the connection at the pump.
make sure it is not clogged follow the line from under the sink and disonnect it from under the sink and make sure it is clear
- If all else checks out, replace the pump.
The Duet hides the pump/filter access behind the lower panel. Most LG, Miele and ASKO washers have it right up front for easy access. I guess keeping such a base element out of view helps sales.
Long Drain error code.
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
Press, PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the "F2 error code" will be displayed.
Potential Causes:(1) Check the drain hose and make sure it is not plugged or kinked.
(2) Check the electrical connections at the pump and make sure the pump is running.
(3) Check the drain pump filter for foreign objects.
If the above does not correct the problem replace the pump
Mar 07, 2018 | Asko D1776 Stainless Steel Built-in...
Pump continually running with F2 displayed.
There is water in the lower pan that you must access by removing the toe kick plate and then the panel behind it. you will see water in the overflow area. Clean that out and all will be well. Asko's are awesome dishwashers that capture any water they may overflow or leak internally instead of it going on your floor, then a float switch triggers the F2 error and runs the drain pump.
May 30, 2012 | Asko D1716 Built-in Dishwasher
I have a 1776 Asko model & it doesn't finish its cycle-code mesage f-2 keeps appearing. Can you help me out.
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Sep 18, 2011 | Asko 1375 Dishwasher
I have a dishwasher AEG BM335 super cleaning system. I got a message: F2, and machine stoppet washing, all red lights are on. What can I do? Is any hope for repairing? My name: Arna...
Hi
F2 error in your Asko dishwasher indicates that the water is not draining or is unable to drain and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 02, 2011 | Asko D1706 Built-in Dishwasher
I have an Asko 1485 Dishwasher. It is showing a F2 code.
Hello, welcome to FixYa.
Based on your post, "Asko 1485 Dishwasher. It is showing a F2 code", the good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part.
What the F2 means is the control has indicated a overfill.
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. There will likely be water present.
With the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base, that should restore normal operation...it should be known that if you leave the unit for a few days, the water in the base will evaporate hence appearing as everything is fine again...if any other problem/leak does exist it will return.
If the unit works fine after resetting the power/breaker and soaking up any water present, it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump...
(it could mean a faulty drain pump so you'll need to pay close attention the next few times you run it)
**The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit and the illuminated
F2 letting you know to service or call for service to the unit**
Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary. Good luck.
Regards,
Macmarkus :)
Jun 02, 2011 | Asko D5152XXLS Dishwasher
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
F1 ERROR
This is a water heating error.
There are a few possible causes:
  1. Bad heating element
  2. Bad connection of wires to heating element
  3. Bad control board
Be sure that water hookup for dishwasher is hot water.
Unplug electrical connection to unit.
Remove front bottom cover.
Check wires to heating element for burning and that they are connected properly.
You may need a multimeter to check power to element and to help trace the circuit if necessary.
Apr 15, 2009 | Asko D1776 Stainless Steel Built-in...
Asko Excellence Dishwasher Model # 1504
I have a manual for 1504 and it says F2 blinking means high water level in machine
Apr 15, 2008 | Asko W6021 Front Load Washer
F2 fault
The F2 error codes relates to high water level It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. As well it could be a defective or a malfunction pump. Good luck!
Sep 05, 2007 | Asko D1876 Dishwasher
Dishwashers Logo
129 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
