Question about Dryers
Zanussi Condensor tumble dryer does not appear to be filling water container as quickly as it did? Tumble Dryer also appears to be on longer to get clothes dry. Have checked vents and condensor and all "appears" to be OK. Any help/advice gratefully received. Thanks Dave
  • 101 Answers
Check the Thermostat.
Posted on Apr 21, 2008
LG condensor tumble dryer fault 6E
my dryer turns on heats up but wont spin
Wayne
Jan 03, 2012 | LG IS 250 Dryers
DRCS68W Tumble Dryr, not filling condensor tank after fix. I recently took my unit to bits to get out something stuck. When i put it back together, it drys ok but the condensor tank no longer gets filled...
you should be able to take off the inspection panel, inside should be your maintenance manual. This will help you troubleshoot your issue. and show you where everything goes. If thats no help then you are going to have to get a service manual, or professional help. This website below is dedicated to DIY troubleshooting and repair. http://www.acmehowto.com/howto/appliance/dryer/electric-dryer-repair.php
Jun 06, 2010 | Zanussi TD4100W Electric Dryer
Condensor tumble dryer not drying clothes
Give the correct model number in full. It will be near the serial number. Engineers plan projects and drive trains!
May 25, 2009 | Dryers
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Zanussi tumble dryer does not get very hot
Hi, I take it from the description taht you have given your T/dryer is a condenser? If this is the case you could be looking at several problems? 1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough! 2 it could be the water collection pump? Can you her it running? 3 It could be that half the heater has failed causing it not to get hot enough to dry?
Try these hopefully it should steer you in the right direction!
Feb 09, 2009 | Zanussi TD4112W Electric Dryer
Water leaking from back of m/c
You may have accidentally disconnected the pipe which takes water from pump to bottle.
Please post back if any assistance needed to access pump.
Thankyou for using Fixya.
Jan 23, 2009 | Zanussi TC7114W Electric Dryer
Zanussi Tumble Dryer
Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
Dec 30, 2007 | Dryers
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Dryers Logo
238 people viewed this question
Top Dryers Experts
